Old Sep 16, 2012, 05:18 AM
s.hantiu is offline
Find More Posts by s.hantiu
Joined Aug 2012
Flight time - can somebody explain me why?
So ... an Lipo battery have around 10 000 Mah @3S per 1kg (1000 grams).
So with an 1000 grams hexa multi rotor (Yea I didn't put the engine weight, the frame weight,etc) .... i can fly according to ecald around to 95 minutes: ....
http://s16.postimage.org/ptfkoojz9/10k.png
Now let's say i wish to fly out more, so i am going to put 10 batteries, each 10 000 mah @3S 900 grams each (those should be really good batteries)
http://s16.postimage.org/n0md4njmt/100k.png
Why I get only 34 minutes flight time this time?
How should I add new batteries, if I hunt for the best flight time I could and to not get this kind of problems?
I mean it's kind of weird... you add more batteries and you get less fly time... lol
s.hantiu is offline Find More Posts by s.hantiu
Old Sep 16, 2012, 05:26 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Heavier = more power to fly.
More power = less efficiency in the props and motors.
The bottom line in the report showing motor power, etc at hover is cut off.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Sep 16, 2012, 05:43 AM
s.hantiu is offline
Joined Aug 2012
Yeah heavier but also more batteries....so much more energy ...
Old Sep 16, 2012, 06:19 AM
pmackenzie's Avatar
Joined Dec 2002
If efficiency was not changed by the weight then it would fly longer.
But because efficiency drops if flies shorter.
Not that complicated
Old Sep 16, 2012, 07:20 AM
renatoa is online now
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
There is a formula, not having handy, but you insist I can resurrect it...
In this formula of efficiency, i.e grams lifted bu 1W of power, there is thrust involved... placed in the denominator! So, the more thrust, the less efficiency.
Btw, your estimation is much than optimistic... is unreal
Let's change no load current to a minimum 0.2A, as the best motors draw, and... you landed
renatoa is online now Find More Posts by renatoa
Old Sep 16, 2012, 07:56 AM
Jason Cole is offline
Find More Posts by Jason Cole
RCG Staff Member
Jason Cole's Avatar
United States, TN, Nashville
Joined Oct 2003
Here's a real world example for you. One of my Hexa's was only getting 4 minutes (with a little buffer room) on a 3S 4500. I wanted to see how much more time I would get by putting two of those in parallel. I only got 6 and half minutes with two. The extra weight and strain on the power system caused it to use more power more quickly. So I was better off flying two 4 minute flights instead of one 6 and half minute flight. Voltage can make a big difference too so my next step was to go to a 4S 4400 and I got 5 and half minutes. More voltage = less amperage for the same power output and longer flight times, so long as the voltage is within spec for the system. I couldn't put a 6S Lipo on it and get more run time because it would blow the system.
Jason Cole is offline Find More Posts by Jason Cole
Administrator
Old Sep 16, 2012, 08:59 AM
Joined Sep 2007
Let's illustrate with much numbers the example of Flyboone.
Assume one kg quad, powered from a 3s 2200mAh pack weighing 200 grams, and it's flying 10 minutes.
Because 10 minutes is 1/6 of one hour, this means the pack was discharged at 6C rate, thus a current of 2.2 * 6 = 13.2Amps
This led to a power consumption of 3(s) * 3.7V * 13.2Amps = 146.5W
This is the efficiency, 146.5W / 1.2 kg (1kh frame and 200 grams pack) = 122W/kg, pretty average.
The above are real data, rctimer DJI frame with 2830 850kv motors and 10*4.5 gemfan props.
Now assume we add a second pack of same capacity and weight.
New mass will be 1.4kg, thus new power consumption 1.4 kg * 122 W/kg = 171W
New current draw = 171W / 11.1V = 15.4Amps
New flight time = double capacity / consumption = 4.4 / 15.4 * 60 minutes an hour = 17.1 minutes, not 20 as expected !
Be aware that in above example I assumed the same efficiency in the both case, but this is not true ! The real flight time is even smaller, a bit over 16 minutes. I just wanted to keep things simple.
Old Sep 17, 2012, 06:23 AM
Zen09 is offline
Find More Posts by Zen09
Zen09's Avatar
Germany, HB, Bremen
Joined Jun 2010
Let me show you a bit of physics, proving why the maximum flight time for a given frame is obtained with a battery of equal weight (=1/2 of total weight).
Firstly, for a propeller we have:
thrust F = kt * p * d^3 * w^2
mechanical input power P = kp * p * d^4 * w^3
where p,d - propeller pitch and diameter, kt and kp - specific constants and w - angular velocity.
Playing with the 2 formulas we get:
F/P = kt*sqrt(kt)/kp * sqrt(p*d/F)
But we have a given frame(p,d - constant) therefore P = k * F * sqrt(F), where k is a constant that shows proportionality (from now on I'll use k to show that, but it'll not be the same k, meaning it will not have the same value), and its value doesn't matter.
Note that we have worked out P as mechanical power, we need to find out P(el) - that is electrical power drained by motors from the battery.
Now I'm cheating a bit, and assume that P(el) is not propotional to P(mechanical output) for an electric motor, but with P * sqrt(F). Meaning that the more we "push" a motor, the lower its efficiency (I know it's only half true). The term sqrt(F) might not seem to make much sense at this point, but we'll see later on that it drastically simplifies the demonstration.
So we write:
P(el) = k * F * sqrt(F) * sqrt(F) = k * F^2
Then F must be equal to copter weight (hover), which is (m+M) * g. M is frame mass(constant), m is battery mass and g - gravitational acceleration.
Therefore:
P(el) = k * (m+M)^2
Now, battery energy is proportional to its mass, E = k * m
Flight time is t = E/P(el)
Substituting P(el) we get t = k * m/(m+M)^2
After playing with inequalities, we find out that the expression m/(m+M)^2 has a maximum value of 1/(4*M) (remember that M is constant and m is variable), reached if and only if m=M. This means t is maximum when for the given frame, we choose a battery with m=M.
Feel free to give examples with real tests or ask questions about the demonstration.
Zen09 is offline Find More Posts by Zen09
Last edited by Zen09; Dec 07, 2012 at 02:38 PM. Reason: realized I had forgotten a term somewhere
Old Sep 17, 2012, 06:54 AM
Joined Sep 2007
Wonderful demonstration from a 18 years young, wish I had him as student in the 90s, when I was in high edu...
The confirmation above (true) theory can be seen in the graph below, from mikrokopter site.
As you can see, the flight time tops at 14.000 mAh lipo, whose weight is close to the 970 grams of frame. QED.
Old Sep 18, 2012, 03:09 AM
gitit20 is offline
Find More Posts by gitit20
gitit20's Avatar
Joined May 2012
Holey crap
gitit20 is offline Find More Posts by gitit20
Old Sep 19, 2012, 01:39 PM
Jem3 is offline
Find More Posts by Jem3
United States, OR, Portland
Joined Aug 2011
@Zen09 - excellent description, and @Renatoa - good find. Please cross-post them here.
http://www.rcgroups.com/forums/showthread.php?t=1284741
Jim
Jem3 is offline Find More Posts by Jem3
Old Sep 19, 2012, 02:13 PM
hawaiitaco is offline
Find More Posts by hawaiitaco
hawaiitaco's Avatar
Joined Dec 2010
my head just exploded
hawaiitaco is offline Find More Posts by hawaiitaco
Old Sep 19, 2012, 06:20 PM
CraigVMN is offline
Find More Posts by CraigVMN
CraigVMN's Avatar
Joined Apr 2012
You crazy kids and your new math
Just get one of these & stop worrying
CraigVMN is offline Find More Posts by CraigVMN
Old Sep 19, 2012, 06:22 PM
hawaiitaco's Avatar
Joined Dec 2010
3 hour flight time ....with the math hah
Old Dec 06, 2012, 05:05 PM
USU_ENGINEER is offline
Find More Posts by USU_ENGINEER
Joined Nov 2012
For your thrust calculation can you explain how you arrived at that formula? It seems that you get a value with units of [radians]*[m^3]*[s^(-2)] which is not a unit of force [kg*m*s^(-2)].
The formula I found on an MIT course page says that to calculate thrust it is the following:
T = kt * rho * n^2 * D^4
where kt is a constant, rho is the air density, n is the angular velocity and D is the propellar diameter.
http://web.mit.edu/16.unified/www/SP...es/node86.html
USU_ENGINEER is offline Find More Posts by USU_ENGINEER
Discussion RC transmitter ,receiver - Can someone explain to me ? noname2x DIY Electronics 10 Sep 13, 2012 11:34 PM
Question Can somebody help me solve a weird BEC issue? Piece Power Systems 12 Jun 13, 2012 01:43 AM
Discussion F3B chute to the line, can somebody help me tiju000 Multi Task F3X 24 May 03, 2012 09:40 PM
Discussion Can somebody explain this to me in English please? raythomas Glow to Electric Conversions 6 Apr 26, 2011 12:17 AM
Discussion somebody could explain me this? snow520lee Mini Helis 28 Aug 15, 2006 12:50 AM
