Old Sep 16, 2012, 03:58 PM
AtGame7 is offline
Find More Posts by AtGame7
United States, PA, Ellwood City
Joined Aug 2011
Jump box or just buy a battery to charge at field?
I don't want to use the car battery to hook up the charger and I'd like a solution for charging at home as well.
Would a jump box with a 12v outlet be the best idea or just go ahead and buy a battery to do the job? I'm assuming a deep cycle battery is correct if I go that direction.
I'm leaning toward a jump box simply for the ease of portability. Would one work better than another?
AtGame7 is offline Find More Posts by AtGame7
Old Sep 16, 2012, 04:02 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Deep cycle batteries are expensive heavy and only last a few years. I think the small generator is a much better option.
Old Sep 16, 2012, 04:13 PM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
Most if not all Jump Boxes are of far to low a capacity for this job unless you are using very small capacity batteries in your planes. It is easy to deep discharge such batteries trying to get that last charge of the day out of them and then--new battery required as Pb's do not tolerate deep discharge at all well. For small capacity batteries (like 1200 to 2200 mah 3 and 4 cell LiPo's) a lawn mower type battery will give you 3 or 4 recharges without requiring a recharge itself.
Rodney is offline Find More Posts by Rodney
Old Sep 16, 2012, 05:05 PM
AtGame7 is offline
Joined Aug 2011
Small generator? Got a link to what you are talking about? You mean like a gas powered one? Seems like overkill, no?
Old Sep 16, 2012, 05:17 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
Does not seem like overkill to me - that is what I use. Better than a heavy battery IMHO.
I use this one:
http://www.harborfreight.com/engines...tor-66619.html
If I were buying today I would get the Honda:
http://powerequipment.honda.com/gene...ter-generator-
Old Sep 16, 2012, 05:37 PM
AtGame7 is offline
Joined Aug 2011
I use this one:
Aren't they pretty loud, though?
Old Sep 16, 2012, 05:45 PM
hoghead5150 is offline
Find More Posts by hoghead5150
The wind caused that!!
hoghead5150's Avatar
United States, OK, Poteau
Joined Jul 2012
i guess it depends on how much charging you plan on doing at the field. i use a small walmart style jump box. it will charge my 3s 3200mah batteries about 4 times before needing to be recharged itself. if your planning on flying all day, your gonna need something better. if i need to charge more than that out at the field, i just use the cars battery.
i have an ac/dc style charger for my rc stuff, so at home i just plug it into the wall socket and charge my batteries.
hoghead5150 is offline Find More Posts by hoghead5150
Old Sep 16, 2012, 05:46 PM
ltc is online now
ltc
Find More Posts by ltc
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
The Honda inverter generators are extremely quiet.
I have a 2000 watt Honda inverter and a 7000 watt Honda inverter generator.
The 2000 watt has a couple thousand hours, as I used it for years when my son was racing. It was never an issue between trailers or running all night.
Highly recommended for RC field application. You can run 8+hours on a single tank and when idling, you probably won't hear it.
ltc is online now Find More Posts by ltc
Old Sep 16, 2012, 08:06 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
Correct from 25-30 feet away the Honda is barely audible. The Harbor Freight is louder but nothing too bad but it is 2 cycle.
So I would get the Honda - you can find them used for less money and use them if you have a blackout at home. They are extremely nice.....
Old Sep 17, 2012, 04:50 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
While convenient I find nothing more annoying than going to an electric event with a bunch of annoyingly noisy smelly generators running.
Deep cycle for me.
Azarr
Azarr is offline Find More Posts by Azarr
Old Sep 17, 2012, 05:57 AM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
A 1000 watt 4 stroke inverter gen works well. I use a Champion brand 65 DB if I remember right. Just a little more than a buddies 1000 watt Honda but a much better price. With the inverter, the RPM is proportional to the load on it. With no load, it runs on what would be considered a fast idle. Charging two 1300 batts at once doesn't even change the RPM. Weighs 36 lbs.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Sep 17, 2012, 06:02 AM
Fast Guy is offline
Find More Posts by Fast Guy
Canada, ON, Thunder Bay District
Joined Apr 2007
Deep cycle for me too. I fly 6s and 12s planes charging with 2 Hyperion Super Duos. The required gennerator and power supplies would weigh as much as the two 100ah batteries I use in series. All this with no noise or smell. Get a good days flying with this setup.
Fast Guy is offline Find More Posts by Fast Guy
Old Sep 17, 2012, 12:29 PM
Beckler is offline
Find More Posts by Beckler
Beckler's Avatar
Canada
Joined Apr 2008
Deep cycle for me.
Azarr
Yeah this is a funny image. If you're gonna run a bunch of generators to charge batteries to run motors, just skip the batteries and put a gasoline engine in your aircraft! Either way it's gas-powered.
I'm only flying 3s 1300 size, so a small 18Ah sealed lead-acid works well for me. Heavy tho! In fact 12/14Ah might have been enough. A lot more convenient than wet-type with spillage, keeping upright, etc. issues.
Beckler is offline Find More Posts by Beckler
Old Sep 17, 2012, 05:39 PM
AtGame7 is offline
Joined Aug 2011
Thank you all for the replies. He flies mostly micros and a Super Cub right now with a T28 in his near future.
I think for charging those small batteries a jump box should be good enough, plus it's a good excuse for me to buy one and have it in the trunk.
Old Sep 17, 2012, 06:04 PM
M Ashmore is offline
Find More Posts by M Ashmore
Average User
M Ashmore's Avatar
Bakersfield, California
Joined Aug 2003
When lipo prices came way down a few years ago, I dumped my 80Ah deep cycle battery. Flight packs are so cheap now I can fly all day without recharging at the field.
M Ashmore is offline Find More Posts by M Ashmore
Discussion When Charging Lipo's At The Flying Field Do You Do A Fast Or Balance Charge? itsme2 Batteries and Chargers 60 Aug 30, 2012 04:50 PM
Discussion is it possible : Charging & discharging battery at the same time or sth like that denisrud Batteries and Chargers 1 Jul 31, 2012 09:42 PM
Discussion Charging from one 80 Ah 12 volt Pb battery at the time or two in series? bossee Batteries and Chargers 10 Jun 26, 2012 06:18 AM
Discussion I need a new field battery for charging at the field Wild Bill Batteries and Chargers 10 Oct 18, 2011 03:39 PM
Discussion Batteries for charging at the field or installed in a trailer Diggs Batteries and Chargers 67 Jan 17, 2009 04:09 PM
