Old Sep 20, 2012, 08:59 AM
Mr_McGlue is offline
Find More Posts by Mr_McGlue
Mr_McGlue's Avatar
United States, CA, Long Beach
Joined Sep 2011
Build Log
#12 Model Airplane Building Clinic >> Pat Trittle's Fleet Model 2 <<
Starting on Pat Trittle's Fleet Model 2 today. I bought the plans and short kit probably 6 months ago and has been sitting around collecting dust
The specs:
42" wingspan
32" length
470 Sq. In combined wing area
E-flite 400
So Murocflyer started a thread about doing a build clinic. Thought what a better time to get started on it. I've been in the middle of helping my son build his cub from a kit and we got to the point of being able to work on it without needing a building board.
For info on what we are doing look here:
http://www.rcgroups.com/forums/showthread.php?t=1704076
Attached my two color schemes I'm going to pick from. If I go with the orange and black one I may alter the fin (vertical stab) to match.
Robert
Mr_McGlue is offline Find More Posts by Mr_McGlue
Old Sep 29, 2012, 04:10 PM
Mr_McGlue's Avatar
Joined Sep 2011
Got the workshop/office straightened up so I can make it a mess again. Went and got the plans copied so I can cut them out for my building board.
So my first plane I did was a scratch built from plans. I can see already that this will be a lot different. Will be stripping a lot of sticks for sure.
Robert
Old Sep 29, 2012, 05:45 PM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
The kit does not come with the sticks? Interesting.
Good luck on your build and following along.
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Sep 29, 2012, 06:59 PM
Mr_McGlue's Avatar
Joined Sep 2011
Nope no sticks. Just a short kit. Not that big of a deal as I can whip out sticks in no time. I had already ordered the extra balsa when I got the kit too so somewhat prepared
This is going to be a light plane though I can tell already. Think it will be a fun build.
Robert
Old Sep 29, 2012, 09:46 PM
Mr_McGlue's Avatar
Joined Sep 2011
A question. The leading edge of the stab uses two 1/16 x 1/8 balsa strips laminated together. How do I get that curve with the strips? Tried putting in water but didn't work that well.
Robert
Old Sep 30, 2012, 09:02 AM
Mr_McGlue's Avatar
Joined Sep 2011
Found an article on Pat's website and seen others do it the same way so will try this later today.
http://www.patscustom-models.com/bowedoutlinres.html
I think I just didn't soak it long enough in the water.
Robert
Old Sep 30, 2012, 11:57 AM
loNslo is offline
Find More Posts by loNslo
wood is good
loNslo's Avatar
United States, CA, Marina Del Rey
Joined Jun 2012
Also I've heard that adding ammonia to water or using Windex aids bending.
loNslo is offline Find More Posts by loNslo
Old Sep 30, 2012, 03:41 PM
Murocflyer's Avatar
Joined Nov 2005
I heard that soaking the side with ammonia and water opposite of the bend direction help "push" the wood to curve.
Frank
Old Sep 30, 2012, 03:54 PM
Mr_McGlue's Avatar
Joined Sep 2011
Well tried the water soaking for 20 minutes. One side almost looks like it might work. The other side broke a little. Trying again and soaking for an hour this time.
Robert
Old Sep 30, 2012, 03:58 PM
loNslo is offline
wood is good
loNslo's Avatar
Joined Jun 2012
Robert
It sounds like the laminations are too thick for the bend radius. Have you tried boiling water?
Old Sep 30, 2012, 04:01 PM
Mr_McGlue's Avatar
Joined Sep 2011
Good idea got one soaking right now will add some to it.
Old Sep 30, 2012, 05:22 PM
WAGliderGuy is offline
Find More Posts by WAGliderGuy
Airliner Builder
WAGliderGuy's Avatar
United States, WA, Seattle
Joined Feb 2010
Looking good! I plan to do a bi-plane this winter so I am watching with interest. I am in the middle of finishing my 4th Tritle kit, his Pilatus Porter
Pat has some great tutorials on his site including bending balsa sticks - http://patscustom-models.com/buildintips.html
Ethan
WAGliderGuy is offline Find More Posts by WAGliderGuy
Old Sep 30, 2012, 09:22 PM
Mr_McGlue's Avatar
Joined Sep 2011
Thanks for watching me up haha.
So finally think I got it. I was doing everything correctly but the wood kept breaking. I went and looked if I had another sheet of 1/8 balsa and did. It was a lot softer than the one I was using. That stuff worked almost perfect.
Pretty frustrating but only because I haven't done it this way before. So I'm thankful that I learned something without cussing....too much
Robert
Old Sep 30, 2012, 09:25 PM
Murocflyer's Avatar
Joined Nov 2005
Haha, no worries Robert, we've all been there. That's the good thing about it (we know how you feel) and thanks for sharing your photos.
Frank
Cool Model Airplane Building Clinic ~ Building A Kit Murocflyer Parkflyers 484 Mar 14, 2013 02:37 PM
Mini-HowTo Model Airplane Building Clinic #2 ~ Building From Plans >> Begins TBD. All Welcome Murocflyer Balsa Builders 79 Dec 12, 2012 09:58 AM
Build Log #1 Model Airplane Building Clinic >> Mountain Models/Laser Arts Switchback<< Murocflyer Balsa Builders 21 Nov 26, 2012 07:41 PM
Build Log #6 Model Airplane Building Clinic >> Mountain Models Lucky ACE << glazzies Balsa Builders 61 Oct 30, 2012 09:20 PM
Cool Balsa Model Airplane Building Clinic Murocflyer Beginner Training Area (Aircraft-Electric) 12 Sep 12, 2012 02:01 AM
