Definitely RTFM!
Most high wing trainers (if there's dihedral in the wings) will correct themselves if you get into trouble, as long as you have the altitude. High rates and low rates, I'm surprised since the manual didn't really explain them in detail that you didn't play with it on the ground to see what it did. You have a valid point though. If you contact HH and suggest that as a starting pilot you may find your suggestion ends up in a reprint of the manual. I'm also very sorry to inform you that you are now hooked. Welcome to the hobby! |
From the manual:
Latest blog entry: Foamie Resurrection
United States, MI, Detroit
Joined Sep 2012
Thank to all who commented and provided support and "welcome". Thank you for pointing out the note that I obviously missed. In the short run the value of the Champ is to be forgiving to new flyers.
I am still grounded for weather, but hopeful. Thanks again! |
Joined Jul 2011
I'm not a fan of all the dihedral that is put on trainers, it rarely helps a new pilot out of serious mistakes, increases difficulty flying in wind and couples yaw to roll such that normal yaw correction during approach and landing is annoying. |
United States, FL, DeLand
Joined Mar 2009
A trainer with dihedral can fly itself. It doesn't even need a pilot. What's a newbie doing if he tries to fly in high wind anyway? How is normal yaw correction during approach and landing annoying? I caught my Radian on just about every landing. Yaw correction was about as annoying as breathing.
Ditto that for reading the manual. Trouble is that this newbie didn't get one with his Decathalon!
Result - two prangs, two broken props...oops. I'm going to try a test glide, and then a hand launch in the long grass next time! BTW if you have a DX6i, you can set for 'EXPO/DUAL RATE' which decreases stick sensitivity in the middle area 0-100%. I tried 10-15% on the sim, and it really does make a difference if you're ham-fisted like me, but I haven't figured out the dual rate bit yet - the manual isn't very clear? |
Set your elevator rate from 100% down to 10%, flip the switch while holding full up or down and watch what happens. Make sure the plane is on the ground. |
United States, CA, Oceanside
Joined Apr 2011
Welcome to the hobby Porsche. The Champ is only the first step to this additction of ours. Pretty soon you will be getting up really early so that you can beat the wind just to fly your Champ for a little while. Then you'll think, " Wow, I can fly this thing pretty good. I wonder if a bigger plane..........." and on and on it will go. Have fun flyin' and be safe.
Joined Sep 2012
Wow! Lots of experience among the comments, some I understand others I think I need more time in the saddle to grasp.
Since my last post I have spent some serious taxi time, which has revealed a rudder trim or rear wheel issue that I am trying to deal with... it wants to turn left, with enough space at low throttle, it goes in circles, I centered trim, an tweeked the rear wheel, but the winds kicked up so I have to go back at that. Hand launchings seems to be the key for now, but winds continue to be a problem, I will probably be getting up early in the AM this weekend to see if I can get some calm air. Winds speeds have been low, but the gusts are killing me and my wing (enough said..I am a pro super gluer...working hard to keep the spare wing in the box). I am really looking forward to calm winds so I can experience that excitement that everyone is talking about...I hope it come soon I need it. I have not found a local club to lean on and the simulators do not seem to be mac computer friendly. Those of you who have warned about being hooked...I fear it has already happened. If for no other reason that I am driving for the first sustained flight. Thanks for all the words of wisdom and encouragement. |
| Thread Tools | |
| Discussion Calling all Angels, Calling all Angels, There's Trouble in Paradise | LcJ | Life, The Universe, and Politics | 30 | Aug 30, 2012 02:58 PM |
| Discussion Warning Rookie (Just purchased my first plane) | JBFlyer85 | Electric Plane Talk | 31 | Jul 05, 2012 12:54 AM |
| Discussion Where's All These So Called Free Heli Models for AeroFly Flight Sim? | Crash-n-Hard | Simulators | 4 | Jun 21, 2007 09:17 PM |
| Rookie. E-Starter first 10 flights. Questions | apodoc | Parkflyers | 1 | Jun 03, 2004 03:49 AM |
| Calling all cars... Calling all Cars - There's an Omega 1.8E on the loose! | Joedy | Electric Sailplanes | 3 | Mar 12, 2003 06:28 AM |
