Old Oct 20, 2012, 01:28 AM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Using a LiPO with BEC is fine except you are limited to the amps capability of the BEC. So you need to make sure you get the highest possible to avoid loss of control.
Personally I prefer NiMH packs, having flown many years in 80's 90's with the standard packs supplied with radios .... 500 - 600mAh 4.8v - I find todays packs of 2000 and more mAh to be more than enough for all my needs.
The other comforting factor is that know my 2300mAh NiMH packs can supply higher amps than the average BEC can when demanded.
For my big gas model - I use 2 NiMh packs of 2300mAh .... one for the Rx and servos, other for the ignition. I also have a 'battery backer' that takes a second 'emergency' pack so if first fails - automatically switches over to the second instantly without losing Rx .... that second pack is a very small light 280mAh NiMh pack ....
But each to their own ... I know my system is not everyones cup of tea ...
Nigel
solentlife is offline Find More Posts by solentlife
Old Oct 20, 2012, 09:33 AM
acdii is offline
Find More Posts by acdii
Garfield is my Pilot
acdii's Avatar
Joined May 2011
I like the LiFe packs for the RX, no BEC needed if you run high voltage servos. Still using a NiMH for the Ignition though, 4 cell 1800mah. Not all my planes run LiFe, only 2, the rest are using Venom 5 cell packs.
acdii is offline Find More Posts by acdii
Old Oct 20, 2012, 11:17 AM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Not true - any 6v servo will be fine. HV servos can take 8.4v an unregulated 2s LiPo battery.
Old Oct 20, 2012, 11:38 AM
Evan03 is offline
Find More Posts by Evan03
Mtn Home, Idaho
Joined Feb 2010
I'm running ds610s unregulated with a 2cell lipo
Evan03 is offline Find More Posts by Evan03
Old Oct 20, 2012, 05:10 PM
acdii is offline
acdii's Avatar
Joined May 2011
I meant anything above 4 volts as HV. Most servos today can take the 6.6, but older servos can't. I noticed a lot of servos that are rated at 6 volts being called high voltage.
Old Oct 20, 2012, 05:13 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
That is my point - servo's being called HV or high voltage are able to handle 8.4v NOT 6v or 6.6v.
The vast majority of standard servos (even old ones) can easily handle the 6.6v LiFe puts out but they are called standard not high voltage.
For Sale Thunder Power 5S, 3300mA, 65C LiPO...NEVER USED drice Aircraft - Electric - Batteries & Chargers (FS/W) 7 Jun 14, 2013 09:51 PM
Question Using LiPo for Rx FWCXC Batteries and Chargers 34 Sep 19, 2012 10:08 PM
Idea Using lipo charger to power laptop from 12 volt sammyc Batteries and Chargers 0 Apr 13, 2012 11:50 PM
Question Using 3 cell lipo to run RX directly (Nitro plane) maverick64 Fuel Plane Talk 17 Mar 16, 2012 08:47 PM
Discussion Question about using LiPO for Rx power RickAvery Power Systems 3 Nov 17, 2007 07:19 PM
