Old Nov 27, 2003, 09:51 PM
Toronto, Ontario
Joined Jul 2002
Help - Reversing an Astro 60
Hi Guys,
Another question regarding my Astro 60. I just got a Modelair-Tech belt drive (Thanks Sabrejock!) and need to reverse the rotation of my superbox equiped Astro 60.
I read I need to find the "neutral point" of the motor. From what I understand, this is done my loosening the 4 long motor bolts and rotation the black casing slightly until the amps are at the lowest.
First Question: I plan on running the motor at 36 cells. Do I need to find the neutral point using this many, or will say 12 cells be fine.
Then I understand that to find the proper timing, I should rotate the casing untill there there is a no load draw of about 2 to 4 amps? Does anyone know a good target?
Here's where Im lost. To reverse the rotation of the motor, is it just a matter of moving the motor cases to either side of neutral point. IE, turing left will make it turn left, right turn right?
Anyone care to suggest a few props for this setup?
Astro 60 11 turn, 36 2400mah, 2:1
Thanks for your help!
Dave
DavidMC is offline Find More Posts by DavidMC
Old Nov 28, 2003, 08:27 AM
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Dave: I've e-mailed you a copy of Astro Bob's procedure. Tex.
Sabrejock is offline Find More Posts by Sabrejock
Old Nov 28, 2003, 05:45 PM
Toronto, Ontario
Joined Jul 2002
Got it.
Thanks Tex!
Old Nov 28, 2003, 09:40 PM
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Ah good - much better than me trying to explain it......
BEC is offline Find More Posts by BEC
How hot is too hot for an Astro 60? DeanW Power Systems 7 Aug 17, 2005 07:25 PM
Reversing an Astro 010 Brushless Farm Flyer Electric Plane Talk 5 Jul 31, 2005 12:16 PM
Help with an Astro 10/14 Repair John_C Micro Helis 5 Mar 13, 2005 02:33 PM
Reversing an Astro 40G shv2sail Power Systems 1 Oct 08, 2004 12:58 PM
Reversing an Astro 020 motor tenover Electric Plane Talk 10 Jun 26, 2003 10:19 PM
