Old Sep 17, 2012, 05:06 AM
Mr_westie is offline
Find More Posts by Mr_westie
Down under under
New Zealand, Auckland
Joined Nov 2007
Data
Ax-2810q 750kv motor test, as good as the nx-4006 530kv
http://www.himodel.com/electric/AX-2..._Aircraft.html
The motor has a nice finish and feels solid.
Comes with 2mm bullets fitted.
Long wires, 35cm
4mm Shaft with 5 & 6mm bushings. 9mm high
Shaft length 16mm
Props tested
14x8
http://www.quadrocopter.com/Graupner...eft_p_561.html
13x4.5
http://www.himodel.com/plane/13_x_45...CW_Yellow.html
12x4.5
http://www.himodel.com/plane/GF_12x4...W_one_CCW.html
11x4.7
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX1685
10x4.5
http://www.multiwiicopter.com/produc...-4-multicopter
Hobbywing Funfly 30A ESC.
Watts, grams/W
Looks like I am missing the secret sauce to get the published numbers.
The search goes on.
On a brighter note it does perform equal/better than the HK NX-4006 530kv
http://www.hobbyking.com/hobbyking/s...dProduct=17923
All 4s
Mr_westie is offline Find More Posts by Mr_westie
Old Oct 15, 2012, 08:51 AM
alainphoto is offline
Find More Posts by alainphoto
Japan, Tokyo, Chiyoda
Joined Oct 2010
Thank you for sharing the test
That might be my next motor then, for a 1.5kg payload octo.
alainphoto is offline Find More Posts by alainphoto
Old Nov 07, 2012, 10:38 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
anybody know the resistance of the AX-2810Q-750KV as im trying to get ecalc estimates.
i currently have:
kv:750 (himodel)
resistance:?
noload: .82A @14.8v (himodel)
Limit: 370(himodel) -> 444(HK)
#mag poles: 16 (counted off of HK image)
case length: 26 (hk)
sirbow2 is offline Find More Posts by sirbow2
Old Nov 08, 2012, 01:13 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Case length is wrong , it's 12mm outside, measured by me now, and, according to motor code 2810, this means the stator diameter is 28mm and stator/magnets length is 10mm.
Mag poles again wrong, it's a 14/12 standard setup
I would use 0.2 Ohms for ecalc, it's a typical resistance for this motor class.
Anyway, this seems to be the best flat, not disk motor design under $20, no need for ecalc to say this, OP test results speaks.
renatoa is offline Find More Posts by renatoa
Old Nov 08, 2012, 07:22 AM
sirbow2 is offline
Emress
Joined Nov 2011
oh, ok so its the can length measurement on HK. thanks! and i guess guessing at 1/4 of the magnets hidden in the picture isnt a good idea. hopefully using it for a hexa.
Old Nov 08, 2012, 05:20 PM
sirbow2 is offline
Emress
Joined Nov 2011
ok so i have a question for my ecalc calcs. i have attached the excel of all parts which has final weight except for gimble, gopro, vtx batts and landing gear and so i just made the ecalc total to 3000g instead of 2400g. some of the grams are weird because i didnt want to add another column for final proportional weights, so i just changed some of the values.
i have two cams n stuff for the pilot and one for the gopro/other cam controller
does this ecalc seem plausible? are these motors really that great? seems strange.
oops missed the top row. B is individual price, c is quantity, d is total price of that item, e is grams of that item, f is total grams of the quantity. at the bottom is the total g (~2400)
it should produce ~1880g each with 11in props so thats like 11000g. i should be able to do 5500g max weight but with 3000g overall in ecalc i get .4:1 thrust to weight (see the . in .4).
Old Nov 09, 2012, 12:20 AM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
got one question about your ecalc... number of rotor?
jy0933 is offline Find More Posts by jy0933
Old Nov 09, 2012, 08:35 AM
sirbow2 is offline
Emress
Joined Nov 2011
I feel stupid to say the least... Thanks
Old Nov 09, 2012, 10:43 PM
sirbow2 is offline
Emress
Joined Nov 2011
...and using the wrong calculator came out to 22min hover with 8000mah.
Hopefully a cam/fpv/gimble won't add much weight.
Do you guys think it would be best to have two fpv systems? One that is always for ward for the pilot and then another one for the gopro/gimble so that the cam dude can move that independetly with a second tx.
Old Nov 10, 2012, 01:02 AM
jy0933 is offline
James not bond
jy0933's Avatar
Joined May 2012
more system more weight.. totally depends on the need
Old Dec 04, 2012, 01:54 PM
KKUSA is offline
Find More Posts by KKUSA
United States, IN, Indianapolis
Joined Oct 2010
I just got 4 of these from Himodel, and while the quality is pretty good for the money, and the performance seems pretty good so far, 3 of the 4 I received have bad bearings. One of them is really bad and it would reach a point where it would actually seize turning it by hand.
I did pop one of the bearing shields off and there is quite a bit of crud in it. I suspect they are all just dirty bearings, but on a new motor that equates to a bad bearing.
On a better note, the rotors are actually balanced.
They will be good motors, just have to replace all the bearings. Bummer!!!
KKUSA is offline Find More Posts by KKUSA
Old Dec 17, 2012, 04:04 AM
renatoa is offline
Joined Sep 2007
Talking "secret sauce", interesting how real life setups can produce quite significant results than bench measurements.
Get the first row in your table, 300 grams 3s 12x4 prop = 37W drawn = 8.11g/W. This could mean 300 * 4 = 1200 g quad, right ?
My 1150 grams quad draws in hover 9A from 3s, turning a 12x4.5 prop, which led to 11g/W efficiency.
Could be the effect of the ESC reflashing ? Are you testing with 400Hz driven ESC, or a standard aero setup ?
Old Dec 18, 2012, 12:32 PM
Down under under
Joined Nov 2007
Interesting.
Margin of error was probably +-0.5g/w
11 is a significant difference.
Esc could play a part there.
I was using unflashed.
As at the time there was not option for SIL based ESC
Now there is.
http://www.rcgroups.com/forums/showthread.php?t=1686498
Will re run test and see.
Old Dec 18, 2012, 12:48 PM
renatoa is offline
Joined Sep 2007
There are other explanations though... just these days is in progress a thread about wattage, find it in electric gliders forum.
Lots of good points there about how misleading could be the static thrust.
Old Jan 28, 2013, 05:29 PM
alphapilot is offline
Find More Posts by alphapilot
Joined Jan 2013
Just found this thread via google as I'm experimenting with these motors. I ordered the 900kV version directly from the manufacturer, they provided me with the internal resistance in case you want to make simulations in ecalc. It's 0.108ohm
alphapilot is offline Find More Posts by alphapilot
For Sale 6 2814Q 750kv iPower motors with 450mm cables aForcefulThrust Aircraft - Electric - Multirotor (FS/W) 3 Aug 11, 2012 11:59 AM
Discussion A40-10s 750kv on a protos 500? kavic5150 Hacker Brushless 6 Jun 27, 2012 02:58 PM
For Sale 2836-750kv motor for sale NIB NeverCrashed Aircraft - Electric - Multirotor (FS/W) 2 Jun 25, 2012 11:26 AM
Sold *** Price Reduced *** OS Power Box E-3010 Muffler for OS 46 AX, 55 AX and others modestmagi Aircraft - Fuel - Engines and Accessories (FS/W) 2 May 08, 2012 09:48 PM
Sold OS Power Box E-3010 Muffler for OS 46 AX, 55 AX and others modestmagi Aircraft - Fuel - Engines and Accessories (FS/W) 0 May 05, 2012 04:40 PM
