Old Sep 20, 2012, 05:00 PM
tahoelight is offline
Find More Posts by tahoelight
tahoelight's Avatar
North Lake Tahoe
Joined Nov 2009
Power Surge
I am having an issue with power surging. Basically in hover the motors surge up and down. Seems like a power supply issue so I am considering rebuilding my wiring harness, but I thought I would see if anyone has some troubleshooting advice before I go through the hassle. It does not change much with different gain settings. I had this issue a long time ago on a Y6 and rebuild it and changed esc's to fix the issue. Any thoughts?
This is on my x8 with Turnigy Plush 40amp esc and Tiger motor 2826 550kv motors. 5s batteries.
tahoelight is offline Find More Posts by tahoelight
Old Sep 20, 2012, 08:43 PM
Webheadfred is offline
Find More Posts by Webheadfred
Air Traffic Controller
United States, TN, Knoxville
Joined Aug 2011
I'm having the exact same thing. I've taken a little break but still read. I thought it was something I had done to the Y6. It does seem to get a little better after about 6 minutes into the flight but then I only have 3 minutes or so left. I too was going to rebuild the harness. Just waiting to see if someone else posted similar. You did.
Turnigy plush 40a... RCTimer 3536-11 750k 4s battery.
Webheadfred is offline Find More Posts by Webheadfred
Old Sep 20, 2012, 08:49 PM
AeroVideoUS is offline
Find More Posts by AeroVideoUS
aka Helidaho
AeroVideoUS's Avatar
United States, ID, Boise
Joined Jun 2010
I know this sounds totally counter intuitive but I had a problem with my motors surging and really bizarre behavior and as it turns out it was vibrations getting to the FC. Fixed that and all was good.
AeroVideoUS is offline Find More Posts by AeroVideoUS
Old Sep 21, 2012, 12:06 AM
Stacky is offline
Find More Posts by Stacky
Pants first, then shoes
Joined Jan 2011
I had the same as you on my X8 Paul.
Stacky is offline Find More Posts by Stacky
Old Sep 21, 2012, 06:01 AM
Joined Aug 2011
Yeah.... That's what I really expect it is. Vibration. I'm using those cheap RCTimer motors and the variance in them motor to motor is enormous. Some are rock smooth on the laser balancer and some you can actually see the bell move. No amount of opposing weight (that I can safely secure) will help. I bought some longer shafts and I screwed up two and got one perfect attempting to replace them. I gave up. The wife-unit said to bite the bullet and get some Scorpion or AXi motors. I hope they're a lot better. That may have to be in next months budget. Such is life.
But at least I'm not blaming HF and demanding my money back!
Old Sep 21, 2012, 02:39 PM
aka Helidaho
Joined Jun 2010
Oh no, that guy hasn't found his way over here has he?
Old Sep 21, 2012, 07:03 PM
Joined Aug 2011
Lol... I don't think so!
Old Sep 24, 2012, 01:01 AM
workshop is offline
Find More Posts by workshop
Closed Account
Joined Nov 2004
His handle said it all...
Jeff
workshop is offline Find More Posts by workshop
Old Oct 03, 2012, 02:44 PM
windfou is offline
Find More Posts by windfou
multi rotors,foamies,car lover
windfou's Avatar
Joined Dec 2008
cheap motor mean also cheap winding assembly so if some have less copper
sure this will make a difference , also rctimer stock program are crap , flashed esc are some much better.. now thanks to Simonk
windfou is offline Find More Posts by windfou
Question Power surge then failure Jinxer Power Systems 1 May 16, 2012 01:49 PM
Help! X400-power surge & cutoff nieves50 Mini Helis 5 May 03, 2006 08:50 AM
Motor surging ,No power Spadkun Castle Creations 4 Sep 10, 2004 01:34 AM
HB power surges with 8cell NiMH Gluey Micro Helis 0 Sep 02, 2003 09:33 PM
Help? Gws IPS A drive w kokams / power surges gomarpyle Parkflyers 2 Feb 22, 2003 09:31 PM
