Old Sep 19, 2012, 11:11 PM
shurley02 is offline
Find More Posts by shurley02
shurley
Joined Dec 2010
How to add working bombs to your scratch built foamie plane.
Hey guys and gals,
I created this little tutorial on how I added working bombs to my RC Powers F18. I thought I would share my experience here as well, it may help you come up with your own ideas for a bomb system on your plane. I hope you can make use of it. Good Luck!
Adding bombs to your RC Powers F-18v2 (4 min 46 sec)
shurley02 is offline Find More Posts by shurley02
Old Sep 23, 2012, 08:39 AM
metasim is offline
Find More Posts by metasim
metasim's Avatar
USA, VA, Charlottesville
Joined Apr 2010
Brilliant
Design simplicity is superb. This is going to end up a "standard" in warbirds. Thanks for sharing.
Didn't quite catch it in the video.... Are you using channel mixing to map the two switches to one servo?
metasim is offline Find More Posts by metasim
Old Sep 23, 2012, 09:53 AM
Razors edge 29 is online now
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Very nicely don Sir!
Razors edge 29 is online now Find More Posts by Razors edge 29
Old Sep 23, 2012, 02:41 PM
maurice076 is offline
Find More Posts by maurice076
maurice076's Avatar
United States, MI, Warren
Joined Aug 2011
Thanks for sharing with us,I'll have to try that .Seems you could use a very small servo also so little weight.
maurice076 is offline Find More Posts by maurice076
Old Sep 23, 2012, 05:03 PM
Modarius is online now
Find More Posts by Modarius
"Watch out for...CRUNCH!!
United States, CA, Sacramento
Joined Jul 2008
It sounds like he is using a three position gear channel to switch it. Middle position is neutral on the servos and each of the end positions drops one bomb, if that makes sense. One channel to drop two bombs.
Modarius is online now Find More Posts by Modarius
Old Sep 26, 2012, 10:04 PM
shurley
Joined Dec 2010
Sorry, I miss spoke in the video. I am using two switchs, the trainer and the gear. I have setup the mix so that if I flip the gear switch and do not return the switch, the trainer switch will send the servo full the other direction reguardless. I'm using the er9x software and the mix on my channel is:
100% FULL !TRN
and
+- 100% FULL !GEA f>0
This is so that I can have two bombing runs in one flight. I was going to use the three position switch, but opted for the trainer/gear mix. I also considered a two arm servo and dropping both, but I like having two runs in one flight. If you use this system in your plane, please send me some pix, I would love to see if you were able to make any improvements. I CHALLENGE someone to drop 4 bombs at a time!
Old Sep 26, 2012, 10:10 PM
shurley
Joined Dec 2010
ALSO, I need to come up with some tissue paper bombs filled with cake flower! This was the original reason for the bomb system. I couldn't see flower bombs working with the rubberband/servo arm systems I have seen in other videos. Just need to figure out how to hang them on the pin system and keep them from tearing in flight!
Help! Scratch built foamy Seaplane or Float plane plans SenLar Foamies (Scratchbuilt) 5 Aug 04, 2012 06:23 AM
Discussion How many channels do I need for a scratch built foamie? SensusVitae42 Foamies (Scratchbuilt) 24 Apr 27, 2012 06:05 PM
Gallery Aerial Video of a fellow fliers scratch built 3D foamy! Adidas4275 3D Foamies 6 Apr 18, 2012 12:36 AM
Gallery Video of Scratch Built 3D Foamy in flight Adidas4275 Aerial Photography 0 Apr 16, 2012 11:26 AM
Discussion Whats your favorite scratch built foamie? NighthawkF-117 Foamies (Scratchbuilt) 14 Sep 07, 2011 03:19 AM
