Old Sep 16, 2012, 08:31 PM
FWCXC is offline
Find More Posts by FWCXC
FWCXC's Avatar
London Ont.
Joined Sep 2006
Question
Using LiPo for Rx
I seen the opportunity to use 2 C LiPo batterie for my RC planes as a better choice then NiCad's .So I bought two Zippy 2100 ma batteries, I also bought UBEC to lower the voltage to the receiver. I am flying Spectrum/JR system. I plugged it in receiver blinks once and the satellite is blinking intermittently. It does not work. As soon as I hooked up NiCad batterie it worked again?
Any help or suggestions would be appreciated.
Greg
FWCXC is offline Find More Posts by FWCXC
Old Sep 16, 2012, 09:49 PM
rcalldaylong is offline
Find More Posts by rcalldaylong
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
Greg
how did you wire the UBEC?
see if this helps:
External UBEC "How To" (5 min 27 sec)
rcalldaylong is offline Find More Posts by rcalldaylong
Old Sep 16, 2012, 10:02 PM
FWCXC is offline
FWCXC's Avatar
London Ont.
Joined Sep 2006
rcalldaylong Thanks this is great info. I am fairly new to electric's and have to learn a lot yet. I'll give it a try.
Greg
Old Sep 17, 2012, 06:05 AM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Did you charge the LiPo's before you tried to use them? I know this seems obvious but sometimes we forget.
Also you wrote "2 C". Did you mean "2S"? (two cell.)
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Sep 17, 2012, 10:03 AM
pilotpete2 is online now
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Using a lipo for a receiver battery and having to add a regulator makes verl little sense when a 2S LiFe pack will be safer and doesn't need a regulator (BEC) if the servos are rated for 5 cell (6V nominal) operation. Just about any lipo charger on the market has LiFe/A123 settings.
Pete
pilotpete2 is online now Find More Posts by pilotpete2
Old Sep 17, 2012, 10:20 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Pete
Good advice but on a side note not all servos rated for 6V operation are happy with LiFe batteries, most but not all. Personally I'm using Hitec HV servos with a 2S lipo in all my new stuff. They even have a low cost HV std analog servo now.
grimbeaver is offline Find More Posts by grimbeaver
Old Sep 17, 2012, 11:03 AM
pilotpete2's Avatar
Joined Jun 2004
I've had good luck running nominal 6.6V, even on some old ATX 94102 that were the last of the old style ATX style connector and Hitec sport servos such as the HS-325 and 475/485.
Moving forward I've switched to the Hitec HS-430HB HV servos for any standard sport application. A dual BB HV servo for $13.49, not too shabby.
Pete
Old Sep 17, 2012, 04:48 PM
FWCXC is offline
FWCXC's Avatar
London Ont.
Joined Sep 2006
Glen
Yes it was a misprint it is 2S batterie . Do I use UBEC or SBEC?It seams UBEC is used for separate power to the receiver with electric powered airplanes and SBEC is used with glow planes.or I misunderstood ?
Pete
I have couple of 123/ 6,6 Batteries but I thought that the high voltage would damage servos so I never used them?
Thanks for the replies
Greg
Old Sep 17, 2012, 06:06 PM
USA, GA, Marietta
Joined Aug 2005
Yes it was a misprint it is 2S batterie . Do I use UBEC or SBEC?It seams UBEC is used for separate power to the receiver with electric powered airplanes and SBEC is used with glow planes.or I misunderstood ? Greg
UBEC and SBEC are different terms for the same thing. Basically it is the same circuit that is found in an ESC, just as a standalone device. I think SBEC came from Standalone Battery Eliminator Circuit and UBEC is the trade name of a particular brand. But UBEC has come to be used universally. Technically these devices are not battery eliminators but voltage regulators.
Glen
Old Sep 17, 2012, 06:19 PM
FWCXC is offline
FWCXC's Avatar
London Ont.
Joined Sep 2006
Hi Glen I think I understand that, but why when I connect 8V batterie with UBEC with a jumper at 5V (which is regulated power)the receiver does not respond and when the NiCad is connected it works? It does not matter what the battery power it is UBEC should deliver 5V? Fully charged NiCad batterie is 5.6V.
Greg
Old Sep 17, 2012, 07:26 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Have you checked the output of your BEC with a voltmeter?
This should ALWAYS be done on all new BECs and you should not rely on the QC at point of manufacture as some QC departments are iffy at best.
I've heard reports of BECs with either no or low output as well as BECs with far too high output that then smoked receiver and servos. Consequently, it is extremely wise to check first.
What specific BEC are you using? Are you sure that it is specified to work properly with 2S lipoly?
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Sep 17, 2012, 07:37 PM
USA, GA, Marietta
Joined Aug 2005
Also have you verified that your batteries are fully charged? Again verified with a volt meter.
Glen
Old Sep 17, 2012, 08:32 PM
FWCXC is offline
FWCXC's Avatar
London Ont.
Joined Sep 2006
What specific BEC are you using? Are you sure that it is specified to work properly with 2S lipoly? I am using HK UBEC 2-6S 3A max5A
Mark
No I have not checked the voltage output.
Very good suggestions .Thanks
I am using HK 2-6S UBEC 3A max 5A
Glen
The battery's were fully charged. I did verify voltage. 4.20 per Cell
Old Sep 17, 2012, 08:45 PM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
2S and external BEC's are all I use in my fuel planes.
Long as its wired correctly yours should work.
I know, I know. we're doing it wrong not using Life but I don't have any on hand and am not buying them when I have lots of small 2S available.
1320fastback is offline Find More Posts by 1320fastback
Old Sep 17, 2012, 08:52 PM
FWCXC is offline
FWCXC's Avatar
London Ont.
Joined Sep 2006
I just checked the voltage leaving BEC it is 5.23 on one and 5.33 on the other?
Greg
For Sale Used lipo sale! Many 5s and 10s lipos for sale! All in working condition! sgrim80 Aircraft - Electric - Batteries & Chargers (FS/W) 7 Jun 25, 2012 07:43 AM
Wanted WTT Used Futaba 3PM-2.4 with NO RX for a FS-gt3b with RX tconners Cars - Accessories (FS/W) 1 Jun 11, 2012 07:45 PM
Question Using 3 cell lipo to run RX directly (Nitro plane) maverick64 Fuel Plane Talk 17 Mar 16, 2012 08:47 PM
Question Use Lipos for Rx Battery? FoamCrusher Batteries and Chargers 13 Jan 13, 2004 09:19 AM
