This thread is privately moderated by phil alvirez, who may elect to delete unwanted replies.
Old Sep 18, 2012, 04:39 AM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
bec, sbec, ubec
i asked master Lucien Miller from innov8tive what are these. he said:
They are all BEC circuits. The BEC and UBEC are both generic terms referring to a Battery Eliminator circuit. This is any device that will set the battery voltage down to 5 or 6 volts to run the Receiver and Servos. Typically, a BEC is a linear type circuit used on speed controllers designed to be used on 2, 3 or 4 Li-Po cells. The term SBEC means Switching BEC. This type uses a switching type voltage regulator instead of a linear type regulator. The switching regulator is much more efficient, and can be used with higher cell counts, some as much as 12 Li-po cells. Standard BEC circuits take the excess voltage and convert it into heat. Switching type BEC circuits chop the incoming voltage up into little pieces and only take as much energy as they need to create the output voltage required. By doing it this way, there is no wasted energy, and the circuits can be up to 95% efficient in converting voltage from one level to another.
good to know, isn't it?
i am also learning that sbecs are available-and needed-from 40 amps up.
phil alvirez is offline Find More Posts by phil alvirez
Old Sep 21, 2012, 11:55 AM
tobermei is offline
Find More Posts by tobermei
Mt Tamborine, Queensland, Australia
Joined May 2008
It's good to know the difference between a linear and switching bec, I won't use linear bec on any battery with more than 3 cells.
tobermei is offline Find More Posts by tobermei
Discussion Sbec, ubec, bec whats the difference? daneflyer Power Systems 69 Feb 02, 2016 07:15 AM
Discussion esc w/bec, sbec, ubec: what is it? phil alvirez Power Systems 5 Jun 18, 2012 07:25 PM
Question when to have an external BEC and which amp or volt rating of UBEC or SBEC? TheSelf Electric Plane Talk 13 Jun 07, 2011 10:30 PM
Wanted BEC - UBEC or SBEC karakoram Aircraft - General - Radio Equipment (FS/W) 12 Jan 03, 2006 10:53 AM
BEC, SBEC & UBEC Difference Between Them mcoccia Micro Helis 31 Feb 08, 2005 01:18 PM
