Test run engines in plane
I took the plane up to the field one afternoon just to test run and set up the engines in the plane and check out the TwinSync settings as this was not used on the test stand. The engines are giving a good idle at around 1800rpm, I could go lower but want to get confidence first. They are peaking at 5,000rpm on one engine and 5,400rpm on the other as they still need to loosen up a bit. They are both giving very good throttle response with no sign of oiling up and dying at low rpm – the TwinSync comes with onboard glows which really help to keep the RCVs firing at tick over. Just after finishing the one video the tank ran dry on one engine and gave the TwinSync a test although I had not planned it, the TwinSync took the running engine to idle as per expectation, so I know the system works.
Also shown here after some requests are photos of the cooling baffle with the engine installed to give an idea of how well fitting the air scoop is, taking the air from the front inlet and up over the fins and then down the back and out over the exhaust. A video walk around with the engines running can be found at
A video showing the engine throttle response with the TwinSync working can be found at
Maiden flight
The final bits and pieces involved installation of the batteries in the nose cone. As I had left all the nose formers in place I had to cut a series of rectangles and install a box. Then came installing the switches for the batteries and painting the spinners red. When all was completed there were no excuses left. It is ready for flight, some 4 years after buying the kit and 3 1/2 years after starting the build.
The weather forecast was for a gentle 10mph wind straight down our runway. Once ready both engines were running well from 2,000rpm to 5,300rpm. Then it was time for some trial runs down the field to see what the ground handling was like. It has a tendency to swing left but nothing that could not be controlled by starting the run with some right rudder and then the gyro held it and the manual input could be eased off. The thrust these RCV engines can put out is phenomenal, there was no shortage of acceleration and I knew it would take off OK. Back to the pits to refuel and take stock, then out to the strip again. Right rudder, hold the elevator up to keep the tail down, start push the throttles forward to just over half, planes rolling, release the elevator to allow the plane to come onto its main wheels and loose the offset thrust (P factor) turning it to the left, ease off on the right rudder and tracking as straight as a die, push the throttles full forward, wait for the extra burst of acceleration to reach full speed, bleed in a bit of up elevator and she’s up, gently climbing away, engines on song, raise the gear and the speed builds up some more, few clicks of aileron trim, ooops it is quite sensitive, more sensitive than I expected given the throws are not huge, gentle inputs only. Landing was without flaps and a bit fast and bouncy but no issues really. First flight was just to get the measure of the plane, right and left circuits and figure eights only. There is no problem with the weight it flies magnificently. The RCV60SP engines are good but the flight is between half and full throttle and I have the engine curves set so this truly means between 50% rpm range (3,500rpm) to max (5,300rpm). Flaps and wheels do not seem to affect the flight trim much, I have a little flap to elevator trim set. On the next flight I started experimenting a little more with the flight envelope – large wingovers look truly impressive, fast low passes, twin engines in sync – brilliant. The landing caught me a bit off guard though and I was too slow and it dropped the last 2ft, split the undercarriage mounts from the ribs and punched it up through the sheeting. Damn, I knew before I started these flights that I would have to keep the speed up, not too bad to fix and one day I will learn to keep the speed up with this type of model. Now I have flown it some more I can say that it is a very easy plane to fly once it is in the air, the controls are well balanced, the plane tracks very smoothly and consistently, a real pleasure to fy. A video of one of the early flights (not the maiden) can be found at
SOCAL
Joined Jul 2006
Yes the Mosquito is a compact airplane. I noticed that the seats are staggered so the pilot and JAFO don't bump shoulders. Also pilot has more armour plate in the seat so you know who's important..........http://www.mossie.org/images/W4050/d...ajd_d5_003.jpg
Probably needed a slender person well under 2M to crawl through to the bombsite. http://www.mossie.org/images/W4050/proto_int_10.jpg |
Bruce |
