Espritmodel.com Heli Air
Old Sep 27, 2012, 04:41 PM
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
Originally Posted by vinnieg View Post
I'll buy some 34 AWG wire and try to get 12-14 turns with a single strand. I don't think I want to mess with anything smaller than that. -vinnie
I have rewound a couple of 3gram motors and I got 14 and 16 turns of 32awg on them. You should be able to get more turns than me with a 5gram motor.
I R Irv is offline Find More Posts by I R Irv
Old Sep 27, 2012, 09:43 PM
vinnieg's Avatar
United States, NJ, Fort Lee
Joined Feb 2012
wow! that looks amazing! maybe i should go for the 32 or 33 awg wire. I'll be happy to get 12 or 13 turns with it on a second rewind. I just don't want to mess with really fragile wire. It was frustrating enough with the 30 awg when the wire snaped on the last tooth of a phase. Anyway, I'm going to hold off on that until I test out my 1 cell setup on the 5 gram.
What plane did you power up with that motor ? running on 1S I assume.
vinnieg is online now Find More Posts by vinnieg
Old Sep 28, 2012, 06:13 AM
I R Irv's Avatar
Joined Nov 2008
. What plane did you power up with that motor ? running on 1S I assume.
Vapor on 1-cell, Ember on 2-cell and scratch-builds. I'd be happy to send you some 32awg just PM me your addy.
TODD
Old Sep 28, 2012, 06:47 AM
vinnieg's Avatar
Joined Feb 2012
Thanks for offer! PM sent!
Old Sep 29, 2012, 02:19 PM
Joined Jun 2009
Did anybody measure the original windings resistance (as it came from the manufacturer) ?
I'm asking because I'm getting weird values on mine: 0.3, 0.7, 1.2 Ohm (see this thread for details).
flylowfast is offline Find More Posts by flylowfast
Old Oct 01, 2012, 03:58 PM
vinnieg's Avatar
Joined Feb 2012
I did measure the resistance but I don't remember the numbers. I know I did not get consistent readings. I will measure again on my rewound motor and post what I find.
Old Oct 01, 2012, 04:27 PM
Jack
USA, ME, Ellsworth
Joined May 2008
If you are measuring like 1 to2, 1 to 3, and 2 to 3 on the motor connectors, they should all read the same. I set my DMM to Rx1 and touch the probes together, I usually see about 0.3-0.4 Ohms on the leads. Then when I check the connectors I see like 0.5 or 0.6 Ohms or so. It takes a couple of seconds for it to fall and statilize.
The readings are not right, you would need a milliOhm meter (another not really needed expensive toy for me!) to read the actual resistance on each phase.
I usually check end to end before I terminate the windings and again afterwards and get slightly different but stable and similar readings.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Oct 03, 2012, 01:29 PM
Joined Jun 2009
Did you get a chance to measure the windings resistance ?
Old Oct 03, 2012, 01:53 PM
vinnieg's Avatar
Joined Feb 2012
not yet.. will try it tonight.
Old Oct 03, 2012, 06:07 PM
vinnieg's Avatar
Joined Feb 2012
measured resistance : 1.6, 1.6, and 1.7.
The resistance of the measuring device was 1.1. So the actually resistance was .5 , .5 and .6
This was my rewound motor with 30 gauge wire with 6 turns.
Old Oct 03, 2012, 06:17 PM
Jack
USA, ME, Ellsworth
Joined May 2008
So those readings are OK then. Looks like you have us stumped!
Jack
Old Oct 10, 2012, 09:13 PM
vinnieg's Avatar
Joined Feb 2012
I just got the 1S esc from HK. The motor runs pretty well with a gws 3x2 prop. Can't wait to slap this on a micro plane!
Rewound 5 gram motor (2 min 17 sec)
Old Oct 16, 2012, 08:42 AM
vinnieg's Avatar
Joined Feb 2012
Hey Todd,
I started rewinding the second 5 gram motor with the 32 gauge you sent. I was able to get 16 turns on 2 of the teeth so far.. 10 more to go...
Old Oct 16, 2012, 10:15 AM
lectroglide's Avatar
United States, WA, Puyallup
Joined Aug 2006
gotta ask what kinda model are ya using a 4x2 prop on? BTW that little bugger really winds up
lectroglide is offline Find More Posts by lectroglide
Old Oct 16, 2012, 10:46 AM
vinnieg's Avatar
Joined Feb 2012
On the first rewound 5 gram, I wanted to use a 4x2 prop with a 1S battery but the motor would stutter on startup. I tried changing the ESC timing but it didn’t help. With a 3x2 prop the stuttering was greatly reduced. So for my first flight I have made a scaled down 15” cheap and easy RET foamie. The AUW is 50 grams. I haven’t had a chance to maiden it yet due to the weather.
BTW that little bugger really winds up.
The funny thing is in the video I had the prop on backwards. It has some decent power for a 3x2 on 1S. (don't have a thrust stand to measure though)
Sold Himax HB2815 2000 KV in runner motor QuietRCFly Aircraft - Electric - Power Systems (FS/W) 1 Oct 01, 2012 09:27 AM
Discussion hexTronik 5gram rewinding to higher kv renatoa Indoor and Micro Models 25 Sep 15, 2012 07:50 AM
For Sale Hextronik 5gm. 1400-2000 Motors pflyer Aircraft - Electric - Power Systems (FS/W) 0 Aug 13, 2012 11:20 PM
Help! hexTronik 16gram motor rewind ? StewieRC Electric Motor Design and Construction 7 Jul 18, 2012 03:11 PM
Question 24g Hextronik 1700kv rewind dedStik Power Systems 1 Jul 06, 2012 04:20 PM
