Old Sep 20, 2012, 02:13 AM
RC_Fishy is offline
Find More Posts by RC_Fishy
RC_Fishy's Avatar
United States, MA, Boston
Joined Jul 2012
So this is what happened after running 5 tanks in a row for the break-in
So I got a little carried away when I was breaking in my new nitro HPI RS4 Drift. The manual said 1 tank idle and 2 more tanks running a laps or something like that. Anyways I just got a little carried away and ran more tanks after that without much of a break. Then this started to happen
-I notice one wheel starts acting funny...
-Then suddenly the car started to full throttle on it's own non-stop
-Pull string becomes IMPOSSIBLE to pull
Well I took apart the front wheels to find that there is actually a bearing missing from that side... I don't think it could come out while driving... I also think this has nothing to do with running the car a lot, but is there any explanation for this? I'm pretty sure it's a missing bearing or else they totally didn't put one in the left side.
Then I took out the glow plug to and try to unflood the engine, but it still wouldn't budge.
I took apart the motor, removed the heatsink and the pullstring. The pullstring mechanism was totally fine, and then I see the piston and bits of metal inside the actual engine...
Looks like it was keeping the piston from moving up and down. Then I took out the piston itself and found this:
http://i48.tinypic.com/2lctt0j.png
Yup. I think running 5 tanks in a row is what cause this. Lesson learned. Time to pick up a new engine.
I'd like to know more about that wheel that is wobbly due to the missing bearing if anyone has any ideas on that...
Questions? Comments? I'd love to hear them!
Thanks!
RC_Fishy is offline Find More Posts by RC_Fishy
Old Sep 20, 2012, 09:00 AM
DG40 is offline
Find More Posts by DG40
Sam Adams Fan
DG40's Avatar
USA, PA, Honesdale
Joined May 2008
5 tanks in a row won't do that. even if you ran a bit hard with out heat cycles it should only loose compression and wear out too soon, not explode.
call warranty support and explain your issue.
DG40 is offline Find More Posts by DG40
Old Sep 20, 2012, 09:37 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Where exactly is the bearing missing on the wheel? The bearings aren't in the wheels on this car, they're in the hubs.
wparsons is offline Find More Posts by wparsons
Old Sep 20, 2012, 03:51 PM
Marty7n is offline
Find More Posts by Marty7n
retrocopter
Marty7n's Avatar
Ireland, Dublin, Dublin City
Joined Jul 2011
That definetly should not have happend after five tanks of fuel,i would ring customer service and state what happend,maybe you might even get a replacement engine!
Marty7n is offline Find More Posts by Marty7n
Old Sep 21, 2012, 12:00 AM
RC_Fishy is offline
RC_Fishy's Avatar
Joined Jul 2012
You would consider the piston basically eating itself inside the motor exploding? I learned what happened when looking inside the motor more;
The pieces of the thing that holds the piston melted obviously, but those pieces blocked the throttle servo from going back to break/idle so it stayed open and just kept at full throttle until I somehow stopped it. That was pretty much the last straw for the engine.
I've posted this in other places and people have said that 5 tanks in a row in a brand new engine is understandable... I'm not the expert though! I don't think I want to tell HPI that I pretty much went on a 5 tank non-stop binge for the break-in.
Old Sep 21, 2012, 12:02 AM
RC_Fishy is offline
RC_Fishy's Avatar
Joined Jul 2012
I'm hoping they can just put everything back up for me as well. Taking that thing apart was a nightmare and I tried putting an OS engine in that I borrowed from a friend, and trying to put that in was a horrible experience and didn't even work.
I just want a working nitro! I hope they can do everything without charging too much...
Old Sep 21, 2012, 12:03 AM
RC_Fishy is offline
RC_Fishy's Avatar
Joined Jul 2012
Yep. They are in the hubs, that's what I meant. I took a look inside, and honest to god one bearing WAS missing. HPI said they will send over the missing bearing.
Old Sep 21, 2012, 06:32 PM
jombo is offline
Find More Posts by jombo
Bad News Everyone
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
That's a tough one , it could happen , especially running too rich. It would diesel or misfire if run too hot and explode the motor.
The way to break in a motor is to run a half tank , shut it down , piston at the bottom. Let it cool. Then start the rest of the tank while leaning it out. Do it like this and you won't have another problem . Never lean it out more than the recommended turns on the motor.
The real best way is to take the motor apart first , remove all the metal filings , then wash it nitro fuel . You will be amazed at all the bits you will find in there. Get some associate green slime and coat all the rubber gaskets with it . This stuff will seal any air leaks and will lube the seals. Set all the needles as per running the engine then give them a half more turn open for breakin.
Then you should be good to go.
jombo is offline Find More Posts by jombo
Old Sep 21, 2012, 06:47 PM
jombo is offline
Bad News Everyone
jombo's Avatar
Joined Dec 2007
Nitro tuning
Nitro RC Engine Tuning 2 (useing a HPI- Savage 25) (3 min 5 sec)
Nitro RC Engine Tuning 1 (useing a HPI-Racing Savage 25) (4 min 47 sec)
Old Sep 30, 2012, 09:08 PM
RC_Fishy is offline
RC_Fishy's Avatar
Joined Jul 2012
Great pro tips there! Thanks a lot!
Old Oct 01, 2012, 09:32 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Just a little correction... glow/nitro engines run just like diesels do, there's no timing of when they fire (like a spark engine has), they just compress under heat (glow plug) until it explodes, so I'm not sure what you mean by "it would diesel or misfire"?
I don't see how running too rich would break the piston like this, in a 2 stroke engine more fuel = more oil, so it's not like a full scale engine (not mixed fuel) where running too rich will wash the oil off the cylinder walls and lead to damage. I would bet on running too lean causing damage like that long before running too rich.
Old Oct 04, 2012, 05:52 PM
jombo is offline
Bad News Everyone
jombo's Avatar
Joined Dec 2007
nope i got it right .
if run too rich , it will hydraulic the piston and put too much pressure on the pin and shaft. if run to lean it will predetonate the fuel early and blow the piston to kingdom come . it needs to be just right
Old Oct 04, 2012, 06:12 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
^^ You said it would diesel, which is totally different than hydrolocking.
I've never seen a glow engine run so rich that it hydrolocks, usually they will stall long before there's that much fuel in the cylinder. The only time I've seen damage from too much fuel is if it's flooded during start up.
Old Oct 04, 2012, 08:26 PM
jombo is offline
Bad News Everyone
jombo's Avatar
Joined Dec 2007
i have.
yes , when i say deiseling it means it sounds like a deisel engine , hence running too rich . what happens is it will spirt out oil and unburnt fuel , then it will hydro lock and blow its self apart.
Old Oct 06, 2012, 04:31 AM
Brutus1967 is online now
Find More Posts by Brutus1967
life without risk isn't living
The Netherlands
Joined Nov 2009
i have.
Nope, it will not.... Combustible fuel/air ratio will be typically something like 1:10 by weight, which by volume (fuel in liquid state) would be very roughly in the area of 1:100.... that is NOWHERE NEAR the amount of liquid needed to cause hydraulic lock. Not even if you take down that figure to let's say, 1:50 due the oil content and an extreme rich mixture.
You will also never get the engine running rich enough to have it spit out fuel in liquid form. The fuel will have evaporated before it exits the exhaust port.
The exiting gasses will also blow out the excess oil that might have collected in the combustion space every cycle again.
Although it is true, that running too rich will cause a higher compression ratio due to more oil present in the combustion space, even that, is nowhere near enough to cause hydraulic lock.
What caused the damage to your engine? No idea, but not hydrolock.
Brgds, Bert
Brutus1967 is online now Find More Posts by Brutus1967
Question Hypothetical question - what happens if you run an EDF with the duct removed? LMF5000 Power Systems 9 Apr 18, 2014 03:38 PM
Discussion What Happened in Boston on this Day in 1974? LcJ Life, The Universe, and Politics 32 Sep 13, 2012 07:51 PM
Discussion Getting back into the hobby after a 6 year break. What has changed? aspencer80 Electric Plane Talk 5 May 05, 2012 09:21 PM
Sold ASP 1.80 - flown once after two tanks for breaking in. Fidelity101 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 16, 2012 01:53 PM
Discussion after-run oil for break in WBFlyer Engines 7 May 22, 2008 11:05 PM
