Old Sep 13, 2012, 10:37 PM
szewang2805 is offline
Find More Posts by szewang2805
Joined Dec 2006
Alert
HOBBYWING SKYWALKER QUATTRO RC Model 20A x4 Brushless Speed Controller ESC
On Sale Now, Only USD 32.9 + Shipping on HobbyHot.com
Hobbyhot ship this item worldwide.
http://www.hobbyhot.com/HOBBYWING-SK...ESC-SL011.html
June 15th, 2012, famous brushless ESC manufacturer Hobbywing released the world`s first 4in1 20A high performance brushless ESC--Skywalker Quattro 20Ax4-UBEC, this ESC is suitable for multirotor aircraft, and four-motor airplane or four-propeller ship model. Integrated design can not only offer better consistency, but also simplify wiring complexity, so as to improve work reliability.
MultiRotor Flyer has been very popular as a new generation of RC model aircraft, which is simple structure, light weight and easy to fly. However, as there are four motors in the four corners, normally there are four ESCs to control each motor, which is complicated to assembly and set up. Since HobbyWing has developed the SkyWalker-Quattro-20A ESC, problems will be solved.
The SkyWalker-Quattro-20A ESC combines four 20A ESCs together, useable with 2~4 LiPo cell packs, it also has a 5V/3A BEC inside. Four motors now can directly connected to the ESC, no more complicated wiring stuff or set up procedures.
The SkyWalker-Quattro-20A ESC combines four high performance 20A ESC and 5V/3A UBEC, wherein the ESC is based on standard PWM control signal. This SQ20A4U has absolutely strong compatibility, which can work with most FC and radio set. Each ESC can separately perform throttle trip correction and other work parameter setting. The default parameter could satisfy most application requirements.
Specifications
Model: Skywalker Quattro 20Ax4-UBEC
Cont. Current: 20Ax4
Burst Current (>10s): 25Ax4
BEC Mode: Switch mode
BEC Output: 5V/3A
BEC Output Capability: 2S Lipo (5 Servos), 3S Lipo (5 Servos), 4S Lipo (4 Servos)
Battery Cell: Lipo 2-4S, NiMH 5 - 12 cells
Weight: 112g
Dimensions (L x W x H): 70 x 62 x 11mm
Features
4 speed controllers in 1 board, only 1 pair of battery wire is needed.
Powerful switch mode built-in (the BEC voltage outputs from the S3 connector).
Multiple protection features: Low voltage cut-off protection / over-heat protection / throttle signal loss protection.
The throttle range of each ESC can be calibrated to be suitable for different multi-rotor flying control systems / transmitters.
Maximum speed: 210000 RPM (2 poles motor), 70000 RPM (6 poles motor), 35000 RPM (12 poles motor).
szewang2805 is offline Find More Posts by szewang2805
Reply With Quote  (Disabled)
Old Sep 13, 2012, 10:39 PM
tlrascal is offline
Find More Posts by tlrascal
United States, AR, Lavaca
Joined Aug 2002
Available for less.
These are selling elsewhere for less.
tlrascal is offline Find More Posts by tlrascal
Old Sep 13, 2012, 11:39 PM
DaxFX is offline
Find More Posts by DaxFX
Play tetris with my english
DaxFX's Avatar
Puerto Rico, San Juan
Joined May 2008
can you tell me where to get one at good price ! thanks
DaxFX is offline Find More Posts by DaxFX
Old Sep 18, 2012, 08:30 PM
Joined Dec 2006
try to buy at hobbyhot
Discussion Hobbywing 20A Skywalker Quattro 20Ax4-UBEC koolkiwikat Multirotor Talk 113 Feb 14, 2016 12:22 AM
Mini-Review Review: Hobbywing Quattro Skywalker 20A ESC TS00 Multirotor Electronics 85 Dec 13, 2015 05:30 AM
Discussion Hobbywing SKYWALKER ESC Quattro 20AX4 Speed Controller superek4 Multirotor Electronics 2 Aug 15, 2012 11:56 PM
Sold 4x Hobbywing Skywalker ESC 20A ($25 Shipped) readerror67 Aircraft - Electric - Multirotor (FS/W) 2 Aug 02, 2012 04:21 PM
Wanted hobbywing skywalker 20A jy0933 Aircraft - Electric - Multirotor (FS/W) 0 Jun 28, 2012 06:39 PM
