Sep 14, 2012, 02:08 PM
United States, WA, Seattle
90mm Composite BAE Hawk and 90mm Composite L39
Hello!
So I do not have any more of the PNP BAE Hawks. I do have (1) ARF BAE Hawk and (1) ARF L-39 Albatros for sale.
These are both new in the box and are in good cosmetic condition. However they are both missing parts.
The BAE Hawk is missing the tube that goes behind the fan that directs the thrust out the back. The (2) inlet tubes are both there though.
The L-39 is missing the hinges that normally come in the kit.
Please note that the ARF kits do not come with ANY Electronics, Fan unit or Retracts.
BAE Hawk $175 plus shipping.
L-39 Albatros $200 plus shipping.
BAE Hawk Description Below:
This famous jet trainer model consists of a precisely molded fiberglass fuselage, spray painted in an eye-catching color trim from the RAF 90th Anniversary. The well crafted fuselage brings out true scale outline of the Hawk. Solid and light construction with take-off weight only around 2.6~2.8 kg, it provides almost full power of thrust and results in a very responsive model. Additional features also include flap design that efficiently lowers landing speed and increases general stability. Easy access and a very neat compartment for the ducted fan setting is featured to help ultra fast installation. Motor, ESC, EDF, and Servos. All you need to do is supply your own radio and a few of your time to get this scale model up in the air.
Landings are remarkably easy for a jet. With the use of Flaps, this model is a very stable and easy aircraft to land.
Wingspan: 1140mm
Length: 1220mm
Weight: 2600-2800g
Wing Area: 24 dm/2
Wing Loading: 108-116dm/2
Not included:
EDF Unit 90mm
ESC
Servo 1.5kg Digital micro servo (Tower Pro MG90S 23 x 12.2 x 29mm) 8 pcs
Retracts Retract system w/scale landing structs 1 set
L-39 Description Below:
The Aero L-39 Albatros is a high-performance jet trainer aircraft developed in Czechoslovakia during the 1960s. The Albatros, as the most widely used jet trainer in the world, is versatile and seeing duty in light-attack missions as well as in basic and advanced pilot training.
Our model features a precisely fiberglass moulded fuselage and built-up wings, spray painted in matt finish to achieve the maximum realistic appearance. Scale touches include moulded wing tanks and authentic markings. The model delivers an incredible attention to detail and it also gives you the option of pushing the speed envelope even further by adding pneumatic or electric retracts.
Specifications:
Wingspan: 1200mm
Length: 1323mm
Weight: 2700-2800g
Wing Area: 29.2dm/2
Wing Loading: 92.5-96dm/2
Flaps
NOT Included:
Radio System: 4-6 Ch., 6-8 Servos
ESC: 70-80A
Duct Fan System: 90mm Duct Fan
