Old Sep 15, 2012, 09:30 AM
captain MoMo is online now
Find More Posts by captain MoMo
Mach One
captain MoMo's Avatar
Joined Apr 2011
Question
What is the correct elevator angle or setup
I built a FMS Cessna 400 and wanted to know what the correct angle is for the elevator and other controls. I have centered the servos and have made sure the controls are at zero position. However, the elevator does not seem to have adequate throw. Please help! Thanks.
captain MoMo is online now Find More Posts by captain MoMo
Old Sep 16, 2012, 02:19 AM
Butch777 is offline
Find More Posts by Butch777
Livermore, CA
Joined Sep 2004
All control surfaces should be level.
Usually the amount of throw is adjusted by moving the control rod into different holes on the servo arm and the control surface horn.
Butch777 is offline Find More Posts by Butch777
Old Sep 17, 2012, 03:12 PM
Mach One
Joined Apr 2011
Thanks Butch 777
I did the maiden flight and it was plenty controllable. I was amazed at how little it took? The air foil over the tail wings is super sensitive.....
Old Sep 23, 2012, 06:52 PM
ghosty is offline
Find More Posts by ghosty
aspiring noob
United States, CO, Denver
Joined Aug 2012
Ya 10 to 20 Degrees is good for most trainer and sport... 3d is closer to 45 to 60 degrees
ghosty is offline Find More Posts by ghosty
Old Sep 24, 2012, 05:03 AM
scruffy1 is online now
Find More Posts by scruffy1
looking up down under
scruffy1's Avatar
Australia, NSW, Fairlight
Joined Feb 2008
the "tail wings" are called the stabiliser (or stabilizer to usa)
the "airfoil" is actually the cross section of a wing or other surface, and as such can't be sensitive
but i get what you mean
scruffy1 is online now Find More Posts by scruffy1
Discussion Dual elevator setup with DX8 - use mix or program servos? Daedalus66 Radios 15 May 09, 2015 06:33 PM
Poll Elevator: Controls airspeed or Angle of Attack b36roxs Sailplane Talk 13 Aug 31, 2012 11:10 AM
Discussion Gimp 2.8 and GoPro wide-angle correction Jem3 Aerial Photography 3 Aug 15, 2012 02:40 PM
Discussion Correct Motor Mount angle? Mustang MadMan Modeling Science 10 Jun 27, 2012 02:39 AM
Question Steering SETUP? Right Turns Left Or Right Turns Right? Correct Setup? Mr. Miyagi Motorcycles 3 May 21, 2009 05:56 AM
