Old Sep 16, 2012, 10:29 AM
cmidnight is offline
Find More Posts by cmidnight
cmidnight's Avatar
Joined Sep 2012
Issues with AR400
First, I would like to say that I am returning to the hobby after 30 years and cannot believe how things have changed! Great to be back!
I have a new Spektrum AR400 Rx and a DX7s. All seems to go fine during the bind process (Rx light flash, turns solid, Tx reading well), but there does not seem to be the connection with the channels. No control surface movement, no throttle, etc. Also, motor has continuous beep.
I have tried other Rx's with three different motors, ESC combos and this same thing occurs. Batts are charged (i am not using a seperat Rx Battery could this be the prob?) I know that the ESC has internal BEC, as I another of the same.
My only conclusion is the Rx is bad.
Hoping someone might help
cmidnight is offline Find More Posts by cmidnight
Old Sep 16, 2012, 11:30 AM
lcm1977 is offline
Find More Posts by lcm1977
lcm1977's Avatar
United States, OH, Columbus
Joined Dec 2011
Did you do the procedure to bind the TX to the RX?
lcm1977 is offline Find More Posts by lcm1977
Old Sep 16, 2012, 11:42 AM
xmech2k is offline
Find More Posts by xmech2k
xmech2k's Avatar
United States, CA, San Diego
Joined Jun 2007
I'm stumped. The fact that you get lights on the rx confirms you at least could not have reversed the polarity of the throttle connection.
One thing comes to mind. The esc wants to see a low enough throttle position before it arms. It's possible either the throttle trim has to be lowered. Or even the throttle channel needs to be reversed.
That would not explain the other channels not functioning though. I would double check you have the servo wires plugged in the right way.
xmech2k is offline Find More Posts by xmech2k
Old Sep 16, 2012, 12:20 PM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
If you've tried several other receivers and you get the same problem every time why do you conclude that one particular AR400 receiver is bad ? It sounds to me a lot more like a fault with the transmitter or the technique you're using.
Are you sure the ESC is plugged into the throttle position ? Do you have the TX throttle AND TRIM low when you're doing the binding ? After the bind have you disconnected the ESC battery to fix the bind ? The continuous beep is usually the ESC telling you there's no signal from the RX and that's often because the ESC is plugged into something like a battery slot instead of the throttle slot.
Steve
slipstick is online now Find More Posts by slipstick
Old Sep 16, 2012, 12:52 PM
cmidnight's Avatar
Joined Sep 2012
My apologies on the typo! What I meant to say was that I have tried THIS Rx with the other combos and the same thing occurs. Also, I have no problem with the other Rx's binding to three different planes. It just seems to be this AR400.
Old Sep 16, 2012, 01:04 PM
Babadush is offline
Find More Posts by Babadush
Babadush's Avatar
United States, VA, Richmond
Joined Aug 2012
Does this RX have a satellite? If so Check the connections where the satellite connects to the rx. My insulation moved back a bit, the signal and ground wires were touching. This caused the same exact problem as yours. I put shrink wrap on both wires and now it works.
Babadush is offline Find More Posts by Babadush
Old Sep 16, 2012, 01:12 PM
cmidnight's Avatar
Joined Sep 2012
No, no sat.
Old Sep 16, 2012, 01:17 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
It is likely a dud - send it in they will send you a new one. They are really good about that.
I have 5 of them and this is a fluke.
Old Sep 16, 2012, 01:35 PM
Babadush is offline
Babadush's Avatar
Joined Aug 2012
No, no sat.
That's unfortunate then. Bad luck.
Old Sep 16, 2012, 01:44 PM
cmidnight's Avatar
Joined Sep 2012
That's what I thought! Just hoping that I may have missed something.
Thanks all for your input.
Glad to be part of the forum.
Old Sep 16, 2012, 04:58 PM
netdudeuk is offline
Find More Posts by netdudeuk
England
Joined Nov 2005
Ask here
netdudeuk is offline Find More Posts by netdudeuk
Help! Full throttle issue with servos acting up!! VIDEOPRO Power Systems 0 Jun 20, 2012 06:19 PM
Discussion Issues glitches with DJI Naza alexedit Multirotor Talk 8 Jun 16, 2012 05:41 PM
Discussion Real issues with KK v5.5 blackboard and Xcopter setup with JR radio chopperaddict Multirotor Talk 1 May 23, 2012 04:16 AM
Help! DJI Naza wind issue!!!! (help needed with throttle up issue in wind) Arxangel Multirotor Talk 11 Mar 07, 2012 01:47 AM
