Old Sep 19, 2012, 07:42 PM
T.B. is offline
Find More Posts by T.B.
gram obsessive
United States, AZ, Tucson
Joined Mar 2005
Question
How to charge LiFe transmitter batteries?
I bought 3 of these LiFe 1500 transmitter batteries for my older HiTec (72mHZ) Transmitters because the voltage is nearer the voltage of NiCad's.
http://www.hobbyking.com/hobbyking/s...dProduct=17955
I Emailed Hobby King to get their recommendation for the right charger for those LiFe batteries. They recommended, and I bought this;
http://www.hobbyking.com/hobbyking/s...idProduct=7028
Like most HK products the charger has no instructions.
I cannot find a LiFe setting in the menu.
Any suggestions would be appreciated.
T.B.
T.B. is offline Find More Posts by T.B.
Old Sep 19, 2012, 08:24 PM
Wintr is offline
Find More Posts by Wintr
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
When you go to the setup menu with the type button, you can select the lithium battery voltage; as you do, it changes from LiPo to LiFe, and any other lithium type supported. Once the lithium voltage type is selected, that type is the only one chargeable when you use the type button to go to lithium charge. To return to LiPo, you have to go back to the setup menu, and change the voltage again.
Wintr is offline Find More Posts by Wintr
Old Sep 19, 2012, 08:48 PM
T.B. is offline
gram obsessive
Joined Mar 2005
There is nothing in my menu that says LiFe.
The only voltage choices are multiples of 3.7.
That's all I get.
Old Sep 19, 2012, 08:53 PM
Wintr is offline
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
That would be in the lithium battery charge menu. You have to use the setup menu to change the voltage option for lithium batteries. If it works like most, pressing the type button runs through a series of menus, including setup. You use the enter button to enter the setup function, and advance through the various options.
Old Sep 19, 2012, 09:01 PM
T.B. is offline
gram obsessive
Joined Mar 2005
Yes, and the voltage choices are 3.6, 7.2, 10.8, 14.4, 18.0, 21.6. No option for 3.3, 6.6 and 9.9 for LiFe.
Old Sep 19, 2012, 09:10 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Press Stop till it says User Set Program, press Enter. Press Enter again, press right or left to select life 3.3v.
grimbeaver is offline Find More Posts by grimbeaver
Old Sep 19, 2012, 09:15 PM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Or charge it as a Pb (lead acid).
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Sep 19, 2012, 09:26 PM
Mikecam is offline
Find More Posts by Mikecam
Mikecam's Avatar
Canada, MB, Winnipeg
Joined Apr 2008
grimbeaver has it.
http://www.hobbyking.com/hobbyking/s...ual%282%29.pdf
Check the flow chart.
Mikecam is offline Find More Posts by Mikecam
Old Sep 19, 2012, 09:29 PM
T.B. is offline
gram obsessive
Joined Mar 2005
Grimbeaver,
OK that worked, thank you.
So, I got it on 9.9V at 1.5A and pressed enter. It was OK for a few seconds and then beeped and now it reads BATTERY VOL ERR CELL CONNECT
What's that?
T.B.
Old Sep 19, 2012, 09:31 PM
T.B. is offline
gram obsessive
Joined Mar 2005
OK I may have answered my own question. I plugged in the balance connector, and it seems to be working.
Thanks all.
Old Sep 19, 2012, 09:34 PM
United States, MN
Joined Feb 2011
Thanks all.
If you are in balance charge mode the balance connector must be connected. Really you should always connect it even if doing a normal charge because it monitors the cells to prevent over charging.
Old Sep 19, 2012, 10:09 PM
T.B. is offline
gram obsessive
Joined Mar 2005
Thanks, I'll do that.
Old Sep 20, 2012, 11:17 AM
Ducati-Rider is offline
Find More Posts by Ducati-Rider
Arroyo Grande, CA
Joined Dec 2004
Cell Pro 4 for LiFe
Can you charge LiFe batteries on a123?
That's all I have besides LIPO
Ducati-Rider is offline Find More Posts by Ducati-Rider
Old Sep 20, 2012, 11:31 AM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
Absolutely. LiFe / A123 are same CV termination voltage.
Mark
mrforsyth is offline Find More Posts by mrforsyth
Question Charging a LiFe battery with a LiPo charger?? AcroFPV Batteries and Chargers 22 May 22, 2016 12:08 AM
Discussion Charging Life batteries wjb Batteries and Chargers 3 Aug 07, 2012 09:07 AM
Discussion charging Zippy life batteries wjb Batteries and Chargers 0 Aug 05, 2012 09:43 AM
Discussion Charging LiFe Batteries Eoghan FMA Direct 2 Aug 03, 2012 12:16 PM
Question Does charging a battery at a higher rate shorten it's life? astronaut Batteries and Chargers 20 Jun 27, 2012 09:16 AM
