Old Sep 18, 2012, 07:14 PM
SohoR1 is offline
Find More Posts by SohoR1
United States, FL, Tampa
Joined May 2012
Using a lipo to power a RX
I'd like to power my RX with a lipo instead of a nimh for my nitro planes.
I've got a few planes varying in size from a GP Cherokee, a Big Stik 60, and a GP P-40 Warhawk. I'm just not sure what size battery I should be using, and the BEC or ESC/BEC combo.
Will this combination work?
http://www.hobbyking.com/hobbyking/s...dProduct=13925
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Thanks for your help!
SohoR1 is offline Find More Posts by SohoR1
Old Sep 19, 2012, 08:46 AM
rcshirt is offline
Find More Posts by rcshirt
miniture aircraft pilot
rcshirt's Avatar
Joined Oct 2007
a lipo and a bec will do the trick. just like a power box set up for 3d planes.
where do you fly?
rcshirt is offline Find More Posts by rcshirt
Old Sep 19, 2012, 09:01 AM
jymz is offline
Find More Posts by jymz
jymz's Avatar
Delaware, Ohio
Joined Nov 2006
Just use this and forget the BEC
jymz is offline Find More Posts by jymz
Old Sep 19, 2012, 10:20 AM
SohoR1 is offline
Joined May 2012
I fly at SparksRC in st petersburg, fl.
Does that battery have the correct connector to plug into my spektrum receivers?
Old Sep 19, 2012, 02:46 PM
rcshirt is offline
rcshirt's Avatar
Joined Oct 2007
it says it has a jr adaptor. so it will fit a spektrum. just make sure the servos can take that voltage.
Old Sep 19, 2012, 02:56 PM
SohoR1 is offline
Joined May 2012
how do I make sure that the servos can take that voltage? Wouldn't a BEC do that for me?
Old Sep 19, 2012, 03:28 PM
rcshirt is offline
rcshirt's Avatar
Joined Oct 2007
some of the older servos didn't like over 6 volts. Usually a bec can be changed between 5v and 6 v. I run my converstions at 5v to be safe. unless you really need high speed 6v isn't going to be noticed. and on a p40 you really don't need high speed servos.
you would have to look up their specs on each sevo.
Old Sep 19, 2012, 03:31 PM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
A 2S of around 750-1000Mah will power what you have for Multiple flights without recharging.
I use Lipos exclusively in my glow planes and always use a CC BEC. Have never had one hiccup.
1320fastback is offline Find More Posts by 1320fastback
Old Sep 19, 2012, 04:09 PM
600Bob is offline
Find More Posts by 600Bob
United States, OR, Canby
Joined Aug 2011
This one has the proper connector.
http://www.hobbyking.com/hobbyking/s...iver_Pack.html
I use the 2100mah version of this one in many of my planes. Good with any servo rated for 6v. Most good Lipo chargers have a setting for these batteries. They also are not as much as a fire hazard as Lipos. And no regulator to fail.
http://www.hobbico.com/radioaccys/hcam6415.html
600Bob is offline Find More Posts by 600Bob
Old Sep 20, 2012, 05:28 AM
Lifer is offline
Find More Posts by Lifer
Kansas City
Joined Apr 2010
Plus 1 on the LIFE packs!
Lifer is offline Find More Posts by Lifer
Old Sep 20, 2012, 07:10 AM
SohoR1 is offline
Joined May 2012
What size Lifepo should I be using for my GP Cherokee? Looks like my option are 750mah to 1500mah
Old Sep 20, 2012, 10:36 AM
rcshirt is offline
rcshirt's Avatar
Joined Oct 2007
i like 100mah in most of mine. Although a standard 4cell nicad was only 600mah for a 4 servo plane.
Old Sep 20, 2012, 10:37 AM
rcshirt is offline
rcshirt's Avatar
Joined Oct 2007
sorry 1000mah
Old Sep 20, 2012, 10:47 AM
jymz is offline
jymz's Avatar
Delaware, Ohio
Joined Nov 2006
I know the picture shows different it will come the same as the 700mah battery. (I have both) No adapter is required.
Jim
Old Sep 20, 2012, 10:53 AM
600Bob is offline
Joined Aug 2011
The ones linked in my post, #9 are more than 1500mah, as high as 3200mah. I like as much as I can fit in the plane, generally a 2100mah for a plane the size of the Cherokee.
Maybe not the best prices but a list of whats available from one brand.
http://www.towerhobbies.com/products...hcam6415m.html
Another option with standard JR plug.
http://www.hobbyking.com/hobbyking/s...ter_Pack_.html
Do not go by pack voltage to determine when to stop flying, go by MAH used like with a Lipo.
For Sale Thunder Power 5S, 3300mA, 65C LiPO...NEVER USED drice Aircraft - Electric - Batteries & Chargers (FS/W) 7 Jun 14, 2013 09:51 PM
Question Using LiPo for Rx FWCXC Batteries and Chargers 34 Sep 19, 2012 10:08 PM
Idea Using lipo charger to power laptop from 12 volt sammyc Batteries and Chargers 0 Apr 13, 2012 11:50 PM
Question Using 3 cell lipo to run RX directly (Nitro plane) maverick64 Fuel Plane Talk 17 Mar 16, 2012 08:47 PM
Discussion Question about using LiPO for Rx power RickAvery Power Systems 3 Nov 17, 2007 07:19 PM
