Old Sep 18, 2012, 10:52 AM
AcroFPV is online now
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
Question
Charging a LiFe battery with a LiPo charger??
I have a 3s LiFe battery that came with my TX, but the only charger I have is for a lipo battery.
The charger has no buttons, no settings, nothing. It charges through the ballance port on the battery.
Would I damage the LiFe battery if I used the LiPo charger? I imagine I would have to watch it closely, as it does monitor each cell as it charges.
Or do i risk blowing things up??
This is the Charger I am using: http://www.hobbyking.com/hobbyking/s...30w_2s_4s.html
Thanks in Advance,
AcroFPV is online now Find More Posts by AcroFPV
Old Sep 18, 2012, 11:00 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Less then ideal but yes it will charge it, however with several catches. One you would have to remove the battery when the cells reach full at 3.6v. A lipo charges to 4.2v which is too high for a life. Second catch is you will have no way of balancing the pack unless you also happen to own an old external balancer you can use.
In short, buy a real charger.
grimbeaver is offline Find More Posts by grimbeaver
Old Sep 18, 2012, 11:07 AM
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
This is a ballance/charger that charges through the ballance leads.
Why wouldn't it ballance a LiFe battery??
Old Sep 18, 2012, 11:16 AM
United States, MN
Joined Feb 2011
No, it balances by charging each cell individually to 4.2v. There is no "balancing" circuitry in that charger other then the ability to terminate the charge on each cell individually at 4.2v. Since you are disconnecting the battery when the first cell reaches 3.6v you are never getting to the point of "balancing" the pack. If you could change the charger to terminate at 3.6v then yes it would be a "balancing" charger, but since you can not it isn't.
Old Sep 18, 2012, 11:18 AM
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
That makes sense. thanks.
Old Sep 18, 2012, 11:22 AM
United States, MN
Joined Feb 2011
I would save yourself the headache and just buy a cheap charger that does more:
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Old Sep 18, 2012, 11:28 AM
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
Yeah i have been searching for a better deal on that accucell.
But it looks like im just gonna have to bite the bullet and wait for HobbyKing.
Old Sep 18, 2012, 11:52 AM
United States, MN
Joined Feb 2011
What do you mean "wait for HobbyKing"? They ship out of Washington, you'll have it in like 2-3 days from when you order it as long as you order from the US warehouse.
Old Sep 18, 2012, 11:56 AM
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
yeah but they dont have the props I need in Washington, or the bullet connectors, or other parts I have in my cart.
True, they have a US warehouse now. Its just unfortunate most everything they carry is stocked in Hong Kong.
Old Sep 18, 2012, 01:23 PM
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
Okay so I said effit and decided to try my charger on the 3s LiFe battery. Whats odd was when I plugged the battery into the charger, it reads all the cells and I get 3.17/3.23/3.37 but then when i plug my charger into 12v DC, it drops and all the cells read 2.41/2.45/2.57.
I left the battery on the charger for about 10-15min but not a single cell changed voltage. So I decided to abort the mission, and I disconnected the battery & charger.
Guess Im just going to have to wait
Old Sep 18, 2012, 01:52 PM
United States, MN
Joined Feb 2011
Okay so I said fuckit and decided to try my charger on the 3s LiFe battery. Whats odd was when I plugged the battery into the charger, it reads all the cells and I get 3.17/3.23/3.37 but then when i plug my charger into 12v DC, it drops and all the cells read 2.41/2.45/2.57.
Not a clue what's going on there with the dropping voltage except I will say with most chargers you are supposed to plug in the charger before the battery. As for why nothing changed, no charger will initiate a charge if it thinks a cell is below 3v for safety purposes.
Old Sep 19, 2012, 08:03 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
YMMV -- IIRC EverydayFlyer / Charles charged a 3S A123 pack for more the 500 cycles to LiPo / 4.2 volts -- w/o complaints about a change in capacity / performance.
jrb is offline Find More Posts by jrb
Old Sep 19, 2012, 06:50 PM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
Even though the nominal voltage and normal termination voltage are be the same , the newer LiFE type rectangle cells MAY be a different matter. I've been wondering if anyone has any info on a higher termination voltage. My very limited awareness suggests that they have a sharp KNEE at the top similar to the sharp KNEE at the bottom. sorry, can't remember at what voltage this occurs.
gulio is offline Find More Posts by gulio
Old Sep 19, 2012, 06:52 PM
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
Consider your friend lucky.
I would never charge a life to 4.2v per cell.
Old Sep 20, 2012, 08:57 AM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
As I asked (tried to) is LiFe = A123?
Our friend Charles (do a search) is one of the best battery gurus here!
Of his many A123 packs he specifically did one @ 4.2 to see the long term effect -- not much as I recall.
Discussion Charging my first lipo battery with my new charger insutama Batteries and Chargers 7 Oct 16, 2013 09:24 PM
Discussion Gens Ace iMars 50W 1-6S Smart LiPo/LiFe/NiMH/NiCD Battery Charger/Balancer in stock! Nitro_Gary HobbyPartz.com 1 Jul 16, 2013 04:24 PM
Discussion life / a123 charging weirdness with hyperion EOS charger ? aquaanox Batteries and Chargers 5 Jul 21, 2012 05:45 PM
Discussion Gens Ace iMars 50W 1-6S Smart LiPo/LiFe/NiMH/NiCD Battery Charger/Balancer in stock! Nitro_Gary Nitro Planes 0 Jun 05, 2012 06:14 PM
Question Can I charge a LiFe Tx batt. with a basic Lipo charger? Just4parts Batteries and Chargers 5 Jun 03, 2012 03:09 PM
