Going by the video of your test flights, there looks to be some fairly long grass there. Why not try some hand glides into the long grass to see just how it glides.
Another method of determining the CG, and to get some idea of how much reflex is affecting the trim, a smaller scale chuck glider is well worth considering. It has worked for me a couple of times, even using a simple flat sheet foam model, (a Pteranodon and an unusual shaped delta). Once you have a small glider that works, then the full size model wont be much different. |
![]() I tend to agree that the first line of attack would be to try a more forward CG. As mentioned it does seem to be suffering from a strong pitch up divergence which then produces the out of control chain of events. As is said so often you can fly poorly with a CG that is too far forward often. But you often only fly once with a CG that is too far aft. I just hope for your sake that the farmer doesn't come along and mow off your "safety pillow" too soon...
I have tried to balance the CG to 1 1/2 inches behind the leading edge. 10 oz of lead won't do it. The only solution I can see is to cut the wing in 1/2 and sweep it backward. Can anyone confirm what my drawing indicates. Assuming the red wing dot is the CG location on the original.Will sweeping the wing back keep the CG point on the original wing the sam place on the wing or will it change?
Joel, maths is not exactly my strong point, so I reverted to one of my old methods, graph-paper.
I copied your last picture, printed it out onto graph-paper and started counting squares on the slightly swept forward wing. Worked out the approx area, then tried a 20% of the area CG location. It still needs to be forward of you CG marks. I tried 20% as that's what my Eagle flies at. I can't give a dimension, but an educated guess would be 1" back from the LE at the side of the fuselage. This is for the 'swept forward' drawing, just under the 'Original' word. |
Eflightray. I could not get the bird to balance at 1 1/2 inches even with 10 oz of lead. I have decided to cut the wing in 1/2 and insert the shaded piece into the middle. Hopefully this will sweep the wing back enough to allow me to balance it and still retain a birdlike profile
Joel
With your cranked wing planform, the inner halves of the wings need to be stiff in torsion. If not stiff, then the smallest loads can have drastic aerodynamic effects. You could try adding a flat underside skin, to create a torsion box structure. [I am assuming that the section is thin, and high camber] I agree with post 14, that some fin area would be beneficial [maybe essential]. When you get the model flying reliably, you can then work to progressively remove any undesirable features. |
A beautiful paint job.
Joel,
I gave up hand launching after flying electrics for two years. I don't care how good you are - you just cannot hand launch well CONSISTANTLY. MAKE A CATAPULT OR A LAUNCHER , YOU'LL LOVE IT! Spend about $20 on some 3/4" PVC pipe and some connectors + a bungee suitable for the size of you plane. This will give a consistant speed and attitude and your wings will be level too. Google RC Catapult/Launcher for pics. I hope you add a Fin. I think you have a Sever Duthch Roll meaning poor directional stabilit. Ya' gotta' have some Fin - and you dont need rudder with ailerons. You don't have to launch at full throttle either. Add power a couple of seconds AFTER the launch. High power when the plane is "catewampous" creates disaster. GOOD LUCK - But ADD A FIN THAT DOESN'T ACT LIKE A MOVABLE RUDDER. THAT'S MY 2 CENTS.
The deed is done. I have swept the wings more to allow for balancing. I am hoping Kevin will give me an accurate balance point. I believe it to be approx 3 inches back from LE. I love EPP. It allows for quick mods. The torsional stiffness is very good. It may be helped by my filler. Combination of Elmers.woodglue and lightweight spackling.
| Thread Tools | |
| Help! Siren - Power System That Won't Break My Wallet (and PO My Wife) | Left Coast DJ | Electric Sailplanes | 1 | Sep 06, 2012 09:44 PM |
| Discussion um t-28 won't fly straight | dge | Beginner Training Area (Aircraft-Electric) | 3 | Jul 07, 2012 10:13 AM |
| Discussion DH 9116 china model won't fly help. | nick060200 | Beginner Training Area (Heli-Electric) | 9 | Mar 07, 2012 10:18 PM |
| Discussion My latest Foamy (it won't fly) | larryross | Car Talk | 21 | Feb 26, 2012 09:28 AM |
| My plane won't fly. What's wrong? | Ron H | Electric Plane Talk | 105 | Jul 16, 2007 04:12 AM |
