Old Sep 20, 2012, 04:50 AM
mummi is offline
Find More Posts by mummi
Iceland, Capital Region, Reykjavik
Joined May 2012
continuous rotation servo's
I wanted to try out some robotics and need a continuous rotation servo. I found http://rctimer.com/index.php?gOo=goo...8&productname= these for quite the price Can I modify these for continuous rotation or should I look for something else?
mummi is offline Find More Posts by mummi
Old Sep 20, 2012, 09:16 PM
kegresse is offline
Find More Posts by kegresse
SF, CA
Joined Apr 2006
Hi,
Hitec HSR-1425CR Continous Rotation Dual Robotic Servo 1425CR/1425
It costs around $17. Standard servo size.
I got two of them. They work well; with enough
torque. I might get the 180 degree one too.
Good luck! Kegresse
kegresse is offline Find More Posts by kegresse
Old Sep 21, 2012, 04:46 AM
mummi is offline
Joined May 2012
Originally Posted by kegresse View Post
Hi,
Good luck! Kegresse
Thanks for the tip, I went with the http://rctimer.com/index.php?gOo=goo...2&productname= for my first projects
Old Oct 18, 2012, 02:05 AM
HotAir2 is offline
Find More Posts by HotAir2
Neal
Christchurch, NZ
Joined Nov 2004
I modified a Futaba S3001 in about 2 minutes by removing the plastic connector between the pot and the bottom gear, then trimmed off the lug on the top one.
It works perfectly when plugged into my receiver. Move the sticks one way, it spins round and round, move the other way and it spins the opposite direction. So far so good.
But when I just put power to the black and red leads, it gives a tiny pluse, but doesn't go round and round. I guess that's because the signal to turn comes down the white wire, but I don't want to control it that way, just one way, then the other on a plain old switch. What should I do?
Thanks, Neal
HotAir2 is offline Find More Posts by HotAir2
Link Continuous Rotation Modification Difficulty List (very helpful!) ServoCity ServoCity.com 0 May 10, 2012 09:36 AM
Discussion New 360 deg continuous rotation turret for Wild Thumper zoom99 FPV Talk 5 May 02, 2012 07:33 AM
For Sale continuous rotating servos (2) reduced $15shipped futabafreak Aircraft - General - Radio Equipment (FS/W) 2 Jul 31, 2009 03:43 PM
Question GWS Micro MG BB Servo and Continuous Rotation David Hjelle GWS (Grand Wing Servo) 8 Sep 03, 2008 08:02 PM
GWS servo modified for continuous rotation pkk GWS (Grand Wing Servo) 3 Oct 26, 2003 01:15 AM
