Old Sep 16, 2012, 07:46 AM
SpaceAviation is offline
Find More Posts by SpaceAviation
Build and Fly!
SpaceAviation's Avatar
Philippines, NCR, Manila
Joined Sep 2012
Change Sun 70mm 10 blade EDF
hey guys.. help me on this..
i'm using Change Sun 70mm 10 blade EDF don't know what will i use.. i want a 2 kg thrust.. what ECS? battery and motor?
thanks!
Happy Flying!
SpaceAviation is offline Find More Posts by SpaceAviation
Old Sep 16, 2012, 03:14 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Here are some specs: for 2Kg thrust you may need more input power and higher rpm than is good for that fan (You may need well over 2000W)... even to get 1800W on 4s you need 128A... on 6s you need 80A.
ChangeSun 70mm 10-Blade Ducted Fan
product summary
• Meterial: fiber reinforced Nylon rotor
• Motor adaptor 2 set (4mm and 3.17mm)
• MAX 1800W
• MAX 52000 RPM
• Suitable motor 2300KV for 6S(not include)
• Suitable motor 3400KV for 4S(not include)
Cyclone power 3300kv on 4s lipo http://edfhobbies.com/index.php?rout...product_id=131
Cyclone Power 2500kv on 5s lipo maxx http://edfhobbies.com/index.php?rout...product_id=128
Disclaimer: EDFhobbies not responsible for burned up motors please read below....
FYI: These fans make a lot of power but, most motors can not handle the same cell count that they were designed for because 10 blades draws more amps than a normal 5 or 6 bladed fan. Its best to use a watt meter to see what the your combo draws. This is the only way to know that you will not damage your motor...
Example:
If your motor was designed 6s and you pair it with CS 10 bladed fan you probably going to have to run it on 4s to keep the amp draw manageable.
A NeuMotors 1527-2300Kv is rated for 2250W and 60,000rpm max. ... you might get near that with your fan at 100A on 6s
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Sep 17, 2012, 05:17 AM
Build and Fly!
Joined Sep 2012
is this okay??
Turnigy L2855 - 2100kv
6S 4500 25C
Vm: 21.86
Ap: 71.80
Wp: 1642.7
Thrust (Kg): 2.4
g/w: 1.46
Old Jan 22, 2013, 03:39 AM
sikky is offline
Find More Posts by sikky
speedin n da weeds :)
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
That 2100kv will smoke on 6s...
Edfhobbies 90mm 5s 2400kv 32mm 5mm shaft outrunner looks good for 6s... tams shaft adapters in a het fan shroud "stand off" wood spacer with a added 5mm bearing 450 heli 5mm main shaft $70 I have the shrouds ... standoff knive liddle style...
sikky is offline Find More Posts by sikky
Old Jan 22, 2013, 03:41 AM
sikky is offline
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
Big block ooooyeah!
Old Jan 22, 2013, 03:48 AM
sikky is offline
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
erh7771 | 27/11/2011
5lbs of bench thrust SETTLED, 80 amps, 4s 25c 3700mah Rhinos. 6.5lbs of bench thrust SETTLE the peak stuff), 100amps on 5s using 30c 5000m pack...did not hold heat on 10-20 sec runs. Fan starmax fan, well balanced with metal spinner W REALLY nice about this motor is it's weight or la with the starmax fan its 10oz total, it's also an outrunner...keeps magnets a little cooler IMHO
Try this one yet? I know you know you have the parts...
Old Jan 22, 2013, 04:01 AM
solentlife is online now
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
thanks!
Happy Flying!
Better if in EDF listing .... but anyway - no way Hosť .... it aint gonna do it.
2Kg is a LOT ! You may get 1.5Kg ... but in a model there are substantial losses as soon as you install. ie - my 70mm went from just over 1kg thrust to under 800gr when installed. OK it's not CS ... but even so - losses are there whatever edf you use.
Nigel
solentlife is online now Find More Posts by solentlife
Old Jan 22, 2013, 04:04 AM
sikky is offline
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
Bl32?
Old Jan 22, 2013, 04:06 AM
sikky is offline
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
Go here...
http://www.rcgroups.com/forums/showt...21248&page=412
Discussion Change Sun 10 blade 70mm (Test Results Consolidated) 901racer Electric Ducted Fan Jet Talk 193 Feb 24, 2015 12:34 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun 70mm 10 Blade EDF Twinkletoze Aircraft - Electric - Jets (FS/W) 5 Mar 01, 2012 03:50 PM
Sold New Change Sun 70mm 10 blade fan. Twinkletoze Aircraft - Electric - Jets (FS/W) 4 Feb 29, 2012 05:59 PM
Sold Change Sun 10 blade 70mm edf w/motor 420flyboy Aircraft - Electric - Jets (FS/W) 2 Dec 16, 2011 12:42 PM
