Old Sep 14, 2012, 09:28 AM
Twinboom is offline
Find More Posts by Twinboom
Semper Fidelis...........
Twinboom's Avatar
Madagascar, Toamasina, Atsinanana
Joined Dec 2003
October Meeting
The October meeting will be at my place. Usual times. See you there.....
Doogie
I did not put the date in. Looks like the 3rd Thursday is the 18th.
Twinboom is offline Find More Posts by Twinboom
Old Sep 27, 2012, 07:30 AM
Twinboom is offline
Twinboom's Avatar
Joined Dec 2003
To trail, or not to trail....edge........
Hey Gents, not to shock the h e doublesticks out of you, but I have been doing some work on my 190 wing. The trailing edge is not quite as sharp as usuall. I will post some photo's this evening when I het home. How can I build it up/out, and make it a goor fix?? Carbon rod then sanding it to an edge? Enquiring minds.
That will be my topic, and hands on repair/fix discussion for the meetin in October. Hope too see you all there.
January is around the corner, IMS show?? New photo's for the booth? Are we even doing it?
Any other topics, keep your thinkoing caps on.
Anyone in the club want the Lancair fuse and new cores, let me know, if not, it will be going in the RCGroups classified this weekend.
Doogie
Rick, I will call you this evening around 9:00 p.m.
Old Sep 29, 2012, 03:39 PM
Twinboom is offline
Twinboom's Avatar
Joined Dec 2003
So, anyone out there, rebels or not, ( ie Target ) have any ideas on my trailing edge issues???? The wing has a 16" chord, 70" ws, and it is a 374 foil I believe. Thanks for any thoughts.
Doogie
Old Sep 30, 2012, 01:13 AM
sarmoby is offline
Find More Posts by sarmoby
Composites guy
North OC, Ca.
Joined Jun 2005
Doug-
Carbon or even a hardwood should work I should think. I assume you would then glass over it to get it covered.
Do you need any materials?
What happened to the lancair? Looked like it was making progress. Can we gang up on it during the next meet and get it chuckable? Carl helped me before the last meeting and made good progress.
I was working on repairing planes this week( should have cleaned the garage instead...).
Hope to have plane for the fest. More than one so I can crash mor often.
Scott
sarmoby is offline Find More Posts by sarmoby
Old Oct 01, 2012, 05:38 PM
MicroRotors is offline
Find More Posts by MicroRotors
3D Toy Designer
MicroRotors's Avatar
USA, CA, Hesperia
Joined May 2001
Doug,
A 1/8" trailing edge on a wing that size is fine. It's not a high speed plane so don't worry about it. If you are, ... just put a small piece 1/8 x 3.16 piece of basswood or even balsa, but don't make it a knife edge. Don't worry about glassing it either, just tack it on with a few drops of CA and then put a small amount of west systems on it. It will seep in to the grain and the gap.
Glassing it would be overkill. Besides, it's the trailing edge of the wing, ... If you hit it, ... you'll have bigger fish to fry than your trailing edge.
In very simple terms (and not completely technically correct), a sharp trailing edge wants the air from the top surface and the air from the bottom surface to meet at conflicting angles. This does not happen in real life, so you find the air separating from the surfaces before it reaches the trailing edge. This separation is not terribly stable and can cause some fluctuations in the flow that results in heavy, but variable control forces. By cutting the trailing edge flat (blunt), you create a pocket of "dead" air behind that allows a place for the two flows to join together without separating form the upper or lower surface. The blunt trailing edge is also easier to build, structurally stronger, and less prone to damage.
Bill
MicroRotors is offline Find More Posts by MicroRotors
Latest blog entry: My New Toy!
Old Oct 01, 2012, 06:54 PM
Carlski is offline
Find More Posts by Carlski
Team member-One day PSS Build!
Carlski's Avatar
Joined Sep 2003
So Doug, he is trying to tell you to be blunt and not to the point!
Carlski is offline Find More Posts by Carlski
Old Oct 01, 2012, 07:20 PM
sarmoby is offline
Composites guy
North OC, Ca.
Joined Jun 2005
Sand it square.....
"puttin the Boom in Twinboom since......"
Scott- of the clan Resin
Old Oct 04, 2012, 10:22 PM
TFLG is offline
Find More Posts by TFLG
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
I'de glue a long razor blade to it, just in case some out of control dauntless tries to ram you from behind!
TFLG is offline Find More Posts by TFLG
Old Oct 05, 2012, 12:13 PM
3D Toy Designer
USA, CA, Hesperia
Joined May 2001
Um, ... That would have the same effect as a 1974 Pinto trying to stop a Freight Train.
Old Oct 05, 2012, 06:50 PM
TFLG is offline
TFLG's Avatar
Joined Feb 2002
But if the pinto hits it JUST RIGHT........ nah, never mind, same result..
Old Oct 05, 2012, 11:14 PM
Twinboom is offline
Twinboom's Avatar
Joined Dec 2003
I love you man.........
Nothing like a whole club busting your twinsphere's.... aye yaye yaye.......
Doogie
Old Oct 06, 2012, 10:35 AM
3D Toy Designer
USA, CA, Hesperia
Joined May 2001
I was wondering if anyone would have caught on to that, ...
Old Oct 06, 2012, 10:37 AM
3D Toy Designer
USA, CA, Hesperia
Joined May 2001
Doogie
Well Doug, ... we could just could kick 'em for yeah!
Old Oct 06, 2012, 10:57 AM
Carlski is offline
Carlski's Avatar
Joined Sep 2003
Boom Boom baby!
Old Oct 10, 2012, 04:46 PM
masson74 is offline
Find More Posts by masson74
Dave Massongill
masson74's Avatar
yucaipa, ca
Joined Dec 2003
I know I have been out of the loop for quite a while guys. I wanted you to know that I dont have a way to tow the porta pots anymore in plenty of time to find someone that has a truck with a hitch before the fest.
attached is the contact info for the people we have always rented the porta pots from. when things calm down with my Lyme and work I will hopefully get back to flying and building. I do miss it quite a bit.
Dave
masson74 is offline Find More Posts by masson74
Fly-In Curry's Lake Flyers Fun fly and Swap Meet October 13th, 2012 bob865 Fuel Power Events 4 Oct 12, 2012 08:21 AM
Swap Meet Curry's Lake Flyers Fun Fly and Swap Meet October 13th bob865 Fuel Power Events 3 Oct 09, 2012 04:25 PM
October Meeting Artsloper Inland Slope Rebels 6 Oct 18, 2004 09:29 PM
Blugrass EDF jet meet October 16&17 Chris True Electric Flight Events 1 Oct 11, 2004 08:20 AM
Rc Driver Tuner Meet October 22 – 24, 2004 Hobby Chamber On-road Cars 1 Oct 08, 2004 02:29 AM
