Old Sep 16, 2012, 08:16 AM
bubbleman is online now
Find More Posts by bubbleman
bubbleman's Avatar
United States, TN, Cornersville
Joined Jan 2007
Eclipse 7 (72 Mhz) FunCub Flaps program
Help,
I need a way to slave a second channel to the CH 6 control. The FunCub requires that one flap servo be reversed.
Anton
bubbleman is online now Find More Posts by bubbleman
Old Sep 16, 2012, 03:12 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by bubbleman View Post
Help, I need a way to slave a second channel to the CH 6 control. The FunCub requires that one flap servo be reversed. Anton
Given the numerous set ups for one of those models, would need to know how other channels
are being used and which are still free.
All knowledge on mixes is available under:
Hitec Eclipse & Eclipse 7 Pro - All Manuals, Addenda, Quick Setup, CCPM and Additional Programming FAQ
However, rather than trying to slave a second channel, there are also several other methods to install
your MPX Funcub as shown on previous thread:
. Multiplex Easy Cub & Fun Cub - Aileron, Elevator & Flaps Installation
quote"
. Multiplex Easy Cub & Fun Cub - Install Aileron & Elevator - Video
note re video - see pic attached.
"Easiest general purpose solution:
"Multiplex Easy Cub & Fun Cub - Install Aileron & Elevator - Video"
. 3.35 minutes into video is highlighted "Flap Servos on a "Y" Connector".
This describes enlarging one hole sideways so as to flip the servo over and
mount flap horn further over to compensate, refer attached screenshot..
. Size the section of wing to be removed so as to glue as a filler in the original hole.
. Multiplex Easycub questions thread.
. Multiplex Easy/Fun Cub Aileron - pictures
. Differential - Mechanical set-up - Correct Dutch roll and Drag. "
This may also be of interest:
MPX Easy/Fun Cub Tailwheel Assembly & Replacement.
and more under
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
A.T. is offline Find More Posts by A.T.
Old Sep 16, 2012, 07:31 PM
bubbleman's Avatar
Joined Jan 2007
quote"
and more under
Alan T.
Allen,
Thanks for the well researched answer.
This is not my first FC. I have been flying one for 2 years. Have ail. dif set up mechanically. I had a pair of normal and reverse servos that I used on my flaps.
I have been on the FC thread and know the option of hacking on the wing
IMO a high end 7 ch radio that only allows a 4 ch wing to be setup in GLIDER mode is lame
My old Futaba allows any ch to any ch mix with no switch to flip and the trim is slaved as well.
The fellow that I am building this for had a "magic Y" servo reverser that he was not using, so I will use it off CH6.
ch assign will be
1 ail
2 ele
3 throt
4 rudder
5 tow release
6 flaps with reverser
7 not used
Anton
Old Sep 16, 2012, 08:07 PM
A.T. is offline
Joined Aug 2002
Allen,
I have been on the FC thread and know the option of hacking on the wing.
IMO a high end 7 ch radio that only allows a 4 ch wing to be setup in GLIDER mode is lame.
ch assign will be
1 ail
2 ele
3 throt
4 rudder
5 tow release
7 not used
Anton
Post #2 "Given the numerous set ups for one of those models, would need to know
how other channels are being used and which are still free. "
Mix Ch 6 to Ch 7:
Switch on the Eclipse 7. Depress both left hand Edit buttons at once
to enter the Set Up menu, then select "PMix 1".
Pull top left front switch forward to turn the mix "ON".
Use left or right cursor button to move flashing icon to set MAS to ch 6 and SLV to ch7.
To adjust throw in either direction, move flashing icon to the %,
then rotate knob left & right and adjust percentage.
[This is essential as Ch6 defaults to 30% - adjust ch6 in Set Up menu under "FLPT"]
Early Eclipse 7 did not have an extension on the ch6 knob. In need, drill and insert a small bolt
for easy finger tip operation. (Or acquire the later style knobs)
Alan T.
Old Sep 17, 2012, 06:00 AM
bubbleman's Avatar
Joined Jan 2007
Mix Ch 6 to Ch 7:
Alan T.
Alan,
Thanks again.
It is the switch to flip part that has me worried. I want to make this idiot proof. The switch in the wrong position will result in only one flap
Anton
Sold Corona RS410II 72 MHz Rx and GWS PICO 72 MHz Rx with two micro crystals $18 shipped CitizenKane Aircraft - General - Radio Equipment (FS/W) 2 Jun 08, 2012 09:23 PM
Discussion Funcub power and flap problems -james- Foamies (Kits) 2 Mar 22, 2012 12:58 PM
Wanted 72 mhz futaba 9c super , hitec optic 6, or hitec eclipse 7 grfcon Aircraft - General - Radio Equipment (FS/W) 2 Mar 16, 2012 05:54 PM
