| Thread Tools |
| This thread is privately moderated by prodriverex, who may elect to delete unwanted replies. |
Saw this great tip about prop balancing especially if you are building one craft for AP.
Unbalanced prop causes the video to show waves literally..
Electrical Work
Now that the frame and motor mount and motor is done.. time to move up the base and think of how to mount the ESC.
My design believe in having a low CG and all components should concentrate to the middle as much as possible. Even my base plate is very small at 100x100mm for a 750mm Quad. So to reduce wire and cable clutter, I want to formulate my own PCB to carry those power. So the idea came from http://hackaday.com/2008/07/28/how-t...gle-sided-pcb/ Its interesting to learn that one can laser print onto practically any flat surface, literally.. But instead of meddling with pungent chemicals, i decided to adopt my own method.. Here's the PCb plan on drawing: ![]() S that means, we can employ the same manner to transfer these lines onto a sheet of copper! Voila! But which paper or foil to use? I suppose using the aluminum foil looks better as I can see how the print out will turn out.. But before I can do that, I think it may sense to reverse the color like this: ![]() Reason is simple. the track should be clear of any printing so we do not need to clean it off later. The portion to be cut away will be printed instead. Then off to print direct onto the aluminum foil.. I tried out both dull surface and shiny surface, the effect is the same.. ![]() ![]() Now cut away those tape that held the foil to the paper and remove slowly taking care not to crisp the foil. I realise to print it very nice, always use a super nice and flat foil without any lines.. try.. The foil i had in hand was a lousy one, it was thinner than usual.. Now slowly flip it over and lay the foil with the printed side, down to the copper sheet. You can see the print did almost an embossing on the foil.. this is before ironing.. ![]() Tips. Now, you gonna move that iron around so better tape down the foil too. But do not use plastic tape. I happen to have aluminum film tape so it came in useful.. Then I place the sheet on a flat surface like an acrylic sheet top with a thick but firm cardboard.. I lay a smooth cloth like a shirt over it so that my iron can slide smoothly.. ![]() Turn the iron to the hottest and lets do it! ![]() After 3-4 minutes of moving the iron around making sure it covers all the area.. Remove the hot iron.. remember to turn it off.. wait for the copper sheet to cool.. you can put it in front of a running fan to cool it faster.. And once cool enough to work on, peel the foil away slowly. Here's are the results: This is with less than idea flat foil without lines.. ![]() This is from a nicer foil, almost perfect without lines. ![]() You can see the importance.. I will cut the bull short, than i just trim the printed portion with a big strong pen knife.. ![]() To be continue.. |
| Thread Tools | |
| Sold Align 3GX Ver 1.2 Upgraded to Ver 2.1 $70 Shipped | 737 Driver | Aircraft - Electric - Helis (FS/W) | 1 | Jul 19, 2012 08:29 PM |
| For Sale walkera 2801 pro ver 2.3. * reduced* | Jon.M.Barter | Aircraft - Electric - Helis (FS/W) | 0 | Jun 15, 2012 05:54 PM |
| For Sale walkera 2801 pro ver 2.3. * reduced* | Jon.M.Barter | Aircraft - General - Radio Equipment (FS/W) | 0 | Jun 15, 2012 05:51 PM |
| Sold hobbyking quad board ver 1 | hallstudio | Aircraft - Electric - Multirotor (FS/W) | 1 | Jan 02, 2012 04:07 PM |
| Discussion RCAP Ver 1.1- Ver 2 Development. | hihptsi | UAV - Unmanned Aerial Vehicles | 33 | Mar 21, 2008 12:28 AM |
