United States, OR, Corvallis
Joined Jan 2010
Sig "Tiger" rubber powered plane build
Hey, Just so everyone knows, I come from a build-it-yourself woody RC glider background, and have recently started building this rubber powered Sig Tiger.
So, since I don't know "that" much about free flight sorta things (but I've done some reading here and there), any input is totally welcome. The whole micro-adjustments of warping wings, washout, tailsurfaces, etc on chuck gliders is really interesting and I assume applies similarly with these sort of planes also???? I'm thinking of next getting a Sig "Mini-Maxer", anyone have any thoughts on that plane? It looks cool and looks like a better flier(more aerodynamic and the way I think of cleaner designs coming from a glider background). So far I'm using yellow alphatic resin wood glue, T-pins, waxed paper and enjoying the Lo-Techiness of this. Here's what I have going so far: Adios - Paul
Hi Paul,
A suggestion: The Willamette club has a contest at the end of Sept. One of the events is called the "Runt". It's a one design sort of like your Sig Tiger. Why not build one and join the fun. Here's the plan link and also a link to the club. http://willamettemodelersclub.weebly...lan-files.html BTW - I wouldn't shellac your plane. Go over to Trump's and get some nitrate dope and thinner. - Norm |
Joined Jan 2010
More stuff.....and thanks for the input.....
Hey Bruce- Thanks for the input and glad to meet you in person at the last freeflight thing. I did read and print out what you posted about trimming freeflight rubber powered planes so, thanks for that info. I'll have to try what you posted here also as I'm used to doing things sorta like that such as building "washout" into my RC glider wings.
Sam- Yes, old habits die hard, you should see how overbuilt my first 2 RC gliders are, I've tamed it down some on gliders #3 and #4. You're probably correct, but all the additions I'm making are for compression loads, I figured the tissue shrinkage and dope would provide plenty of tension "snugging things up". Good to know about the Sig "Mini-Maxer". Norm- I'll probably go get some dope at Trumps since that's what it's made for. I'm mostly curious about trying thinned Shellac since I have plenty of it and denatured alcahol to thin it and clean brushes with. I hope to make it to the next Willamette Modelers event, but I'll be gone for a week and won't have time to make another plane. I plan on sitting this season out and just checking out other people's stuff and posting pictures. I'll check out those plans you posted the link to. Adios- Paul
For a model of this size it's common simply to put the rubber right onto the nose block hook. Now if you want to wind using a blast tube then that's a whole other enchilada.
In that case there are a few options. A common way to go is to buy the smaller sizes of Crocket hooks as sold by FAI Model Supplies; http://domino-35.prominic.net/A55C2D...257743000749DA Or there if you're handy with working metal and have the tools then some nice ends can be made by drilling a few holes in a strip of aluminium and then cut and file and finally polish your own. I've even seen some made up from music wire where a figure 8 was made up with a small and large end. OK, I made up a sketch of some hooks similar to some I made a bunch of years back. I started a new thread for it so you can find the drawing there. |
JKinTX, if you practice what you preach you'll end up with some decent enough casual sport models but you won't get good rubber model performance in smaller sizes or for contest models. Models such as PNut scale rely on a lightly built weight to even fly at all, let alone turn in winning contest performances.
I guess it comes down to opinion and each to their own but most of us would agree that the stock Tiger wing is built more than adequitely strong enough for the sort of flight and even harder landing loads that it will experience. |
Gold Coast Australia.
Joined Jan 2005
Joined Jan 2010
Sig Tiger Pictures!!!
Hey, Thanks for posting the pictures of your completed Sig "Tigers"!
Any and all other pictures are always welcome. Good to know about it's flying capability too. After looking at the trusses I added to add strength to the rubber band anchor in the tail of the fusalage, the diagonal trusses (per plans) farther back in the tail seem really redundant so I'm probably going to remove those to lessen some tail weight. The wing is not made to come off per plans, but since I ride my bike to fly RC gliders and model rockets, everything I build is dis-assembly oriented. So, I'll likely re-use the above mentioned (per plans) trusses that I remove from the tail and use them in wing-mount area to make a removable wing so I can take this plane to the park in a box in/on my backpack as I ride my bike to and fro. I've never built a plane completely per plans yet so I'll just keep on with that trajectory. One of the guys at the local hobby shop thinks it's a genetic condition of some sort. Adios - Paul |
| Thread Tools | |
| Question stick and tissue rubber powered plane to build w/ my 7 year old | whichwaysup | Free Flight | 25 | Sep 05, 2012 10:47 AM |
| Discussion New Hobbyking free flight rubber powered planes. | Tartago | Indoor and Micro Models | 4 | Jun 22, 2012 02:25 PM |
| Help! Dihedral of rubber powered plane | joyalflyer | Free Flight | 11 | Apr 18, 2012 11:21 PM |
| Question Problem with building a good rubber powered plane... | catman529 | Free Flight | 6 | Oct 09, 2009 11:03 PM |
| Discussion Looking for a rubber band powered plane building kit | afterwop | The Builders Workshop | 13 | Jun 17, 2008 10:16 AM |
