Old Dec 16, 2012, 10:13 PM
invertmast is offline
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
Originally Posted by cpdude View Post
WOW!!! I might just need one of these!!
haha Brian... we can chat about that when I can find the time to give you a call! (hopefully tomorrow, i'm tired!)
invertmast is offline Find More Posts by invertmast
Old Dec 17, 2012, 09:19 PM
Joined Mar 2004
Pulled all the bagging, feed lines, etc off of the molded top part. Again it turned out pretty good... I'm begging to think the CF has a defect in it as there is another spot that appears to not have fully wet out either... but it is very stiff. It may just be some sort of contaminant on the surface of the CF... either way, off we go!
Then we tested the fit of the structure to the top half. We need to do a little bit of adjustments, but they fit pretty good. We also closed the mold halves together and they fit reallly good. The aft half didn't close completely, but that's due to the structure needing a bit of trimming. Wed. we are planning to get the structure layout and lightning holes finalized and then start installing all that stuff this weekend:
Old Dec 18, 2012, 12:42 AM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Lookin GOOD!
turbonut is online now Find More Posts by turbonut
Old Dec 18, 2012, 07:54 AM
MaHö is offline
Find More Posts by MaHö
MaHö's Avatar
Germany, BW, Stuttgart
Joined Dec 2001
Really good work invert!
Do you have a link on that material that is in your layup looking like hoenycomb?!
regards Martin
MaHö is offline Find More Posts by MaHö
Old Dec 18, 2012, 09:02 AM
Joined Mar 2004
regards Martin
Martin,
Acp composites sells a similar material under the name aero-mat
Old Dec 18, 2012, 11:12 AM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Invert,
Hopefully your experience with aeromat turns out better than mine...
pdawg is online now Find More Posts by pdawg
Old Dec 19, 2012, 03:23 AM
MaHö is offline
MaHö's Avatar
Joined Dec 2001
Thanks for the info!
regards Martin
Old Dec 19, 2012, 08:18 PM
thtaco is offline
Find More Posts by thtaco
thtaco's Avatar
United States, VA, Timberville
Joined Oct 2012
internal structure
After work today invert and I cut out most of the internal structure.
thtaco is offline Find More Posts by thtaco
Old Dec 19, 2012, 11:42 PM
minimicrorc is online now
Find More Posts by minimicrorc
Joined Apr 2012
wow
great job
minimicrorc is online now Find More Posts by minimicrorc
Old Dec 20, 2012, 11:13 PM
Joined Mar 2004
The first Horten is getting closer to being born!
Tonight I got the wing tube sockets epoxied and glassed to their carry-through spars/bulkheads. I also epoxied the main gear mount doublers in place. And I got started on designing the nose gear structure parts. I've got to wait for the nose gear to show up to verify they are long enough, but I'm pretty sure they are. They are also oddly shaped so you can get to the fan mount parts.. This big ole' center section is getting crammed pretty quickly with its guts..
Old Dec 20, 2012, 11:32 PM
Joined Apr 2012
FINISH IT BEFORE THE WORLD ENDS!
jk jk
take ur time and make it fly
Old Dec 21, 2012, 12:52 PM
Joined Mar 2004
While I wait for the firewood delivery, I went out in the shop and got some stuff done..
First up was cutting and epoxying all of the outer wing panel attachment bolt blocks into place on the carry through bulkheads. I'll drill and tap these blocks for a 4-40 bolt to hold the wings on after the halves are joined.
I then got the main landing gear plates aligned and epoxied that entire assembly of plates and ribs together. 1/2" tri-stock was placed in the corners for added strength:
And my buddy Tom brought over the Robart nose gear retract. So with the retract here and some slight modifications to the nose gear structure, It is ready for install. We have decided to wait to install this till after we join the halves due to it possibly interfering with the canopy frame openings, which may require it to modified again..
So, now that everything is essentially complete, tomorrow we close the mold halves!
Old Dec 22, 2012, 12:44 PM
Joined Mar 2004
OH YEAAAAAAAAA!!!!!!!!!!!!!
Only about 20 hours till we seperate the mold halves and have the first 229!
Old Dec 22, 2012, 12:47 PM
pdawg is online now
Need 4 Speed!
pdawg's Avatar
Joined Apr 2004
Sweet! It looks great Invert. Talk about a nice holiday present!
Old Dec 22, 2012, 12:50 PM
Joined Mar 2004
That it will be... as long as it all come out good!
We are thinking of doing a twin 90 or 120mm EDF ME-262 next. I'll use a set of Bentley drawings so it is extremely accurate, and possibly a fiberglass fuse and stuff. We need to do some figuring on the size and power system, but i'll be posting up a poll in the next few weeks or month to see what kind of interest there is.
It may even just be a set of Plans for an all built up version.. not really sure yet.
Ho 229 Build northropn9m Flying Wings 154 Oct 22, 2009 05:42 PM
Building the Luftwaffe secret weapon - Horten Ho 9/229 XPHAM Electric Ducted Fan Jet Talk 107 Dec 15, 2005 01:31 PM
Ho 229 Tempest Electric Ducted Fan Jet Talk 0 Nov 05, 2004 03:39 PM
Jack Cooper's ho 229 (sting wing) mothflyer Slope 4 Sep 01, 2003 11:26 AM
Building the secret Luftwaffe weapon - Horten Ho 9/229 XPHAM Scale Kit/Scratch Built 14 Apr 01, 2003 08:26 PM
