Sep 22, 2012, 01:25 PM
The 'Wack, BC, Canada
Joined Oct 2002
The old adage still applies, "nose heavy flies poorly, tail heavy flies once". You're getting away with murder thanks to the tall grass and EPP but you'd be wise to start with your CG at around 20% of the wing's MAC for a first few flight attempts and then work it back slowly and in small increments from there.
My WAG from looking at the second picture in Shoe's post above is that the forward location shown is maybe OK or you might start with it even slightly ahead of that.
I've attached a copy of the picture of your modified wing with the balance point location as a red diamond that I'd suggest to start out with for this next set of flight tests.
It's a shame that this didn't work out better right from the get go since you did such a great looking job on the paint work. But you're learning a lot and it will mean that the next one with the wings more nicely in the "soaring" position as you originally did should be possible if you can work out some VERY LIGHT structure for the rear of the wing and the tail feathers. Because certainly at the original weight plus the hunk o' lead you have added the present model simply won't have that nice Kestral like glide.
