This thread is privately moderated by RHTizzy, who may elect to delete unwanted replies.
Old Sep 15, 2012, 05:14 AM
RHTizzy is offline
Find More Posts by RHTizzy
RHTizzy's Avatar
The Netherlands, NH, Bussum
Joined Feb 2012
PID's in practice
I found the seemingly best post on tuning PID's so far:
http://www.rcgroups.com/forums/showthread.php?t=1375728
After all I've read, I liken PID tuning to driving a car with a somewhat loose steeringwheel and wanting to change lanes: how much force to apply (P) to the steering wheel for how long (I) and how quickly (D) you need to make adjustments is basically what's needed to change lanes as smoothly as possible...
Tuning in short (much thanks to Shikra):
For Aerobatic flying:
Increase value for P until oscillations start, then back of slightly
Change value for I until until hover drift is unacceptable, then increase slightly
Increase value for D (remember, that means a LOWER number as it is a negative value - i.e. closer to zero) until recovery from dramatic control changes results in unacceptable recovery oscillations
P may now have to be reduced slightly
For stable flying (RC):
Change value for I until recovery from deviations is unacceptable, then increase slightly
Decrease value for D (remember, that means a HIGHER number as it is a negative value - i.e. further from zero) until recovery from dramatic control changes becomes too slow. Then Increase D slightly (remember - lower number!)
For stable flying ( AP / FPV):
You will have to accept a compromise of optimal settings for stable hover and your typical mode of flying. Obviously factor it towards your most common style.
RHTizzy is offline Find More Posts by RHTizzy
Discussion Adding weight, and adjusting the PID's accordingly... Foam boy Multirotor Electronics 1 Aug 01, 2012 09:20 AM
Sold Practically New 4S 14.8V Lipo's for Sale godofthunder77 Aircraft - Electric - Batteries & Chargers (FS/W) 5 Jul 27, 2012 11:56 AM
