Old Dec 16, 2012, 09:39 PM
Mike_Then is online now
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
I've been flying my Outlaw e-converted for several years now. I'm using a Hacker A40-16S motor, 5s 4000, Castle Ice 75, and an 8x8 prop. I don't think I'm getting 120 MPH speeds as I swear my FJU is faster but it's certainly no slouch. The Outlaw is heavy with that big pack. I'll have to check with Hacker to see if that motor is 6s capable and maybe prop down a bit.
Mike_Then is online now Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old Dec 16, 2012, 09:45 PM
bigmoebbq is offline
Find More Posts by bigmoebbq
bigmoebbq's Avatar
United States, GA, Atlanta
Joined Mar 2008
yea I was not going for stupid fast just some easy flying. I may get another one and get with C/F mike to get the carbon add on.
bigmoebbq is offline Find More Posts by bigmoebbq
Old Dec 16, 2012, 10:28 PM
Mike_Then's Avatar
Joined Apr 2001
I guess he's the one I got the carbon tunnel from. Channels air right over the battery and the components come down cool.
Old Jan 18, 2013, 11:45 AM
gregory.da is offline
Find More Posts by gregory.da
ProBro, 3D
gregory.da's Avatar
United States, FL, The Villages
Joined Jul 2008
Hey guys, I've been following this thread and just picked up a rebuilt Outlaw to convert to e-power. I used to have one with an OS32SX glow motor and it hauled the mail pretty well and I would like to get about the same speed on my e-setup. Any updates on e-power setups? Are you guys happy with the 2820's or is the 3542's giving more speed? It seems to me as you go to bigger motors and batteries there is going to be a trade off in weight vs. speed.
gregory.da is offline Find More Posts by gregory.da
Old Jan 18, 2013, 12:02 PM
bigmoebbq's Avatar
Joined Mar 2008
mine and Herc's go about 120mph. I like this setup as it is fast reliable and does not require many mods.
Old Feb 04, 2013, 07:36 AM
bigmoebbq's Avatar
Joined Mar 2008
Well after the Frosty and a few flights last week i have killed yet another motor.
So after burning up 2 of these http://www.hobbyking.com/hobbyking/s...50kv_700W.html
I am looking for a better option. Anyone got any suggestions. This is a setup that I had in my MPX Blizzard that ran flawlessly for a long time. However I think that my Extreme Flight outlaw is heavier so it is killing my motors. Need a replacement that is no wider , but could be longer. Right now I am running it in a 9x9 prop on 4 cells. Maybe I just need to prop down to a 9x7? I would lik eto stay at 4 cells so I dont have to buy another battery.
Old Apr 13, 2013, 09:52 AM
ProBro, 3D
gregory.da's Avatar
Joined Jul 2008
Time to revive this thread!
BigMo/Chris, I'm just getting around to starting my e-conversion on my Outlaw. I'm going to try the:
Aerodrive SK3 3542-1185kv motor.
Turns: 10T
Voltage: 3~4S Lipoly
RPM/V: 1185kv
Internal resistance: 0.024Ohm
Max Loading: 49A
Max Power: 730W
Shaft Dia: 5.0mm
Bolt holes: 25mm
Bolt thread: M3
Weight: 141g
I'll start with 4s and then move to 5s if it holds up. If it doesn't work, I'll either go with either an Eflite 25-1250kv, a Motrofly, Hacker, or the EF Torque Chris (Herc) is using.
I'll let you know how it goes, once I get the conversion done and maiden it.
Old Apr 27, 2013, 05:04 PM
ProBro, 3D
gregory.da's Avatar
Joined Jul 2008
Where is everyone on this thread???
BigMo, I finally got around to maidening the e-powered Outlaw yesterday. Using the Aerodrive SK3 3542-1185kv motor it flew great! No issues with the power system. Not as fast as my .32 glow engine but it should be close once I get the optimum prop/battery combo. I used a 9x6 for the first few flights just to get used to it again. I need to check my amp draw before I go up to a 9x9 APC prop. I'm using 4s-4000mAh and will test the amp draw on 5s down the road if my esc can handle it. I'm only using a 60A with separate BEC currently and might need to go up to a 85 or 100A if I go 5s. Engine and ESC were not even warm after the flight, so I should have some room to experiment. I flew four flights before it got to dark out. I had to lower the aileron throw on low rates and up the expo, I forgot how touchy the ailerons were. Lots of smiles and lots of compliments! Anyway, it flew great, decent power and handled great. Later, DG
Old Apr 27, 2013, 09:21 PM
bigmoebbq's Avatar
Joined Mar 2008
well I switched mine over to a Eflite power 25. It worked great on 4 cell9x7.5 prop. However I got hungry and tried a 9x9 prop and over amped and it cut off and I flat landed a little hard. I need to repair it now. I will since they are now out of stock.
Old Apr 27, 2013, 09:42 PM
dano02vfr is offline
Find More Posts by dano02vfr
dano02vfr's Avatar
USA, OR, Oregon City
Joined Sep 2004
Hacker A40 10S
I have this Hacker A40-10S laying around I thought I'd try in mine. Do you guys think this will have enough snot using 4000 6S?
Thanks!
Dano
dano02vfr is offline Find More Posts by dano02vfr
Old May 02, 2013, 11:07 PM
ProBro, 3D
gregory.da's Avatar
Joined Jul 2008
Dano, send Mike a PM, maybe he can let you know what he liked/disliked about his setup (similar to yours except for the motor kv). 6s might require the carbon fiber tunnel conversion that C/F sells due to pack height.http://www.rcgroups.com/forums/showt...2#post13280080. Let us know how it turns out, nice to have options.
" Dec 16, 2012, 10:39 PM
Discussion Extreme Flight Outlaw - Electric Conversions
Posted By Mike_Then
... 'm using a Hacker A40-16S...
... 'm using a Hacker A40-16S motor, 5s 4000 ... "
Old May 02, 2013, 11:14 PM
ProBro, 3D
gregory.da's Avatar
Joined Jul 2008
BigMo, 6 flights now on the Aerodrive without issue using the 8x6 APC (cool to touch). Soon I'll be trying a 8x8 or 9x9 APC. If I don't burn it up, I'll step back to 9x6 and try 5s The 9x6 on 4s is zippy and keeps you on your toes, about like the OS25 glow I originally used, but not as quick as the OS32sx glow motor/mousse can pipe setup I upgraded to. DG
Old Jun 08, 2013, 05:04 AM
simonbull1 is offline
Find More Posts by simonbull1
Netherlands
Joined May 2010
Message to CF
hi i have sent you a paypal payment of 30 dollars for carbon mod for extreme flight outlaw it would be nice if you responded by email
jerk
simonbull1 is offline Find More Posts by simonbull1
Old Jun 15, 2013, 07:15 PM
ProBro, 3D
gregory.da's Avatar
Joined Jul 2008
Best to send him a private message, not sure he monitors this thread. Also, not sure if you are calling him a jerk, or if that is your nick name (signature). If it's the first, I don't think that will help move things along for ya. Just sayin'
Old Jun 20, 2013, 02:52 AM
Netherlands
Joined May 2010
i did that he never answerd after i sent him 30 bucks by paypal
looks like he dropped of the planet with my money and no answers to pms since
Sold Extreme Flight Outlaw Webra .32 and pipe RTF with your RX LPU VT millerhill Aircraft - Fuel - Airplanes (FS/W) 4 Sep 07, 2012 06:34 AM
For Sale extreme flight outlaw ecoliburger Aircraft - Fuel - Airplanes (FS/W) 3 Aug 22, 2012 05:18 PM
Sold Extreme flight electric outlaw harrymc Aircraft - Electric - Airplanes (FS/W) 2 Apr 12, 2012 06:22 PM
Sold Extreme Flight Outlaw 50%plane Aircraft - Fuel - Airplanes (FS/W) 1 Mar 26, 2012 10:20 AM
Sold Extreme Flight Outlaw Electric Eyefly Aircraft - Electric - Airplanes (FS/W) 3 Dec 30, 2011 11:00 AM
