Old Sep 20, 2012, 04:21 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Question
HK 450 CCPM T-Rex Clone
I just bought one of these today, looking for experienced users of the HK450's
http://www.hobbyking.com/hobbyking/s...dProduct=14516
I am currently flying a Blade 450x FBL and I am having a blast with it. I thought I would pick up this T-Rex 450 clone for $30 and practice building a kit.
I know that this kit is supposedly garbage, but I wanted the build experience as well as something to practice manuevers with that I didn't care much about. I already have the servos, Rx, and ESC to drop in it, so the only other purchase I would have to make is on a used FB gyro.
MY question.....
What parts are mandatory to switch out for Align parts?
I just want to make sure it flies stable and parts don't fly off in the air. It wont be used for ragging out, just sport flying and learning new manuevers, orientations....
I am new to helis, only been flying them for about 4 months, but moving quickly. Coming from 3D airplanes, I seem to be learning quick enough to need to learn how these things go together.
I would like to build a nice 600 around the end of the year.
Thanks for any advice...
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Sep 21, 2012, 08:42 PM
shahram72 is offline
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
It's far from garbage. There are people flying $10 helis around successfully. Head over to the HK450 thread and there's lots of talk over there. It's under mini helis I think.
shahram72 is offline Find More Posts by shahram72
Old Sep 26, 2012, 06:02 AM
ebinmoothedam is offline
Find More Posts by ebinmoothedam
bein ebin
ebinmoothedam's Avatar
Australia, QLD, Brisbane
Joined Sep 2012
Those are not that bad. You might find few screws are missing with the kit and that some might even strip off very easy. Just buy additional screws and also a set of Allen keys from different manufacturers, but same dimensions. There will be minor difference in the dimension of Allen keys from different manufacturers and it will come in handy if you manage to strip the screw. All you need is, be careful with the build and apply loctite where ever needed.
I am actually in the process of building one. You can find about it here --> My Heli Build Log
Ebin
ebinmoothedam is offline Find More Posts by ebinmoothedam
Old Oct 10, 2012, 04:27 PM
ifin is offline
Find More Posts by ifin
Joined Jan 2010
Well, I have older version - HK 450MT (more than two years old), but this one is very similar. Some minor problems, but after all this is very cheep and valuable helicopter. Two weeks ago I have finished a new fuselage for my "old crow". Looks perfect, flyes good.
HK 450 Bell 206 (6 min 55 sec)
ifin is offline Find More Posts by ifin
Old Oct 10, 2012, 05:34 PM
old4570 is offline
Find More Posts by old4570
Australia, VIC
Joined Dec 2011
Love cheap ! , great for learning !
I just rebuilt [ tightened ] the head on my first DIY heli ..
After 6 months of serious abuse , I had to pull the head off and retighten a few things ..
Two screws needed re-thread locking ..
And just a little tweaking ..
And its sweet again , .......
Nice and quiet , less vibration , almost like new , and while its not quite hands off it will hold position [ depending on breeze ] for up to 5 seconds without input .
I removed some flybar weight from it , to make it a ittle more responsive ..
If you take an open minded aproach ,
Set up the kit with some care ,
use add on parts that work [ electrics ] and use it within specs , I dont see why it would not make a fecent 2nd heli
old4570 is offline Find More Posts by old4570
Old Oct 10, 2012, 06:36 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
THAT is a really good question actually. I didn't find anything on mine which I would say absolutely needed to be switched out, but I found that almost every part on the thing was not up to my standards. The only thing I switched was the torque tube (and to do that I had to get an Align boom because the bearing was stuck in the HK one). The TT is solid (light) metal for some reason and I think it was bent - but it probably would have worked actually, it wasn't a really bad vibration.
Here's the thing though - I have a pretty long list of issues that I found just during the build, and only by using visual and feel inspection - didn't have to get out the microscope to find many, many problems. What concerns me is that these are not the kind of problems a beginner would notice. Things like the washout links being too long, and the mainshaft bearings being sticky. So, I still don't recommend these for beginners, but if you absolutely must get a clone, have someone like me check it out before you cause a safety problem for yourself.
jasmine2501 is offline Find More Posts by jasmine2501
Old Oct 10, 2012, 08:37 PM
vewdew1 is offline
Find More Posts by vewdew1
FPV Crash Test Dummy
vewdew1's Avatar
United States, AR, Sparkman
Joined Aug 2012
I've built several of the HK450GT versions and they are far from garbage. There are some poor quality parts that I would in fact recommend swapping out just to save yourself the hassle. For example:
  • I'd recommend an Align main gear set. I've yet to get an HK gear set that was not at least slightly warped. Some have been unusable.
  • As mentioned previously, the screws are cheap and strip very easily. Get a better quality hardware set or at least some spares of the cheap ones.
  • The tail pitch sliders also have a lot of slack and wear out very quickly in my experience. Get a precision aftermarket one.
I've upgrade my first HK450 to the point that its barely an HK anymore aside from the frame, but it wasn't really because I had too. Much of it was just bling.
vewdew1 is offline Find More Posts by vewdew1
For Sale RC Helicopter HK T-Rex Clone 450 PRO Torque Tube (Bind N Fly) $250 (firm price) Diverrcpilot Aircraft - Electric - Helis (FS/W) 0 Sep 09, 2012 11:30 AM
Off Site HK T-REX 450 clone RX and Battery RTF crosby Aircraft - Electric - Helis (FS/W) 0 Jul 08, 2012 02:28 PM
Sold 2 HK 450 T-Rex clone Never flown 1NIB 1RTF Opus44 Aircraft - Electric - Helis (FS/W) 4 Jun 19, 2012 05:21 PM
Sold <<<SOLD>>> T-Rex 450 Pro HK Clone with da Blingggg $170 Mahu Aircraft - Electric - Helis (FS/W) 0 Apr 30, 2012 11:50 AM
