Espritmodel.com Heli Air
Old Sep 21, 2012, 12:04 PM
Joined Aug 2012
Yea that makes sense thanks. And I have no idea I just got it because my friend has it on his and told me to get it lol.
KTMDirtFace is offline Find More Posts by KTMDirtFace
Old Sep 21, 2012, 12:08 PM
Rocket Programmer
jasmine2501's Avatar
United States, CO, Golden
Joined Jul 2007
It's a good idea to use the satellite with all that carbon fiber. I don't use one on my 450 Pro, I use the AR600 instead. I stuck one antenna through the hole in the bottom of the frame and tied the other one to the landing gear. Seems to work fine that way.
jasmine2501 is offline Find More Posts by jasmine2501
Old Sep 22, 2012, 01:49 AM
rc aircraft crasher
United States, MI, Lansing
Joined Sep 2012
i guess ill get one too then. my heli is all carbon fiber as well. by 90 degrees do you mean one like this _ and one like this ] ?
jnmardister is offline Find More Posts by jnmardister
Old Sep 22, 2012, 12:06 PM
Rocket Programmer
Joined Jul 2007
If you imagine that the receiver forms a plane extending in all directions, the plane formed by each receiver should intersect each other at 90 degrees.
Old Sep 22, 2012, 03:11 PM
rc aircraft crasher
Joined Sep 2012
ok, gotcha. thanks
Old Sep 23, 2012, 12:13 AM
Joined Aug 2012
I think my friend has his receiver mounted under the main gear between the frame and the sat is stuck to the outside of the frame on the side.
Old Sep 24, 2012, 01:36 AM
Joined Aug 2012
Had to move my receiver off the little shelf and down to the bottom of the frame. The wires would not fit without the RX being shoved against the motor...or they were smashed into the back of hte tail servo mount.
I mounted the motor and started routing my wires here a a couple pictures.
Tomorrow night I will finish mounting the ESC ( I got Tarot alumin battery tray and canopy mount so that I can fit it under the nose between the frame )
SHould have it buttoned up and done here soon.
Oh I had a weird wobble with the head that came with my kit. wobbled pretty bad...I could see it just by spinning it by hand.
I bought this from Dave at tarot-rc-heli.com I think I ordered it wednesday it was here saturday! Wobble is totally gone and it worked fine with the rest of the parts...I didn't have to buy an entire new upgraded head just this.
http://tarot-rc-heli.com/Tarot_RC_He...r-holder-black
Old Sep 24, 2012, 08:13 AM
rc aircraft crasher
Joined Sep 2012
where did you get the mesh for the wires? it looks so neat and clean.
Old Sep 24, 2012, 12:53 PM
Joined Aug 2012
Hobbypartz .45 cents for 3 feet. I bought $10 worth lol.
http://www.hobbypartz.com/wireprotector.html
tarot-rc-heli also has some. http://tarot-rc-heli.com/PROTECTION-TUBE-FOR-WIRE
I think I used the 5mm one for single wire and the 7mm for the two front servos.. and the 9mm for the big clump of wires from the gyro to the receiver.
You need shrink wrap also when you cut it it frays...But I got lazy and used electrical tape on the ends.
Old Sep 24, 2012, 04:16 PM
mmracecars's Avatar
United States, MI, Harrison Township
Joined Jan 2012
tarot
I have seen video tests on youtube where if you install the satellite as far away from the receiver as possible it does increase the range?.. But thanks for the explination.. I don't really know what it does either. It was cheap and my friend said to get one, so why not install it if I have it right?
Yes I think you can use the ZYX-S without a receiver but from what I gathered on heli freak it is a huge pain in the butt to setup and most people gave up.
the zyx-s only needs a sat,no reicever needed,it was my first fbl set-up.very easy to set-up and user freindly,and works great and now have 3
mmracecars is offline Find More Posts by mmracecars
Old Sep 24, 2012, 04:18 PM
mmracecars's Avatar
Joined Jan 2012
wire sleeve
http://www.mcmaster.com/#standard-ca...eeving/=jfoxeb
they have all diff kinds sizes and colors
www.mcmaster.com
Old Sep 25, 2012, 12:46 PM
rc aircraft crasher
Joined Sep 2012
ok thanks, ill have to get some.
Old Sep 25, 2012, 05:27 PM
Joined Aug 2012
I finished wiring and setting up the gyro and tail.
Onto leveling the swash and doing blade pitch and all that stuff tonight. Hopefully first hover test on wednesday.
Old Sep 26, 2012, 10:28 PM
bein ebin
ebinmoothedam's Avatar
India, Kerala, Kochi
Joined Sep 2012
excellent read. waiting for the hover report.
ebinmoothedam is offline Find More Posts by ebinmoothedam
Old Sep 26, 2012, 11:15 PM
If I drop 1 more heli screw...
finguz's Avatar
United States, CA, El Cajon
Joined Mar 2012
I'm impressed with tarot products. The build looks nice!
finguz is offline Find More Posts by finguz
Discussion Couldn't wait till Nall '09 cleatis 3D Flying 0 Nov 01, 2008 09:47 PM
Discussion Couldn't wait for SA Mudbug TERHUT Parkflyers 4 Apr 15, 2007 10:17 AM
Just Couldn't Wait for a P-38 Balsa Hound Foamies (Kits) 5 Oct 30, 2005 12:46 PM
Yippee! FIRST FLIGHT on TM ...... In dark, Couldn't wait till Morning Scomis Parkflyers 13 Jan 13, 2002 01:01 PM
Yippee! FIRST FLIGHT on TM ...... In dark, Couldn't wait till Morning Scomis Parkflyers 0 Jan 12, 2002 09:22 PM
