This thread is privately moderated by daign, who may elect to delete unwanted replies.
Old Sep 14, 2012, 02:15 AM
daign is offline
Find More Posts by daign
Trader Rating: 22
My RC builds in my profile.
daign's Avatar
Joined Feb 2011
Trader Rating: 22
Sold
Bambucopter Mini Y6 FPV Frame with A1510 Motors, Simonk ESCs, SMD Leds
New build, Only PID tuned. Never flown outside. $250 shipped
I built this frame to replace my flat hexa FPV rig, but decided against the Y6 Configuration due to noise. It sounds like a tie fighter! I tested motor redundancy and this frame will fly with one motor/prop out with minimal flight characteristic changes. I was impressed.
It is very nimble, capable of picking up a 4000mah 3s and a gopro HD at the same time no problem. Lots of lifting power. Extra standoffs between plates added at the end of the arms to reduce vibration.
Comes with:
1x Bambucopter Y6 Classic Frame for FPV made from Laser cut 2mm quality UV filer policarbonate material
6x Suppo A1510 2200kv motors from Altitude Hobbies
6x Hobby Lobby eRC Rapid Drive Simonk 12a ESCs
2mm Bullet Connectors to make moving your components from frame to frame.
All ECS soldered to one solid strip of wire, then liquid electrical taped, then sheathed to keep everything neat with the clear frame.
1x 6 LED SMD 5050 White panel up front pointing down.
1x 6 LED SMD 5050 Red panel in back pointing down.
6x CNC 2.0mm Billet Prop Adapters
3x Gemfan 5x3 CW Props
3x Gemfan 5x3 CCW props
1x EC6 Connector for 2650mah 3s to 4000mah 3s sized batteries.
Extra JST connector wired in for LEDS etc running 12v.
Extra Futaba Connector running 12v for Hitec SPC ports or auxiliary power.
Photos from tonight. Gopro, Coptercontrol not for sale or included!
If you are in need of a flight controller I have the following flight controllers for sale as well:
http://www.rcgroups.com/forums/showt...0#post22729890
I will also be selling my Y6 Bolt Hexa by quadframes.co.uk with motors/escs as well.
daign is offline Find More Posts by daign
Old Sep 14, 2012, 05:01 PM
mcashatt is offline
Find More Posts by mcashatt
Trader Rating: 47
mcashatt's Avatar
United States, AZ, Gilbert
Joined May 2012
Trader Rating: 47
Gorgeous. Wish I had the budget for it!
mcashatt is offline Find More Posts by mcashatt
Old Sep 27, 2012, 10:21 PM
daign is offline
Trader Rating: 22
daign's Avatar
Joined Feb 2011
Trader Rating: 22
Anyone?
Old Sep 28, 2012, 05:04 AM
Sid3ways is offline
Find More Posts by Sid3ways
Trader Rating: 39
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Trader Rating: 39
Any onboard video of the GoPro? How did you combat the vibes with what looks like minimal isolation?
Sid3ways is offline Find More Posts by Sid3ways
Old Sep 28, 2012, 05:24 PM
daign is offline
Trader Rating: 22
daign's Avatar
Joined Feb 2011
Trader Rating: 22
Never mounted the gopro its just sitting there for reference. The frame was too small for most of my FPV gear (all 1.3ghz) and it sounds like a tiefighter which is cool, but not too cool when flying at night around the yard...
It flew with minimal drift with CC3d once I added the outer standoffs, I also have rubber grommets under the cc3d from the start. I suppose I could mount up the gopro and make a vid.
I never mounted a Naza to it but I may if it wont sell. I have one on my Bolt Y6 right now and it flies well.
NOTE: NO CC3D is for sale with this setup.
Old Sep 30, 2012, 05:08 PM
MrDusanmandic is offline
Find More Posts by MrDusanmandic
Trader Rating: 47
Closed Account
Joined May 2011
Trader Rating: 47
Interested in any type of trades?
MrDusanmandic is offline Find More Posts by MrDusanmandic
Old Sep 30, 2012, 07:35 PM
daign is offline
Trader Rating: 22
daign's Avatar
Joined Feb 2011
Trader Rating: 22
like? PM me.
Discussion LadyBird Qr SMD Led's mod, even more led's to come! croyal918 Multirotor Talk 6 Jan 13, 2014 07:15 PM
Discussion Bambucopter Mini Y6 FPV build daign Multirotor Talk 0 Aug 19, 2012 05:00 PM
Sold HT-FPV frame prewired with LED's Hockeymonkeymark Aircraft - Electric - Multirotor (FS/W) 3 Aug 04, 2012 11:25 AM
For Sale foxtech FH-800 frame, simonk flashed escs and Motors. vewdew Aircraft - Electric - Multirotor (FS/W) 0 Jul 11, 2012 03:21 PM
Sold HK micro PCB Quad frame with led's and motors, and a Micro 2 servo Camera mount!!! tc3wins Aircraft - Electric - Multirotor (FS/W) 3 Apr 28, 2012 10:45 PM
