Old Sep 26, 2012, 10:17 AM
SDSURFnGLIDE is offline
Find More Posts by SDSURFnGLIDE
Multi rotors=No Paycheck left
SDSURFnGLIDE's Avatar
United States, CA, San Diego
Joined Apr 2011
Originally Posted by Titus Gordon View Post
Nice tip! I'll keep that in mind.
yeah definitely...its a quick and dirty fix...cheap and gets the job done....i just keep the stuff in my hobby kit....two second fix...well...2 seconds to set it up...24 hours to dry...haha
SDSURFnGLIDE is offline Find More Posts by SDSURFnGLIDE
Old Sep 26, 2012, 11:41 AM
Titus Gordon is offline
Find More Posts by Titus Gordon
FPV it is!
Canada, SK
Joined Aug 2012
My new props arrived! Thanks Flitelab!
Titus Gordon is offline Find More Posts by Titus Gordon
Old Sep 26, 2012, 01:48 PM
Raja_Kajiev is offline
Find More Posts by Raja_Kajiev
Joined Jun 2012
What are overall dimensions of the copter?
I mean, box of what size is needed to carry this beauty without disassembling?
Raja_Kajiev is offline Find More Posts by Raja_Kajiev
Old Sep 26, 2012, 02:04 PM
FPV it is!
Canada, SK
Joined Aug 2012
Not quite sure the exact measurements as I don't have it in front of me atm, but I've seen this picture before and the case is a Pelican 1650 which seems to be about the perfect size. I don't have a case for mine yet though.
Old Sep 26, 2012, 07:22 PM
FPV it is!
Canada, SK
Joined Aug 2012
Got it fairly stable in stabilize mode, altitude hold works but needs some tuning. Going to try loiter mode tonight!
Old Sep 26, 2012, 07:59 PM
vic20owner is offline
Find More Posts by vic20owner
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
Nice build! You'll need to remove the props to get it in the box, but it's a nice fit. I may have to get one myself and cnc out the foam so it'll drop in. (tom@hoverthings)
vic20owner is offline Find More Posts by vic20owner
Old Sep 26, 2012, 08:40 PM
FPV it is!
Canada, SK
Joined Aug 2012
Thanks! I really like the frame
Took it out to run a battery through it tonight and to test Loiter mode and it worked great! It was fairly calm outside with just enough wind to push it around some but it stayed there hovering in nearly one spot without any input from me. I walked up to it and grabbed an arm and dragged it about 5 feet away and let go and it went right back to where it was! No video though I'll try and get some next time.
Old Sep 28, 2012, 01:02 AM
compuatic is offline
Find More Posts by compuatic
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
Great job! Im following your foot steps soon and will bug you about the settings.
compuatic is offline Find More Posts by compuatic
Old Sep 28, 2012, 01:44 PM
FPV it is!
Canada, SK
Joined Aug 2012
I've got some tuning to do still, but it's getting better!
Old Sep 29, 2012, 12:00 AM
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
Is your board hard mouned to the frame or floating on rubber bands?
Old Sep 29, 2012, 09:47 AM
FPV it is!
Canada, SK
Joined Aug 2012
It's hard mounted with some plastic stand-offs. Seems to be working ok.
Old Oct 02, 2012, 09:20 AM
Mochaboy is offline
Find More Posts by Mochaboy
Radd Graduate '06
Mochaboy's Avatar
United States, MA
Joined Aug 2006
Titus,
Thanks for documenting your build - I'm about a month's work behind you and everything's on order.
Hopefully when I'm a little further along we can exchange notes on setup parameters.
Thanks again for all your hard work! (and good job on not frying the battery)
Mocha
Mochaboy is offline Find More Posts by Mochaboy
Old Oct 02, 2012, 09:57 AM
FPV it is!
Canada, SK
Joined Aug 2012
Thanks, this has been a fun learning experience for me.
I've been having some troubles with my GPS unit, worked once but since unable to get a GPS lock. I've got a new one coming to me.
Also got a sonar and 3DR telemetry radio coming.
Old Oct 02, 2012, 08:41 PM
Principal Member
compuatic's Avatar
San Francisco, CA
Joined Jun 2002
Where did you buy the sonar and 3dr?
Old Oct 02, 2012, 08:53 PM
FPV it is!
Canada, SK
Joined Aug 2012
I ordered this sonar
http://dx.com/p/hc-sr04-ultrasonic-s...-133696?item=3
and the 915 mhz kit from here
https://store.diydrones.com/category_s/13.htm
I'm following this to attach the sonar
http://www.rcgroups.com/forums/showp...postcount=1372
Build Log HoverThings.com HT-FPV Black Frame Build Up Adidas4275 Multirotor Talk 50 Aug 11, 2012 10:48 PM
Found HT-FPV HT-450 Parts Keddy Aircraft - Electric - Multirotor (FS/W) 0 Aug 03, 2012 07:28 AM
Rant My HT FPV Quadcopter was STOLEN! I have video of the suspect! daign Multirotor Talk 7 Jun 05, 2012 06:02 PM
