This thread is privately moderated by speedactyl, who may elect to delete unwanted replies.
Old Sep 13, 2012, 10:19 PM
speedactyl is online now
Find More Posts by speedactyl
Scratchbuild Aviation
speedactyl's Avatar
Philippines, NCR, Makati City
Joined Jun 2012
Speedactyl PX22-A
Speedactyl PX22-A
Succesor To Speedactyl Jet
update :
Changes:
EPP Material
an more sweptback wings may give a WS of 36inch
Addition of Ailerons
minor changes to the nose section
better structural materials
move back the motor Aft of the Main Wing to reduce noise and turbulence unless you want to grab attention
Lighter electronics
may try a different color scheme
setup
Tunigy 2211-2300
2s 350mah AUW 280g
2s 800mah AUW 300g
73.8 Prop on 2s
54 Prop on 3s
the PDF
PX22_A Maiden on Sept 09 2012
The maiden went pretty well performance came as close to my old bird except the ailerons no work . Since it’s a lighter plane compare to the original it handles more forgiving.
Grand fanally is the powered nose dive in to the ground by accident .. And survive to fly again in a few mins. Damage just minimal . A small fracture on the side but not that critical. thanks to the internal reinforcement in the nose cone and a lighter AUW
for those who want give this bird a try : Note: the plans are just reverse engineering drawings from the completed plane. since I build this plane w/o plans
PDF Drawings for those who want to give this bird a try
just share your pics or Vids when ever. thanks
speedactyl is online now Find More Posts by speedactyl
Old Oct 29, 2012, 05:10 PM
Tsavah is offline
Find More Posts by Tsavah
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Speedactyl PX22-A
That one is going to be tricky to remember, so I had better subscribe. Thanks for sharing.
Tsavah is offline Find More Posts by Tsavah
Latest blog entry: Center of Gravity - Airplanes
Old Oct 30, 2012, 03:29 AM
speedactyl's Avatar
Joined Jun 2012
: works on most 2s or 3s setups 200g - 300g AUW
Old Nov 16, 2012, 03:11 PM
balsa or carbon is offline
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
Nice design ! Do you have a flying video ?
balsa or carbon is offline Find More Posts by balsa or carbon
Old Nov 17, 2012, 06:25 PM
speedactyl's Avatar
Joined Jun 2012
Non yet no, videographer during its maiden. But will post when ever on the next flight
Old Nov 17, 2012, 06:29 PM
speedactyl's Avatar
Joined Jun 2012
px22 RC pusher Jet (philippines) (2 min 42 sec)
sofar this is the video of the older bird taken from a cellphone
Old Nov 18, 2012, 07:35 AM
speedactyl's Avatar
Joined Jun 2012
K image of the recent flight PX22A
as promise here Video
PX22A Speedactyl (4 min 3 sec)
Old Nov 18, 2012, 09:20 PM
speedactyl's Avatar
Joined Jun 2012
an update note:
put BBQ sticks or CF rod from the Fuse to the nose in the internal Layers that way it wont snap off on hard landings , also the nose section is wrap with packaging tape before the 5mm EPP skin is apply.
notice ailerons would apply when your wings are stiff full span ,in the video I only did 60% span thats why the flex creates an dihedral effect contributing to roll stability
battery is mounted by cutting a hole on the fuse section aft of the nose section and is line with 2 more BBQ sticks
also the bottom of the plane is mounted with a bottom EPP 5mm as skid plate to hide the electronics
Note: ive upgrade to 1300kv bluewonder 3s 8x3.8prop for maximum performance
OCT 23
after several flights and testing ,finally got its Livery
Old Feb 12, 2013, 03:21 PM
ggrimley is offline
Find More Posts by ggrimley
ggrimley's Avatar
United States, SD, Rapid City
Joined Dec 2011
Looks like a great project... will defiantly be on my build menu... but not until i get my taxes Done...
Thanks for sharing...
ggrimley is offline Find More Posts by ggrimley
Old Feb 12, 2013, 06:59 PM
speedactyl's Avatar
Joined Jun 2012
finally tested last feb 10 2013 weekend
Note: ive use 1300kv bluewonder downgrade prop to 6.5x4 prop and put an 2s
still flies ok its just the CG went back a little on a lighter battery.
slower flights and tighter turns ,great for smaller fields
not the most recommended setup since its slightly underpowered
also the Dihedral is cause by the wing flexing and not intentionally force upwards. which gives extra stability since I fly on 3ch on this
Old Sep 08, 2013, 05:35 AM
speedactyl's Avatar
Joined Jun 2012
Re-Visit with some old pics of Speedactyl PX22 & Speedactyl PX22-A (px29)
PX-22A (7 min 30 sec)
Old Jul 12, 2015, 11:39 PM
speedactyl's Avatar
Joined Jun 2012
Refit as of July 2015
its like having a new bird but still the same old bird
Old Jul 13, 2015, 01:44 PM
Tsavah is offline
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Speedactyl
I am sure it attracts kids like eye candy.
Old Jul 13, 2015, 07:55 PM
speedactyl's Avatar
Joined Jun 2012
Stands out better in the RC field as a in field avatar/signature.
tells people im in the field.
im sure the refit would improve structural and control handling
servos are move to the tail for shorter control rod, the tail is now conventional . While the twin boom added extra 9mm foam.
well a closer view of the changes . you can apply on to the original pdf plans , this an simpler improve configuration.
