Old Sep 18, 2012, 11:45 AM
mgivens is offline
Find More Posts by mgivens
mgivens's Avatar
United States, WA, Seattle
Joined Jan 2007
Question
laser cut aluminum
Hello,
I am having trouble finding someone to laser cut 1/16 aluminium plate to my CAD design. I have many control hinges, mounting brackets and other complex little parts that I would rather have cut out of aluminum than ply.
Any suggestions or experiance getting this done would be greatly appreciated!!
-Michael
mgivens is offline Find More Posts by mgivens
Old Sep 18, 2012, 11:53 AM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
I wasn't even sure if aluminium could be cut well with a laser. A quick google on "laser cutting aluminium" turned up a few companies on the first page of results. So they are out there.
But you will likely find that the "usual" sources that cut balsa and plywood can't do it if the laser needs a higher output for metal than for wood. One reference on a You Tube video note attached to the google reply mentioned a 400 watt laser was being used. That's WAY higher than most wood cutting lasers from what I know about it.
Also consider water jet cutting. You might find a local source for that more easily than laser cutting.
BMatthews is offline Find More Posts by BMatthews
Old Sep 18, 2012, 12:01 PM
mgivens is offline
mgivens's Avatar
Joined Jan 2007
Thanks Bruce,
I will try the water cutting avenue. It seems most of the google type laser results are for bigger/larger scale projects, without the small scale accuracy i am hoping to get. I was just hoping to find a manzano laser works type operation for aluminum. Maybe it doesnt exsist.
-Michael
Old Sep 18, 2012, 12:10 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Given that it seems to need a MUCH more powerful laser it's quite possible that you're right. After all the shop needs to charge in accordance with their per hour time based on paying back their investment and still turn a profit.
Old Sep 18, 2012, 01:12 PM
N74463 is offline
Find More Posts by N74463
Wait...Say again?
Anaheim, California
Joined Aug 2004
Michael,
As others have said, much more powerful lasers. I have a small side business making railroad handcar model kits in 1:8 and 1:12 scales (shameless plug: www.alamedacarworks.com). The frames and decking are all laser-cut aluminum. The outfit that cuts them for me? Their smallest laser cutter is 1000w. Yep, 1 kilowatt. (Turns out aluminum is much more difficult to cut with a laser than steel is.)
My vendor does short runs, but as you might guess, short runs aren't cheap. Are you having a few parts made for a project, or are you producing these in quantity for sale?
If you're interested, I can give you my source's info and you can talk to them about a quote.
Joe
N74463 is offline Find More Posts by N74463
Old Sep 18, 2012, 06:50 PM
Chad Veich is online now
Find More Posts by Chad Veich
Scale Builder
United States, AZ, Litchfield Park
Joined Jul 2002
I would be looking for somebody with CNC equipment who could mill out the aluminum parts. You might also consider G10 instead of aluminum as it works superbly for hinges, brackets, and whatnot. (G10 can't be cut with your typical laser either by the way.) I think CNC cutting would be far cheaper than with a water jet and probably much easier to find.
Chad Veich is online now Find More Posts by Chad Veich
Old Sep 19, 2012, 01:55 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Depending on how many bits there are for this project it may well be worth considering doing it the old fashioned way. You know, with jigs and regular tooling? Like we used to do back before we had laser, water jet, plasma jet and other CNC options?
Jigs for drilling and shaping control the shape and provide consistency and aid in holding the small parts for consistent shaping.
For 1/16 clean cutting aircraft aluminium a router with a follower ball bearing guide and a shaping jig can make short work of shaping a couple of dozen pieces. Then a second jig that has pilot holes in a steel overlay can serve for drilling any holes.
All in all the whole job of making the jigs could be done in an afternoon and the parts you want done the following afternoon for little to no cost if you have the means to make these jigs and the tools to form the parts.
Old Sep 22, 2012, 02:21 AM
RGose is offline
Find More Posts by RGose
RGose's Avatar
United States, TN, Knoxville
Joined Dec 2003
I've been away from manufacturing for a couple of decades, but it seems like your job is perfect for "Wire EDM", which is a CNC process that we used to get similar results to laser cutting, but in metal.
How Wire EDM Works (2 min 26 sec)
RGose is offline Find More Posts by RGose
Old Sep 22, 2012, 08:14 PM
liljimmy is online now
Find More Posts by liljimmy
20M northeast of Hell Mi
liljimmy's Avatar
United States, MI, Howell
Joined Jul 2012
http://www.emachineshop.com/machine-shop/index.php
free down load of sofware
liljimmy is online now Find More Posts by liljimmy
Old Sep 25, 2012, 07:53 AM
Hemikiller is offline
Find More Posts by Hemikiller
-insert witty saying here-
Hemikiller's Avatar
United States, CT, Killingworth
Joined Dec 2005
Don't necessarily need a laser to make aluminum parts, a turret punch can do that as well, as long as you don't have complex curves or odd internal cutouts.
I could quote them out for you, will send you a PM with me email for the files.
Hemikiller is offline Find More Posts by Hemikiller
Old Sep 30, 2012, 04:40 AM
jjantti is offline
Find More Posts by jjantti
jjantti's Avatar
Finland
Joined Sep 2004
It's not the power it is wavelenght
Cheap and popular CO2 laser has wavelenght of about 10,6um. Aluminium acts as a mirror for this radiation. More than 98% of energy bounces back from the surface. If putting tons of power with CO2 on it you'll might end up braking your laser with this reflected power.
I have cut aluminium with 3,2W tripled YAG laser (0,355um). It worked just fine. Aluminium is not the best material but it works. As previously mentioned G10(epoxy- GF and copper), Al2O3, CF, glass, depron, steel, polycarbonate and such...
Here is article that popped first when googled... (Fig.1 on page 33)
http://www.measurement.sk/2004/S3/Bartl.pdf
Jyri
jjantti is offline Find More Posts by jjantti
Old Oct 03, 2012, 09:18 PM
metalguy is offline
Find More Posts by metalguy
always something to learn...
metalguy's Avatar
Tacoma, WA
Joined Jan 2011
Waterjet cutting is really the way to go for this. There will be no heat-affected zone, as in laser cutting, so if you are planning on using heat-treated alloy aluminum, the temper will not be altered at all. The biggest disadvantage of water jet cutting is it can only be 2D work, as you cannot pocket with a water jet. Been doing it since 2003, and full scale aircraft parts are all we do at my work. ----------Metalguy
metalguy is offline Find More Posts by metalguy
Discussion Senior Telemaster laser cut kit V2 rodsmith123 Sport Planes 40 Mar 07, 2013 04:19 PM
Discussion Carl Goldberg laser Cut "Gentle Lady" ulpilotrmh Electric Competition Soaring-F5J/ALES/e-Soaring 65 Nov 27, 2012 11:18 AM
Sold ziroli DR1 laser cut kit laser lizard Kev Aircraft - Fuel - Airplanes (FS/W) 1 Sep 22, 2012 12:12 PM
Discussion Inexpensive Foam Cutting Template to be Laser-cut? dlinegar CAD/CAM 15 Jul 30, 2012 08:11 AM
For Sale Guillows laser cut Thomas Morse for conversion cwolfe Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Jul 08, 2012 11:28 AM
