MORE PROGRESS! But wait... how can you progress on something that is done... Easy!
YOU START ANOTHER ONE! lol
Tom's center section is officially started:
I applied the mold release agent, then left to flash off for the allotted time. After that, the molds flanges were taped off to keep the paint off of them, then the primer was applied to the mold surfaces:
That is all for Tom's center section. The paint needs to dry for abit and then the layup schedule will be put in..
For myself, I did some of the work retrofitting the DLE-55RA to the FW-190, I hope to have this done by the end of the week and its shipping crate built so it can begin its journey to its new home starting next week.
For my Horton, I pulled it out of the trailer to do some inspecting to it..
One of the inner flap servo's is burnt out so i will need to replace that, and other than some grass and dirt stains, the outer wing panels suffered no damage.
The center section is structurally un-damaged and again, other than grass and dirt stains and gear door damage, the center section is fine. The ESC mystery remains a mystery. Normally anytime i've seen an ESC fail and catch fire its capacitors were popped, these are still fine, but all the mosfets are shot. so much so, the two boards have separated themselves. I"m pretty sure the motor must of shorted out and caused the ESC failure, i plan to take the motor to work tomorrow and do some work on it to see what's up internally.
ESC picture:
And after cleaning some melted rubber, plastic, solder and random other ESC bits, the inner fiberglass layer shows no sign of damage, just discoloration and there is no loss of strength or stiffness in the area.
Anyone have any suggestions on cleaning out the black soot mess and getting rid of the smell?
