Old Jul 19, 2001, 10:52 AM
astroboy is offline
Find More Posts by astroboy
Superhero, Third Class
astroboy's Avatar
Carson City, NV
Joined Nov 2000
Best covering film for newbie?
I'm getting close to covering my Spacewalker, and I'd like some opinions on what is the lightest-weight opaque film that can be recommended for a first-timer. Searches here on Ezone seem to indicate that Ultracote/Oracover is preferable to Monokote.
If there is a transparent film that is significantly more than .04 ounce/sq. ft. lighter than what is recommended above, and still not too difficult to use, then I'd consider trying that and then airbrushing opaque colors over it. Either way,I will be using paint for trim; what type of paint is recommended for use on film, and what sort of surface prep is involved?
Thanks very much,
Jeff
astroboy is offline Find More Posts by astroboy
Old Jul 19, 2001, 11:43 AM
LJH is online now
LJH
Find More Posts by LJH
LJH
Moths do not fly inverted
LJH's Avatar
Greenwich CT.
Joined Sep 2000
Jeff,
I don't know about the weight part, but I have had much better luck with Oracover, both tranparent and solid colors, then I have with Monocote. I have limited experience covering but I have done a couple of plane , both sheeted and open bay. Good luck, it can be kind of fun covering. Good luck.
Cheers,
Jim
LJH is online now Find More Posts by LJH
Old Jul 19, 2001, 10:42 PM
DaveW is offline
Find More Posts by DaveW
Folsom,Ca,USA
Joined Apr 2001
Jeff
I'm an Ultracote bigot. Very easy to use, can be painted ( no dope please ) and doesn't keep wrinkling like Monokote does. Just follow instructions that come with it and you're first job will look good!
However! It does take a little while to "settle". I put a new plane out in the sun, hotter the better, for an hour or so and see what needs to be re-shrunk. Do this a couple of times and its pretty stable.
I'd do this before doing the painting. I don't know what to do if you got a wrinkle in a painted area.
But, I have only used the heavier opaque stuff, very strong, but it is not light.
Dave
DaveW is offline Find More Posts by DaveW
Old Jul 19, 2001, 11:17 PM
Regecide is offline
Find More Posts by Regecide
What's a Member??
Sydney,Australia
Joined Mar 2000
One of the lighter ones is Solarfilm. It's more stretchy than Monocote, but also easier to apply. I absolutely hate Monocote, tried it once on a friends plane and it just wouldn't work for me. Solarfilm isn't as strong as the others so it won't add a lot of strenght to the airframe but it doesn't shrink as bad so it's a lot easier to avoid warps especially on tailfeathers and light things like that.
Alex
Regecide is offline Find More Posts by Regecide
Old Jul 19, 2001, 11:49 PM
Shawn Palmer is offline
Find More Posts by Shawn Palmer
Schumacher USA
Tampa FL
Joined Jul 2000
I'll second the oracover, I'd never used it before (monokote was all they had at my old LHS in El Paso) but I bought a bunch on clearance @ Hobby Lobby, and 3 planes later I LOVE IT! I was forced to use monokote again for the "flat" colors on a warbird, and I THREW AWAY the 1/2 roll of each color leftover material when I was done. Never again.
Shawn
Shawn Palmer is offline Find More Posts by Shawn Palmer
Old Jul 20, 2001, 01:16 AM
fisher is offline
Find More Posts by fisher
Joined Apr 2001
If weight is not an issue:
The original is still the best for me: Monocote. You have to use high heat to get the proper adhesion and stretching. every iron I've owned ended up all the way up.
ultra cote is a close second. The only real complaint I have about it is the color selection.
All of the rest I've tried were low heat that would stick to it's self if the adhesive side touched and pull the color coat off. The line between shrinking and burning was so fine the possibility of burning through while ironing a compound curve was likely.
And finally look at what the best builder in the hobby use, electric and otherwise. Most use monocote or ultracote.
If you want light weight with extreme strength(and hassles) try micafilm. A pain to apply but almost bullet proof.
[This message has been edited by fisher (edited 07-20-2001).]
fisher is offline Find More Posts by fisher
Old Jul 20, 2001, 01:43 AM
Paul Susbauer is offline
Find More Posts by Paul Susbauer
Balsa Builder
Paul Susbauer's Avatar
United States, OR, Hillsboro
Joined Apr 2001
I'd check out Nelson Litefilm, available from Nelson Hobby Specialties. It weighs .6 oz per sq. yard with its own adhesive, its incredibly tough, yet still light. It goes around curves great, shrinks well, and doesn't sag bad, and doesn't wrinkle up in the sun.
Paul Susbauer is offline Find More Posts by Paul Susbauer
Old Jul 20, 2001, 07:01 AM
BNA Bob is offline
Find More Posts by BNA Bob
Nashville TN
Joined Apr 2001
I don't know about the weight, but I just finished covering a MAD Highlander with Oracover (my first covering job, too...) and it was easy to work with and came out great.
Cheers,
--Bob
BNA Bob is offline Find More Posts by BNA Bob
Old Jul 20, 2001, 02:59 PM
GaryK is offline
Find More Posts by GaryK
GaryK's Avatar
Pinehurst, NC
Joined Aug 1999
Like others have said, if weight is not an issue, Oracover is the most goof-proof covering I have used. It does tend to dull your trimming blade and I change mine frequently to do a good job.
My favorite light weight (and cheap!) covering is Towercote. At $6 per roll (it's perpetually "on-sale"), it is a great bargain and does a very nice job, particularly around compound curves. It has a lower temperature to bond and shrink, so it works well on foam as well.
Gary
[This message has been edited by GaryK (edited 07-20-2001).]
GaryK is offline Find More Posts by GaryK
best 4 stroke for a newbie? corndog Engines 16 Jul 28, 2004 08:29 AM
Best Micro Heli For Newbie samc99us Micro Helis 4 Dec 05, 2003 04:08 PM
best GWS plane for newbie navrog GWS (Grand Wing Servo) 6 Oct 24, 2003 08:47 PM
Best Electric Copter for a Newbie FV Racer Electric Heli Talk 4 Jun 23, 2002 09:28 PM
New covering film for light models bipeflyer Parkflyers 6 May 01, 2001 12:49 AM
