Old Sep 17, 2012, 11:21 PM
dougmontgomery is offline
Find More Posts by dougmontgomery
dougmontgomery's Avatar
Glendale,Az.
Help!
.dxf to .dat file
is there any free programs or easy way to do this? I am trying to help a friend out, so he can cut me some cores.
he has Mach 1 and mach 3 i guess but that does not do it.
thanks, Doug
dougmontgomery is offline Find More Posts by dougmontgomery
Old Sep 18, 2012, 03:35 AM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
I don't think you want a .dat file. The .dat format is not standardized.
What you really need is the gcode file. Often listed as a .nc, Mach3 also supports a few other formats.
This code is generated by cam software. There are some demo programs, that are limited. Some of the cheaper software is also very limited in the tool paths available. So what your looking for is software that can generate the gcode, with a postprocessor for Mach3, and has the type of tool paths you need.
He should have some software, or he would have a hard time using the machine.
If you have trouble getting software, I could generate the gcode for you. Since it is custom for what your doing, and the machine its being used with, it would take many questions to get it done.
Roto Rob is offline Find More Posts by Roto Rob
Old Sep 18, 2012, 09:31 AM
Quick61 is offline
Find More Posts by Quick61
Just call me crash for short
Quick61's Avatar
United States, OH, The Plains
Joined Jan 2011
For what it looks like your wanting to do, this is about the best I've come up with that has a reasonable price tag to it (FREE!) http://pycam.sourceforge.net/ it will generate your tool path for roughing, semi-finish and finish as well as gravure, though you won't probably need that for CNCing (wing?) cores. Read over the link and see if it fits with what your wanting to do.
Mark
Quick61 is offline Find More Posts by Quick61
Old Sep 23, 2012, 12:49 AM
jerome_ is offline
Find More Posts by jerome_
Jedicut, free CNC software
jerome_'s Avatar
France, IdF, Paris
Joined Feb 2006
Hi,
Take a look at this french solution and search "Profscan" : http://www.aeropassion.net/leblog/pa...tre-silhouette
Jerome
http://www.aeropassion.net/index-en.php
Jedicut : free CNC software
jerome_ is offline Find More Posts by jerome_
Old Oct 18, 2012, 09:00 AM
Doron is offline
Find More Posts by Doron
Newport Beach
Joined Jul 2005
site www.aeropassion.net seems to be down
Doron is offline Find More Posts by Doron
Old Oct 18, 2012, 02:40 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Use this link and download ConCord. It will covert between .dat and .dxf formats.
http://www.mh-aerotools.de/airfoils/software.htm
wyowindworks is offline Find More Posts by wyowindworks
Old Oct 23, 2012, 01:17 PM
szastoupil is offline
Find More Posts by szastoupil
Scott Zastoupil
szastoupil's Avatar
USA, WI, Waupaca
Joined Aug 2002
In addition to Adam's post above, I've also found this useful for DAT conversion. http://gm.cnc.free.fr/en/index.html
Scroll down to Profscan.
Another approach to importing ASCII XY coordinates into CAD is to import them as a "point cloud" in your CAD program. Tom Siler posted this as part of a Rhino tutorial a year or better ago. It seems CAD programs have different terminology, but it's the same process. I think ViaCAD Pro it's imported under a spline menu, even though it's not a spline and rather line segments. I wish I had documented the process to add to the collection, but I did not and fiddled with DAT files a lot to get things to work with Anker's Foamcutter software. As mentioned above, not all DAT formats are the same.
szastoupil is offline Find More Posts by szastoupil
Old Oct 25, 2012, 06:42 AM
jerome_ is offline
jerome_'s Avatar
France, IdF, Paris
Joined Feb 2006
It's online now
Jerome
Question DAT to DXF file converter generaltomfooler The Builders Workshop 13 Nov 21, 2015 05:39 AM
Discussion Airfoil .dat File Conversion JimHSoars Modeling Science 7 Aug 22, 2012 05:35 PM
Convert DXF to DAT files djmrozinski Foamies (Kits) 0 Dec 10, 2003 07:25 PM
Need to convert PowerCAD files (flx) to DXF or PLT files jbourke The Builders Workshop 3 Oct 18, 2002 09:42 AM
Plot files from DXF Files ? Russell2 Electric Plane Talk 2 Apr 27, 2002 12:07 PM
