This thread is privately moderated by prodriverex, who may elect to delete unwanted replies.
Old Oct 10, 2012, 01:07 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Let me know if you need anything..
Thread is cool..!
Dialfonzo is offline Find More Posts by Dialfonzo
Old Oct 10, 2012, 09:58 PM
prodriverex is offline
Find More Posts by prodriverex
The Engineer
prodriverex's Avatar
Singapore
Joined Dec 2009
Definitely! Thank ya!
prodriverex is offline Find More Posts by prodriverex
Old Oct 10, 2012, 10:33 PM
The Engineer
Singapore
Joined Dec 2009
No load full throttle, 3.31A only, 53W
Firing up the Quadrotor v2 for the first time(1) (0 min 9 sec)
No load zero throttle, 0.13A 1W:
Firing up the Quadrotor v2 for the first time(2) (0 min 11 sec)
Motor and throttle sensitivity test.
All 3 motors spun but the last one seems less sensitive.. even at 1/2 stick, its still hesitating.. have to punch past 1/2 stick to get it going.
Also the direction seems wrong. I did follow the diagram starting with motor 1 at top left, then go clockwise 2, 3 then 4. The signal also, 1 goes to M1 and the rest followed all the way to 4 to M4.
Ha in the background is my 2nd princess..
So I guess I need to switch the signal cable to corresponding movement..
Old Oct 12, 2012, 06:08 AM
The Engineer
Singapore
Joined Dec 2009
Last 2 days was just revising my understanding of the firmwares avails.
There are so many variants for reflash on the KK+.. finally ironed out the unworkable Controller v4.7X and changed to Copter v1.1.. and the 4 motors spin in unison!
Gonna charged up the batts tonight and test tomorrow! Props up now.. here's a teaser:
Old Oct 12, 2012, 06:10 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
[] http://i41.photobucket.com/albums/e274/prodriverex/Quad%20Rotor%202%20Built/IMAG2022.jpg[/img]
Hi,
I didn't read all the thread so maybe you answered that question before.
But did you ever look at MultiWii controller..?
That's my own...
Old Oct 12, 2012, 06:20 AM
The Engineer
Singapore
Joined Dec 2009
Nope I have not. Worth to explore later. Can switch our the KK for learning new language. I will need a more advance FC for the next Octopus. Am considering Zero UAV.
Old Oct 12, 2012, 06:23 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Nope I have not. Worth to explore later. I will need a more advance FC for the next Octopus. Am considering Zero UAV.
What do you have in mind as "advance" featutre.
Multiwii does have many sensors and GPS now.
It's just not that easy to setup since you need to upload a arduino sketch in the controller.
Old Oct 12, 2012, 06:25 AM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
very clean! hope the CF tubes stand up. and the MWC FC is a good choice too
sirbow2 is offline Find More Posts by sirbow2
Old Oct 12, 2012, 06:49 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
As sirbow2 said, my worry would also be on the tube.
if they can move it will oscillate and that will cause you problem .
but hey... Put that frame in the air and you will see.
Old Oct 13, 2012, 12:23 AM
The Engineer
Singapore
Joined Dec 2009
I just couldn't resist the urge to push the stick today.
Tried a few times to calibrate the throttle range but to no avail.
Turned the Yaw pot clockwise and also tried anti clockwise.. wait for it to beep twice and also three times before quickly pull down the throttle stick, but just didn't get any feedback beep in return.
Anyway, push up the stick gradually and I can see its trying to lift off with a slight left yaw and pitch back.
Bigger problem is the springy skis which was bouncing like crazy and I think that affected the gyros a lot.. I will show video later for a retake..
Old Oct 13, 2012, 12:30 AM
The Engineer
Singapore
Joined Dec 2009
Few projects in mind.
For the bigger AP, I need full autonomous take off and landing. # of waypoints have not decided but most important is RTH under few scenarios. Autoheight as well.
For the smaller one, I need GPS with unlimited waypoints and indoor guidance system. Terrain following as a challenge maybe? It's long shot..
Old Oct 13, 2012, 10:22 PM
The Engineer
Singapore
Joined Dec 2009
Good day folks..
Here's the video taken yesterday for the inaugural first flight test.. maybe i should rename and call it ground acceptance test..
First Flight Test of prodriverex's Quadrotors v2 (12 min 13 sec)
Welcome all input.. TIA
Old Oct 13, 2012, 11:30 PM
sirbow2 is offline
Emress
Joined Nov 2011
dont tease me like that!! haha.
put it up to 1/4 throttle (do esc range calib first) and then throw a little piece of paper over each blade. you can see which way the motor is pushing air (two could be up and two down = no lift).
the legs should be no issue when you have the full throttle range.
img: http://www.mugi.co.uk/img_tut/dx7_1.jpg
the top red boxes are mode 2. elevator (pitch) is on the right side on the up and down movement. you want to push the far right trim thing up, if you need forward trim. BUT what you have is too extreme, something else is wrong. (see above?)
at 7:26, i see it went up a bit. that is obviously oscillation; you need to turn down the P/Pgain
Old Oct 14, 2012, 12:11 AM
The Engineer
Singapore
Joined Dec 2009
i tried but the beep didn't feedback at all. I followed the instruction from the manual.. Turn the Yaw pot anti clockwise, Turn on Tx, to full throttle, turn on FC, wait 2 beeps, some say 3 beeps, then down throttle to zero.. Then there will be confirmation beep..
Nope, the ESC turn on with 4 beeps to cfm there 4 lipo, then 2 tone to end the init process.. Whether i down the stick at any time during init, there is no effect on the throttle ranging.. How?
i will trim the correct one again.. Let me remove be legs first..
Old Oct 14, 2012, 12:51 AM
The Engineer
Singapore
Joined Dec 2009
Ah ha.. I read again on http://rcexplorer.se/page14/kkguide/kkguide/quadx.html
I try this time with the pot turned to clockwise max..
Turn ON Tx, full throttle, Power up FC.. I notice the green LED flashing very fast for a short period as if signaling to me it has talked to the TX and agreed on the the low and high points! Lol..
Then there was silence.. No startup beep whatsoever.. I just pull the stick down and the usual init beeps followed.. I guess, its done? Turnigy Trust 55A ESC and KK.. Hmm.. I hope its done. Can't fly until the new ski comes in.. So break for the moment and work on Octo ver 1!
Sold Align 3GX Ver 1.2 Upgraded to Ver 2.1 $70 Shipped 737 Driver Aircraft - Electric - Helis (FS/W) 1 Jul 19, 2012 08:29 PM
Sold walkera 2801 pro ver 2.3. * reduced* Jon.M.Barter Aircraft - Electric - Helis (FS/W) 0 Jun 15, 2012 05:54 PM
Sold walkera 2801 pro ver 2.3. * reduced* Jon.M.Barter Aircraft - General - Radio Equipment (FS/W) 0 Jun 15, 2012 05:51 PM
Sold hobbyking quad board ver 1 hallstudio Aircraft - Electric - Multirotor (FS/W) 1 Jan 02, 2012 04:07 PM
Discussion RCAP Ver 1.1- Ver 2 Development. hihptsi UAV - Unmanned Aerial Vehicles 33 Mar 21, 2008 12:28 AM
