Old Dec 29, 2012, 08:18 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
they supposedly have a one piece rotor coming out. perhaps you can inquire as to when you can get one (or two).
Rich
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Dec 29, 2012, 08:27 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
Originally Posted by Odysis View Post
You can weigh them. I can't remember the numbers, but the CS12 thread has a lot of discussion about the weak rotors.
Given your ability to pop out a mould in about 3.8seconds, could you just cast a quicky and make some carbon blades?
These rotors are the lighter (weaker) rotors.. From HK
I thought about a carbon rotor, but that is one thing that requires more work than i'm interested in doing.. to much match and smarts involved in making something that spins at 40k+ rpm's
invertmast is offline Find More Posts by invertmast
Old Dec 29, 2012, 08:28 PM
Joined Mar 2004
Rich
Yea I have been waiting and watching for when that happens, no one who really knows has said if it will be a direct replacement for the CS 90 12 blade rotor though.. Either way, i've found a replacement rotor stateside, hopefully i'll have it by weeks end.
Old Dec 29, 2012, 08:43 PM
Joined Mar 2004
Today's work started out with rough cutting out the exhaust tube outlets:
Then I finish sanded those to size/shape.
Then I made up the EDF mounting tabs. Epoxied those into place and mounted the EDF units.. its starting to get heavy now!
Then I started working on the battery and steering servo mount plates. First up I made the ply blank for the battery mounts. You'll see the corners have been cut out, these help locate the aft end of the battery plate side to side.
Then the mounts for this were cut from 1" aluminum angle. one piece of angle was notched to fit around the nose gear and bolted to the nose gear bulkhead. The other end was bolted to the backside of the forward carry-through spar. This strengthened that carry through spray up allot, so it was worth the time to do.
Test fit the plate:
Initial battery positioning thoughts:
Then my buddy Tom came over and we made a thrust tube...
Then we remounted the fan unit and attached the thrust tube to the edf unit:
Suggestion from you guys in the know.. You see I have my ESC inside the thrust tube. Due to its weight, it hangs down into the thrust efflux until the power is applied, then it kind of "floats" there. I have gotten it all bundled together as tightly as possible, but it still does the above. Would it be best to leave it like this, or just relocate the ESC outside of the thrust tube?
Then the steering servo hole in the battery plate was cut out and the mounting holes for the battery plate mount bolts drilled. the aluminum angle was also tapped as well for the bolts, and the batteries mocked up into position:
We also did a little tuft test to see what the air was doing over the bat tail area. It doesn't really tell us much (because its only one fan unit operating), except that the air isn't really swirling (rotating) much (if any). It gives a idea of the sound this monster will have though:
http://smg.photobucket.com/albums/v4...84B9F4D33C.mp4
Old Dec 29, 2012, 09:26 PM
Joined Jan 2009
it's fine in the tube. anything above 90mm is fine behind the motor. I would try and keep it as centered as possible though. most make a U shaped bracket that attaches to the stator section/center hub and that holds the ESC centered.
Rich
Old Dec 29, 2012, 09:29 PM
Joined Mar 2004
Alright, sounds good. Maybe I can make up some Zip-Tie support bracket thing for it
Old Dec 29, 2012, 09:31 PM
Joined Jan 2009
yup, that'll work.
Old Dec 29, 2012, 09:32 PM
Joined Jan 2009
I've seen some that are simply two plastic bars glued to the center hub and then the ESC is zip tied to the bars. simple and it works.
Old Dec 29, 2012, 09:58 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
man its looking awesome!
corsair nut is online now Find More Posts by corsair nut
Old Dec 29, 2012, 10:13 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
its Phsycadellic Man!
Keenan smith is offline Find More Posts by Keenan smith
Old Dec 29, 2012, 10:16 PM
Joined Dec 2010
Originally Posted by invertmast View Post
Those blades as supposedly weaker than the blade from another company. If it comes down to it, i'll order a new rotor from HK, but after this one had a blade snap just by tightening up the bolt, come tax time I'll probably end up going with a pair of Jet-Fan 90's
you probably got one of the bad batch then my CS-90 from HK's Rotor is Fine! (running 5-6s)
Old Dec 30, 2012, 01:24 AM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
You do not want the esc to just flop in the duct..put a stick down each side of the motor tube then zip tie the esc to them as you have posted above..if it moves around it can break a lead/wire off//but then I dont like to put them in the duct anyway..but that is me
turbonut is online now Find More Posts by turbonut
Old Dec 30, 2012, 05:41 AM
Boogie_ is offline
Find More Posts by Boogie_
killed another thread
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
I like to strip off the heat shrink and also remove the heat sink. Really lightens up the ESC.
You don't want it flopping around though, like turbo said, it will eventually break a wire. Use glue, zip ties, paste or bubble gum to attach a carbon rod or bamboo skewer (or 2) to the motor housing and zip tie the ESC to it.
It's also best if you can hang the ESC on edge instead of flat like you have it in the pics. It won't flop up & down as much.
...looking good, won't be long now.
Boogie_ is offline Find More Posts by Boogie_
Old Dec 30, 2012, 06:12 PM
FliteMetal is offline
Find More Posts by FliteMetal
FliteMetal's Avatar
Joined Mar 2009
3.5 Degree Negative Thrust Diflection...
Tom,
3.5 degrees should work fine. The B2's rectangular to cylinder then back to rectangular exhaust issues forced Chris Gold
to place a curved thrust diflector at the furthest most rearward point in the exhaust "trough". This loaded the airframe with
excellent flight results.
With the current amount of vertical space remaining above the current exit you can move outlet vertically to accommodate
additional diflection if required.
In our B-47's we are bifurcating the inboard nacelle and have a Jeti 300 sitting in the vertical stator blade the Dynamax is
mounted to. The entire blade and edf are removable from the pylon. This places the esc immediately behind the motor and
high velocity of the edf.
I am wondering what the thickness of your esc is and if it could be placed inline behind the motor to memic a vertical stator.
A side benefit to this is the axial flow is disrupted symetrically with the esc as a stator. You could move the position fore &
aft to see if doing so reduces axial even further...
We have considerably higher amps than you are dealing with and resulting temperature. This in my opinion negates your
concern for temp at the same time it helps straighten out the post fan flow....
FliteMetal is offline Find More Posts by FliteMetal
Old Dec 31, 2012, 12:52 AM
pdawg is offline
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
This is for you Thomas!
pdawg is offline Find More Posts by pdawg
Ho 229 Build northropn9m Flying Wings 154 Oct 22, 2009 05:42 PM
Building the Luftwaffe secret weapon - Horten Ho 9/229 XPHAM Electric Ducted Fan Jet Talk 107 Dec 15, 2005 01:31 PM
Ho 229 Tempest Electric Ducted Fan Jet Talk 0 Nov 05, 2004 03:39 PM
Jack Cooper's ho 229 (sting wing) mothflyer Slope 4 Sep 01, 2003 11:26 AM
Building the secret Luftwaffe weapon - Horten Ho 9/229 XPHAM Scale Kit/Scratch Built 14 Apr 01, 2003 08:26 PM
