Old Sep 14, 2012, 12:24 PM
Mark DiMonte is offline
Find More Posts by Mark DiMonte
Richmond Hill, Ontario Canada
Joined Nov 2003
Losi Mini T brushless motor size.
Hi all. I want to put a brushless motor in my Mini T. any suggestions ? I have a 30 amp speed control and will by new lipo batteries as well.
Mark DiMonte is offline Find More Posts by Mark DiMonte
Old Sep 14, 2012, 04:31 PM
10x8 is offline
Find More Posts by 10x8
Cookie
10x8's Avatar
Australia, NSW, Petersham
Joined Sep 2005
I put a little Razor RZ300 in my slider and VW. 20mm motors. Tiny bit of work to mount it. 2mm shaft, around 4800kv on 2s, sometimes 3s, lol.
10x8 is offline Find More Posts by 10x8
Old Sep 14, 2012, 05:10 PM
rcphreak is offline
Find More Posts by rcphreak
in memory of dez RIP
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
6500 kv and lower and 2 cell lipos or it will turn into not only an uncontrolable rockett but also a regret as you will burn out trans gears and diff units like theres no tomorrow . some will say different but cant say i didnt warn you .
rcphreak is offline Find More Posts by rcphreak
Old Sep 17, 2012, 07:14 AM
Joined Nov 2003
Thanks guys. I will look into motors and post my possibilities.
Old Sep 18, 2012, 01:30 AM
Evil Twin is offline
Find More Posts by Evil Twin
Evil Twin's Avatar
Joined Feb 2004
What is the goal of going brushless, higher speed, better acceleration or longer run times than stock? That will help determine how many turns/KV for the brushless motor. I haven't worked on a mini-t, but the stock motor is a 370. Be careful choosing the brushless replacement to make sure the length and width will fit the space, some brushless motors are a bit longer. Also make sure the shaft size and mounting holes are the same or you'll need to get a new pinion or have a tough time mounting it. I like the Tacon 2030-21T 4300KV, it's ~$15 and it has fairly close to the same dimensions as a 370. The shaft size is the same as a 370 so a stock pinion will fit and it has two sets of mounting holes, 2 of which are close to the same width as a 370. I had to file the motor mount holes a bit to get it to fit my pro-pulse/megapro. Below are the measurements I took of the mounting holes for the Tacon and a stock 370. The Tacon 2030-21T 4300KV is a bit faster than a stock 370 with the same pinion but has a longer run time and barely gets warm. If you want more speed go with a lower turn/higher KV motor, Tacon 2030 comes in 19T, 18T, 15T also.
Tacon (2 sets of mounting holes)
inside of holes 14mm (16.5mm on center)
inside of holes 12mm (14.5mm on center)
stock 370
inside of holes 14.5mm (17mm on center)
For 'Inside of holes' I measured between the inside edges of 2 mounting holes
Evil Twin is offline Find More Posts by Evil Twin
Old Sep 18, 2012, 07:13 AM
Joined Nov 2003
Great advice. Thanks. Where did you buy the Tacon 2030 ?
Old Sep 18, 2012, 10:17 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
^^ www.hobbypartz.com
wparsons is offline Find More Posts by wparsons
Old Nov 14, 2012, 10:20 PM
Joe Friars is offline
Find More Posts by Joe Friars
Joined Nov 2007
I got one of the ez-run combo's from Hobbypartz. I opted. For the 18t version.
Fit right in set up was easy and yes I stripped the gears in the tranny first time I got in the grass! (I was running on a baseball diamond.) I just ordered a set of metal gears. This should help with the increased power and my poor driving.
Joe Friars is offline Find More Posts by Joe Friars
Old Nov 15, 2012, 07:31 AM
Joined Nov 2003
Thanks. I will look into it.
Old Nov 19, 2012, 02:59 PM
elvill is offline
Find More Posts by elvill
Eugene, Oregon
Joined Apr 2009
here is what I did with my Mini t clone, Novak 4600 25amp, 2wd monster truck madness sometimes better than 4wd control
Edit: Im a huge fan of the mamba competion 1/18 esc+motor combo 8600 on 2s - amazing top end, little spendy. cheaper combos HK et al are the better value
elvill is offline Find More Posts by elvill
Wanted Losi micro t 1/36 or desert truck brushless or mini t 1/18 Constantino 2007 Cars - Cars and Parts (FS/W) 3 Nov 25, 2014 04:17 PM
Mini-Review Losi Mini 8ight Review/ Mini 8ight T? (Truggy) KrazyKoots Off-road Cars 1 Jun 03, 2012 09:31 AM
For Sale Losi Mini T and Asc RC 18 T mewert Cars - Trucks and Parts (FS/W) 0 Jun 02, 2012 07:25 PM
Sold 1/36 losi brushless system 10250kv micro t ect....15 shipped motor is bad rc4life85 Cars - Accessories (FS/W) 0 May 11, 2012 08:18 AM
Sold Losi mini t, losi micro t, losi 1/24 rally pics now 190$ for all 3 custom t Cars - Cars and Parts (FS/W) 5 Dec 11, 2011 04:49 PM
