Old Sep 20, 2012, 04:18 AM
AzTrekie is offline
Find More Posts by AzTrekie
Doing Projects Differently
AzTrekie's Avatar
Joined Jan 2012
Question
felling my creation doesnt have enough power
After finish building my Enterprise-A (acording to all my data it should fly with a 4 to 1 thrust ratio ) but with my design may or may not float in the air, question has any one ever put a kit wing above an air craft to test out how the motors will have the will efect it in the air
Personal note
( I think I may have to much drag and not enough lift most likly need nore power to make it work with out the extra kite delta wing)
Should I just try it with out the extra wing or should I put on the kite wing to get it air born
PS I want so much this to be airborn but have limited amount of funds
Dave
AzTrekie is offline Find More Posts by AzTrekie
Old Sep 20, 2012, 11:58 AM
djacob7 is offline
Find More Posts by djacob7
Zen in the art of foam
djacob7's Avatar
United States, CA, Fremont
Joined Jan 2009
A picture or two might help.
djacob7 is offline Find More Posts by djacob7
Old Sep 20, 2012, 05:57 PM
AzTrekie is offline
AzTrekie's Avatar
Joined Jan 2012
request for picyure to ilistrate the idea
Kind of like an ultra lite
simulare to the picture below with the kite wing above and attached to the Enterprise- A
if any more questions please ask or any and all comments are apreciated
Thanks again Dave
Old Sep 21, 2012, 12:27 AM
djacob7 is offline
djacob7's Avatar
Joined Jan 2009
Do you mean by 4 to 1 thrust ratio that you have 4 times more thrust than the weight of the plane? If so, drag should not be a problem at all. 4 to 1 is highly unusual; usually a 1 to 1 ratio is more than enough.
Discussion Help my Hyperion lipo balance plug doesnt fit my Imex charger seeingeyegod Batteries and Chargers 11 Nov 07, 2013 10:07 PM
Help! I have a Wookong issue with my DX8 and AR8000, not enough channels for everything jasper7821 Multirotor Talk 18 May 10, 2012 10:59 PM
Discussion my syma 110g doesnt fly straight!!! adam.champ Coaxial Helicopters 2 Apr 22, 2012 10:31 AM
Discussion My Belt CP doesnt generate enough pitch to lift!? metalnwood Electric Heli Talk 12 May 05, 2009 01:56 AM
Discussion PC power supply - Does this have enough power? Sherlock Batteries and Chargers 42 Feb 23, 2007 05:30 PM
