This thread is privately moderated by worldraft, who may elect to delete unwanted replies.
Old Sep 20, 2012, 09:54 AM
worldraft is offline
Find More Posts by worldraft
Trader Rating: 0
worldraft's Avatar
Canada, ON, L'Orignal
Joined Sep 2006
Trader Rating: 0
Laser cutter
Hi Y'all well I finally got my Laser cutting Engraving machine two weeks ago and now how to use it. It seems fairly easy to use as I already cut myself a few ribs for my P40 as a test. Works great. Now I'm testing with other materials.
I was exited so I tough of telling you guys as I am with other forums.
Jean
worldraft.com
worldraft is offline Find More Posts by worldraft
Old Sep 22, 2012, 10:41 AM
cadmanpilot is offline
Find More Posts by cadmanpilot
Trader Rating: 73
cadmanpilot's Avatar
Chesapeake, VA
Joined Oct 2002
Trader Rating: 73
Jean,
That's great. What capacity is your unit.
Paul
cadmanpilot is offline Find More Posts by cadmanpilot
Old Sep 22, 2012, 07:58 PM
Trader Rating: 0
worldraft's Avatar
Joined Sep 2006
Trader Rating: 0
Hi Paul, My unit is a 90 Watt unit.
Old Sep 22, 2012, 08:17 PM
liljimmy is online now
Find More Posts by liljimmy
Trader Rating: 0
20M northeast of Hell Mi
liljimmy's Avatar
United States, MI, Howell
Joined Jul 2012
Trader Rating: 0
are you going to do "side jobs"?
liljimmy is online now Find More Posts by liljimmy
Old Sep 23, 2012, 12:23 AM
Trader Rating: 0
worldraft's Avatar
Joined Sep 2006
Trader Rating: 0
Yes of coarse, I'm working on the size of the plywood and or Balsa in one piece that I will be able to cut. From what I calculated it will be approximately 16" x 20".
Old Sep 23, 2012, 11:40 PM
raptorflight is offline
Find More Posts by raptorflight
Trader Rating: 11
United States, CA, Dana Point
Joined Aug 2012
Trader Rating: 11
What type of unit is it?
raptorflight is offline Find More Posts by raptorflight
Old Sep 24, 2012, 09:22 AM
Trader Rating: 0
worldraft's Avatar
Joined Sep 2006
Trader Rating: 0
I'm not sure what you mean? It's a laser cutting and engraving unit. I can cut for example a ribs and write the info of that rib on it, such as W3 for rib 3, If that is your question.
Jean
Old Sep 24, 2012, 10:50 AM
johnbyrne is offline
Find More Posts by johnbyrne
Trader Rating: 90
Often wrong ("wife")
johnbyrne's Avatar
Deep in the South
Joined Sep 2003
Trader Rating: 90
I assume you can work with CAD files. What would you need, DXF, DWG, other?
Also, do you know yet if you will charge by the inch or hour or ?
Thanks in advance
John
johnbyrne is offline Find More Posts by johnbyrne
Old Oct 05, 2012, 07:55 PM
Trader Rating: 0
worldraft's Avatar
Joined Sep 2006
Trader Rating: 0
Hi Johnbyrne, DXF is the language my laser uses, so you can use Acad to do the drawing DWG then convert it to DXF, or you can draw directly in DXF. One is as easy as the other.
Old Oct 05, 2012, 07:59 PM
Trader Rating: 0
worldraft's Avatar
Joined Sep 2006
Trader Rating: 0
I'm in the process of drawing two aircraft, the P40E and The P51D in 1/4 scale. When the plans are ready They will be for sale as a kit or the plans only. However this is not for an other year or so.
Discussion Laser Cutters bigdad1975 The Builders Workshop 13 May 08, 2014 09:06 AM
How much does a laser cutter cost? totalboss Electric Plane Talk 30 Feb 14, 2012 11:57 PM
Discussion Die cutter/laser cutter? Tram The Builders Workshop 7 Apr 08, 2008 07:22 PM
My neighbor has a CNC mill and a Laser Cutter!!! JStory Electric Heli Talk 1 Dec 01, 2001 06:42 PM
Did you get your laser cutter Doug? Scomis Parkflyers 3 Nov 07, 2001 04:02 PM
