Old Jan 20, 2013, 01:12 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
yeaaa.... no way i'm trying to replicate wood on a composite surface, i'm not that good with an airbrush. lol i'll stick with this one as a fun scale flier and use the 335 for a comp. model
invertmast is offline Find More Posts by invertmast
Old Jan 20, 2013, 03:05 PM
pdawg is offline
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
No worries! Maybe someone will try this design in scale comp. BTW I've seen the full scale first hand at the Garber storage facility. You can't see wood grain except in areas of damage.
pdawg is offline Find More Posts by pdawg
Old Jan 20, 2013, 03:42 PM
pdawg is offline
Need 4 Speed!
pdawg's Avatar
Joined Apr 2004
A couple pics...
Old Jan 20, 2013, 04:08 PM
Joined Mar 2004
Maybe once they get a bit further along with whatever they are doing, then i may do a 2nd horton for myself and copy the smithsonians and then do a comp. model with it then.
Old Jan 20, 2013, 06:33 PM
velozzi is offline
Find More Posts by velozzi
Joined Jan 2013
It looks like the winter camouflage paint schematic... Is it?
velozzi is offline Find More Posts by velozzi
Old Jan 21, 2013, 09:51 PM
CarbonFlite is offline
Find More Posts by CarbonFlite
Closed Account
Joined May 2012
ETA of the first flight? I'm excited to see how it goes!
CarbonFlite is offline Find More Posts by CarbonFlite
Old Jan 21, 2013, 10:15 PM
Joined Mar 2004
Sunday.... Maybe
Old Jan 21, 2013, 10:28 PM
Closed Account
Joined May 2012
yeah!
Old Jan 21, 2013, 10:33 PM
gaexcalibur is offline
Find More Posts by gaexcalibur
gaexcalibur's Avatar
Port Orchard Washington
Joined Jul 2009
if you try you must post video
video video video
absolutely must have some video that plane is going to be epic flying
gaexcalibur is offline Find More Posts by gaexcalibur
Old Jan 21, 2013, 10:47 PM
datura is offline
Find More Posts by datura
datura's Avatar
United States, TX, Austin
Joined Dec 2012
I've been lurking here for a while... amazing build and I can't wait to see it fly!
May you have a windless day when the time comes
datura is offline Find More Posts by datura
Old Jan 22, 2013, 06:36 AM
Joined Mar 2004
we plan to video up, so everyone can quit begging for that. There is still much to do between now and sunday, so don't be surprised if it doesn't happen.
Old Jan 22, 2013, 07:02 AM
thtaco is offline
Find More Posts by thtaco
thtaco's Avatar
United States, VA, Timberville
Joined Oct 2012
Canopy
thanks to G&L Hobbies we have the canopys
thtaco is offline Find More Posts by thtaco
Old Jan 24, 2013, 09:08 PM
Joined Mar 2004
Well, got a bunch done over the past few days in anticipation of flying this thing on sunday.... if it doesn't snow tomorrow.
First up was getting the lower strut landing gear doors installed... ended up having some issues with the upper strut doors and had to remove those, but i'm going to try to re-install them on saturday:
Then got the outer wing panel attachment bolts drilled and tapped.. then I had one of these snap off, permanently attaching the right wing panels forward wing tube to the center section. Anyone have any idea's on remove a 4-40 bolt that is counter sunk about 1" Below the surface?
Then the nose gear doors were converted to electric actuation with a pair of HS82MG servo's:
Gear servo and valve installed:
All of the outer wing panel control surface linkages were completed. The hatch's cut and installed and all of the radio programming completed:
Then I cut out the holes for the wing panel servo extensions:
Then everything.... fan units, batter mounts, rx, match box's, gear sequencer, thrust tubes, all the extensions... yadda yadda yadda............ was installed and the outer wing panels put in place. Tom also dropped by this evening and we did a CG check... good news is, we'll be able to get it into CG with only 8 to 10oz of nose ballast needed... Anyways. here is a photo of all the Stuff needed in the nose to get it to CG ( four- 6s 5000 lipo's, 8oz Nicad battery, 2s2300 A123, 3s2300 A123).
The 3s2300 A123 will be replaced by another 2s2300 A123 battery for receiver power, and the 8oz Nicad battery was just used to determine how much nose weight was needed to get it into CG..
Old Jan 25, 2013, 01:06 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
The bolt-you'll need a piece of brass tube same dia as the hole.And a drill to match the inner.AND a screw extractor to match the drill!
Cut the tube so it sits just proud of the surface,and carefully drill( new bit) a hole as deep as you can.Remove the tube,use the extractor(different types,a common one is a hard steel taper with a left hand spiral)to wind out the bolt.I'll see if I can find a link your side,but most auto repair shops will have them.
http://www.lowes.com/pd_232656-1083-...5101&Ntt=screw
There you go-you just need a match with the drill/tube/extractor.
Scrap the above.My metric mind just woke up to how small these are-
http://www.mcmaster.com/#left-hand-drill-bits/=l6o4lj
A suitable size of these should do,same tube method.
Stuart
Stuart A is offline Find More Posts by Stuart A
Ho 229 Build northropn9m Flying Wings 154 Oct 22, 2009 05:42 PM
Building the Luftwaffe secret weapon - Horten Ho 9/229 XPHAM Electric Ducted Fan Jet Talk 107 Dec 15, 2005 01:31 PM
Ho 229 Tempest Electric Ducted Fan Jet Talk 0 Nov 05, 2004 03:39 PM
Jack Cooper's ho 229 (sting wing) mothflyer Slope 4 Sep 01, 2003 11:26 AM
Building the secret Luftwaffe weapon - Horten Ho 9/229 XPHAM Scale Kit/Scratch Built 14 Apr 01, 2003 08:26 PM
