Taiwan, 北市
Joined Dec 2010
And the Pico Stick is 36" span with a narrower chord, also, Pico Stick -F came with a foam fuselage. Add a setup (2208 or 400 size outrunner + ESC20A + prop 9x5 + 2S lipo) on it, you could fly it outdoor in winds. But adding reinforcement under its wing is required.
Using 3S lipo instead on the same set up could power Slow Stick well. One of my buddies put a 450 size 1000KV outrunnder instead last weekend, he only applied half throttle for take off, and 1/3 for flying level. |
Australia, QLD, Tewantin
Joined Jul 2012
Thanks for all the input, much appreciated.
I'm trying to keep my 'power trains' standard, so was wondering if the below would be a good choice for the Slow Stick. http://www.twistedhobbys.com/Power-C...-RCF-30-32.htm Cheers |
cheezels, I agree with aurorae here. The motor you linked would be better suited for the Pico stick with a small 2s lipo, The Slowstick could fly with it, but it would be sluggish and hard to control on a windy day. The stock brushed motors for the SS are 60-70 grams, so getting the CG right can be tricky with a small motor. I suggest a larger motor with a lower kv.
Joined Jul 2012
OK, bit new to choosing motors, esc's and props etc.
Would this do the trick? http://www.hobbyking.com/hobbyking/s...dproduct=24529 http://www.hobbyking.com/hobbyking/s...dproduct=27884 http://www.hobbyking.com/hobbyking/s...idproduct=9846 Cheers |
Taiwan, 北市
Joined Dec 2010
The motor comes with an aluminum cross mount, but it does not fit the stick fuselage of either Pico Stick or Slow Stick. The SS fuselage is 10mm square fiber-glassed one, you might need a GWS black plastic mount that fits the 10mm stick well. Probably the SS kit includes such mount for you.
The prop you posted might not work well if you apply a 3S lipo with the motor, better to use a harder one, GWS EP9050 or EP8040 or APC hard one instead. |
Joined Jul 2012
OK, thanks for all the help.
Is this the kind of thing? http://www.hobbyking.com/hobbyking/s...ount_20mm.html and will this fit the motor?? http://www.hobbyking.com/hobbyking/s...dproduct=24529 Cheers |
| Thread Tools | |
| Sold GP big stick 60 kit | AintQytRite | Aircraft - Fuel - Airplanes (FS/W) | 3 | Sep 04, 2012 09:20 PM |
| Free gws slow stick kits box of at least 8 | MIKEYOUR | Free Items | 8 | Apr 28, 2012 11:33 AM |
| Sold Bud Nosen A&A Kits For Sale! Citrabia, Trainer $200.00 ea. Giant Big Stick $175.00 | stevster | Aircraft - Fuel - Airplanes (FS/W) | 4 | Apr 07, 2012 08:40 PM |
| Sold *RARE* MIDWEST GIANT SWEET N' LOW STICK Kit NIB $225.00 FREE SHIPPING!! | stevster | Aircraft - Fuel - Airplanes (FS/W) | 4 | Apr 02, 2012 12:34 AM |
| Sold Trade a (NIP)Radical R/C Mini Stick kit (V2) for a (NIP) Radical R/C Micro Stick kit | phoneguy | Aircraft - Electric - Airplanes (FS/W) | 3 | Oct 27, 2009 09:41 PM |
