Old Dec 26, 2012, 01:28 AM
Jon Snow is offline
Find More Posts by Jon Snow
You know nothing....
Jon Snow's Avatar
Joined Sep 2011
Here's one someone made earlier! That last pic reminded me of it.
Phenomenal work.
Stuart
Jon Snow is offline Find More Posts by Jon Snow
Old Dec 26, 2012, 10:54 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
Well i didn't do much today... I've got one of the EDF units dynamically balanced, and installed all of the blind nuts for the landing gear and bolted them back into place..
Anyone have any good idea's for ensuring the EDF unit is installed correctly so its Center line will exit at the center of the exhaust exit opening?
The only thing I can think of, is taking a piece of PVC pipe and modifying it so it will fit around the motor can and having it long enough to extend to the exit opening and go through a hole
invertmast is offline Find More Posts by invertmast
Old Dec 26, 2012, 10:55 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Not really needed. The air will bend as required - it's the exhaust itself you need to worry about.
Odysis is offline Find More Posts by Odysis
Old Dec 27, 2012, 06:14 PM
johntjg is offline
Find More Posts by johntjg
Joined Apr 2009
I mount a laser pointer to the back of the motor . The magnents will hold it to the motor can , and put a target on a template the size of the exhaust outlet on the rear of the jet and adjust the edf unit accordingly.
johntjg is offline Find More Posts by johntjg
Old Dec 28, 2012, 04:44 PM
Joined Mar 2004
Alrighty, today was the day of Inlet ring modding and installation..
Thanks to paul (tempest) I got the 2nd inlet ring i needed. Its a little bit different than what i've got, but i'm not waiting!
first up I needed to figure out a way of getting the motor shaft Center-line aligned with the center of the inlet and exhaust. Poking through the shop, i found a piece of 1 1/2" wing tube socket that was the exact same diameter as the motor. So the socket was squared up and taped to the back of the EDF unit and motor:
Then a 80mm diameter foam template was cut out with the center drilled out to 1/8". This will be used to make the tailpipe's as well. This was then placed on one exhaust exit flange and put into the correct position (I centered it with the mark 1 eye-ball). Then the 1/8" center-hole was drilled into the center section:
Then a ply template was cut to allow this center hole position to be transferred to the other side. And the 1/8" center hole drilled into the center section:
Then using a 1 1/2" Forstner bit, a hole was drilled for a 1 1/2" wing tube.. keep reading! It will make sense soon!
Then a wing tube was slid into the 1 1/2" hole. And the EDF unit with the wing tube socket put into position inside the wing. The wing tube was then pushed into the center section and into the wing tube socket. Once these were joined, the EDF unit was placed into the inlet, the inlet ring attached to the EDF unit, and then the inlet ring tack-glued with CA to the center section:
As you can see in the above photo's, the inlet ring becomes part of the center section and gives a nice smooth transition into the EDF unit. The wing tube socket and wing tube act as the alignment device to make sure the EDF unit's thrust line will exit out of the center of the 80MM cutout in the back, when it gets cut out.
After the inlet rings were tack glued into place, and the wing tube socket and tube removed from the motor can, you can look in the hole at the exhaust and see this:
A near perfect thrust line alignment!
Then the inlet ring to center section seam was taped over and a mixture of epoxy and cotton flock put around this seam on the inside of the center section. The inlet ring is part of the mounting system.
And then I spent about 2 hours Dynamically balancing one of the EDF units.
Old Dec 28, 2012, 06:19 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Nice!!!
Kevin Cox is offline Find More Posts by Kevin Cox
Old Dec 28, 2012, 06:30 PM
JimF is offline
Find More Posts by JimF
Ellington, Connecticut, United States
Joined Apr 2001
Unbelievable! Incredible work.
JimF is offline Find More Posts by JimF
Old Dec 28, 2012, 06:49 PM
Jon Snow is offline
Jon Snow's Avatar
Joined Sep 2011
Very nice.Necessity the mother of invention.
Old Dec 28, 2012, 08:17 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Nice work. If you look from the front into the duct does the rear of the fues cut up into the eflux area? not sure if you get what I mean ..On mine the tail section is very much in to the exhaust flow...So I cut the resess to go farther back and not be in the way of air flow
Old Dec 28, 2012, 08:20 PM
Joined Mar 2004
At first i was like "huh?" But now i understand!
Actually, i havent cut out the full size exhaust hole yet, but i dont think the rear end of recess/fuse transition interferes with the efflux column.
Old Dec 28, 2012, 09:05 PM
pencon is offline
Find More Posts by pencon
Joined Dec 2008
Looks great . Seems almost like you used my Idea about a rolled up cardboard tube to align the fan units ,Or maybe great minds think alike ..
pencon is offline Find More Posts by pencon
Old Dec 28, 2012, 10:57 PM
Joined Mar 2004
Well, as is typical for me lately, my luck has gone to Hell. If anyone has a spare ChangeSun 12 bladed 90mm rotor (or an entire fan unit, i don't care), let me know. The rotor got jammed onto the adapter on my 2nd fan unit during balancing and in the process of removed the rotor, one of the blades busted... Sooo now i'm one fan unit short.
Old Dec 29, 2012, 03:39 AM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Just buy some spare blades off of hobbyking (can't post a link because im on my phone)
Keenan smith is offline Find More Posts by Keenan smith
Old Dec 29, 2012, 08:20 AM
Joined Mar 2004
Those blades as supposedly weaker than the blade from another company. If it comes down to it, i'll order a new rotor from HK, but after this one had a blade snap just by tightening up the bolt, come tax time I'll probably end up going with a pair of Jet-Fan 90's
Old Dec 29, 2012, 09:03 PM
Odysis is offline
Joined May 2007
You can weigh them. I can't remember the numbers, but the CS12 thread has a lot of discussion about the weak rotors.
Given your ability to pop out a mould in about 3.8seconds, could you just cast a quicky and make some carbon blades?
Ho 229 Build northropn9m Flying Wings 154 Oct 22, 2009 06:42 PM
Building the Luftwaffe secret weapon - Horten Ho 9/229 XPHAM Electric Ducted Fan Jet Talk 107 Dec 15, 2005 02:31 PM
Ho 229 Tempest Electric Ducted Fan Jet Talk 0 Nov 05, 2004 04:39 PM
Jack Cooper's ho 229 (sting wing) mothflyer Slope 4 Sep 01, 2003 12:26 PM
Building the secret Luftwaffe weapon - Horten Ho 9/229 XPHAM Scale Kit/Scratch Built 14 Apr 01, 2003 09:26 PM
