Joined Aug 2012
Mine had its first "flight" tonight. Hardly a flight it was mostly checking blade tracking(strapped down) and hovering inside the garage( yikes ).. I let my friend thats way more qualified do that.
We made a few small tweaks ( moved my cyclic servo balls one hole in he didn't like how I had mine ) Re-did the zero pitch and checked everything over. Blade tracking was perfect. One blade needed a small bit of tape on its center of mass point to balance them perfect. I guess I did a pretty good job for building my first heli we didn't have to change much! He hovered it in rate mode and the tail was good. Hovered in Heading hold. All good and ready for me to try it at the field this weekend. ![]() The only real complaints I have about the kit and build are. 1. The canopy fit like crap it was about 2" to narrow and warped to hell. I used a hairdryer and heat it up and made it better but its all cracking and just sucks. 2. The head spindle it came with had something wrong with it dont know if it got cnc'd wrong but it had a bad wobble that I could see by turning it by hand. I replaced it with this upgrade/new version and its perfect now. http://tarot-rc-heli.com/Tarot_RC_He...r-holder-black 3. One of the tail control plastic arms bound pretty bad where the plastic was thicker than the brass spacer inside it. I sanded it down a bit by hand with some fine sand paper and its fine. 4. The servo horns are complete trash, super brittle, and the splines are a weird size no idea what to replace them with. I broke 3 out of the 4 that you are supposed to use just by reaming them very carefully with a drill.. but it had some dual sided ones so we clipped one side and used those instead. Also due to the servo horns sucking I had to drill the hole out slightly larger than the ball end threads or they would just snap when you tried threading it in so you need 2mm nuts to hold it together. I would buy it again though. Nothing super major and it seems really nice. I can't wait to fly it myself at the field this weekend. |
Joined Aug 2012
At least I have the MCPX while I wait for 450 parts. Attempted some flips and inverts for the first time...most of them didn't make it onto video ( hard to film that little thing )
Recommend you do some reading while you are waiting for the new parts or you will be re-ordering and re-ordering and re-ordering. Unfortunately the TT is VERY unforgiving for any kind of a tail strike - even more unforgiving is replacing those gears. They are really a PAIN!
Recommended reading: Don't Touch The Controls 3D Is Not For Everyone Phoenix Simulator Flight School |
| Thread Tools | |
| Discussion Couldn't wait till Nall '09 | cleatis | 3D Flying | 0 | Nov 01, 2008 09:47 PM |
| Discussion Couldn't wait for SA Mudbug | TERHUT | Parkflyers | 4 | Apr 15, 2007 10:17 AM |
| Just Couldn't Wait for a P-38 | Balsa Hound | Foamies (Kits) | 5 | Oct 30, 2005 12:46 PM |
| Yippee! FIRST FLIGHT on TM ...... In dark, Couldn't wait till Morning | Scomis | Parkflyers | 13 | Jan 13, 2002 01:01 PM |
| Yippee! FIRST FLIGHT on TM ...... In dark, Couldn't wait till Morning | Scomis | Parkflyers | 0 | Jan 12, 2002 09:22 PM |
